Dana 60 lost backlash, again #3096114
11/21/22 05:58 PM
11/21/22 05:58 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Car has aprox 800 passes. 3330lb, footbrake, 60ft mid 1.2x. First Motive street gear went 425 passes. Bent the teeth and lost backlash. 2nd set, cheapy 4.30. Broke 3 pinion teeth at 160 passes. When I installed the 3rd set; new 5 series strange steel spool and US gear Pro gear. Checked spool runout. Stoned the back of the gear. Checked the backlash at 90 degrees (.007"). Gear was set up text book pattern to me. I could hear clicking while coasting in the stage lanes last time out. Spool and pinion had proper preload. This gear set has about 225 passes. Pulled it apart. Fluid looked ok. It binds on the same 2 pinion teeth for each driveshaft rotation. It has zero backlash. I tried to check ring gear runout on the back outer edge. With the ring gear assembled on the spool that ledge is narrow to get a good reading. It seemed to vary .005". However the tight spot (spool closest to pinion) doesnt corolate at the same spot that the pinion teeth bind. My assumtion is it bent the pinion teeth. Assembled I see no cracks. I have to think this thing shouldn't be so hard on rear end parts being a foot brake car. Thoughts?
Doug
Re: Dana 60 lost backlash, again [Re: dvw] #3096125
11/21/22 06:41 PM
11/21/22 06:41 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Just a thought, did you check the yoke end of the pinion for run out? Maybe the pinion has a slight twist or something
Re: Dana 60 lost backlash, again [Re: rickraw] #3096141
11/21/22 07:43 PM
11/21/22 07:43 PM
Out of the State of Confusion
blue_stocker Offline
Are you using an S60 or OEM housing? What caps? How much carrier bearing preload? When you set it up, did you spot check across the ring gear teeth for TIR as wellas backlash?
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Dana 60 lost backlash, again [Re: blue_stocker] #3096166
11/21/22 09:09 PM
11/21/22 09:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Wear item !
Re: Dana 60 lost backlash, again [Re: dvw] #3096168
11/21/22 09:24 PM
11/21/22 09:24 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I haven’t had that problem but, I had a ProGear vibration big time on decelerating. I called Mark Williams, and after listening to the fault description, he asked if the pattern looked like a “flying v”. Indeed it did, and he told me to disregard the pattern, as the teeth move, depending on loads. I didn’t feel comfortable with the decel vibration, and installed a new gear set. FYI only.
Re: Dana 60 lost backlash, again [Re: Leigh] #3096171
11/21/22 09:40 PM
11/21/22 09:40 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a 1 Ton Truck Dana 60 axle that I cut down. The truck axles have much thicker tubes. We narrowed it, welded the tubes 100% and added weld to the plug welds. I made my own billet aluminum caps, use all strange components with a support diff cover. No issues yet.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Dana 60 lost backlash, again [Re: dvw] #3096234
11/22/22 02:28 AM
11/22/22 02:28 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
What is your definition of proper preload for the diff and pinion?
Initially set up with .007 backlash that tightened itself up to zero? confused
Re: Dana 60 lost backlash, again [Re: INTMD8] #3096246
11/22/22 09:12 AM
11/22/22 09:12 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The pinion preload; 1st set with new bearings was just over 20"/lb. Last set with used bearing was actually a touch tight at 15"/lb. Last rotating torque with the carrier was 30"lb. And yes it started at .007" and has zero. I've been told the teeth bend tightening it up. More than one source suggested far more backlash to start. Close to .014"
Doug
Re: Dana 60 lost backlash, again [Re: dvw] #3096249
11/22/22 09:29 AM
11/22/22 09:29 AM
CJD AUTOMOTIVE Offline
Backlash seems awful tight for a race gear. We set street up for .005-007". Most race gears are .012" up, depending on manufacture.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Dana 60 lost backlash, again [Re: dvw] #3096258
11/22/22 10:30 AM
11/22/22 10:30 AM
PA
moparacer Offline
moparacer  Offline
PA
I posted a reply to your thread over on the Bullet doug but I don't know about teeth bend, "tightening it up" so to speak.....Has anyone else on here ever seen that? I would think breaking would be soon to follow. I have not and like I have said many times I beat the living snot out of my Dana with a trans brake now with 1.19 60 fts. and have used Motive, Richmond and other gear sets.
I have ran my backlash loose too I might add. .010-.012 at times on old worn gearsets.
Foobraking should be so much easier too. The gears would last twice as long you would think. shruggy
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Dana 60 lost backlash, again [Re: moparacer] #3096271
11/22/22 10:56 AM
11/22/22 10:56 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have cracked a few sets on the root of the ring gear. It starts growling that you hear when being pulled back after a pass.
Re: Dana 60 lost backlash, again [Re: FastmOp] #3096283
11/22/22 12:02 PM
11/22/22 12:02 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It looks like I should be setting it looser. Recomedations for a Richmond 4.10 pro gear? Or Motive standard gear? I have to wait to get it completely apart as I need the hoist for a couple of jobs first. I have a 3 series spool. If it needs a new gear I think I'll go back to a 4.10. It goes thru at 7250 rpm now. Doesn't really need to be that high. Besides if I ever decide to try a 315 radial It'll need less gear.
Doug
Re: Dana 60 lost backlash, again [Re: dvw] #3096288
11/22/22 12:10 PM
11/22/22 12:10 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Is the housing flexing on launches?? Are the tubes stock? maybe time to brace the housing somehow.
....BAD A$$ STREET CAR.....
Re: Dana 60 lost backlash, again [Re: n20mstr] #3096300
11/22/22 12:56 PM
11/22/22 12:56 PM
an8sec70cuda Offline
This was my thought also. Seems like every time I've heard of a Dana having problems keeping a gear in it, you end up finding the housing was bent.
Monte Smith warned me about this years ago when I decided to keep my Dana and not change to a 9".
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 lost backlash, again [Re: an8sec70cuda] #3096323
11/22/22 02:16 PM
11/22/22 02:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
1.20ish 60 @ 3300# is nothing to sneeze at. Especially with a radial, if you are running those.
People at MW have also said, current R&P sets are not what they used to be, and you just have to deal with it.
Re: Dana 60 lost backlash, again [Re: CMcAllister] #3096337
11/22/22 03:13 PM
11/22/22 03:13 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Pulled it apart. Spool runout is zero. Carrier still had plenty of preload. Races still fit snug in the housing. Bearings all look good. Pinion preload was less than when it was assembled. But it still had preload. Aparently the "Pro" gear isn't much better than the standard Motive.
Doug
Re: Dana 60 lost backlash, again [Re: dvw] #3096355
11/22/22 04:40 PM
11/22/22 04:40 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Wow. Nice detective work.
Rich H.
Esse Quam Videri
Re: Dana 60 lost backlash, again [Re: dvw] #3096386
11/22/22 07:11 PM
11/22/22 07:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm glad you caught it now.
Re: Dana 60 lost backlash, again [Re: dvw] #3096387
11/22/22 07:20 PM
11/22/22 07:20 PM
AndyF Offline
AndyF  Offline
Your assumption was correct. Good thing you went ahead and pulled it apart. Some people think that stuff will fix itself but usually it just blows up and makes a big mess!
Re: Dana 60 lost backlash, again [Re: dvw] #3096391
11/22/22 07:35 PM
11/22/22 07:35 PM
Maybe it is time to upgrade the rear end for one that will live longer with less maintenance, and I am not talking about GM 12 bolt or Ford a nine inch with all after market parts either shruggy
