Antifreeze Tester #3096055
11/21/22 02:43 PM
11/21/22 02:43 PM
Cruising!
Q
QuickDodge Offline OP
Q
Cruising!
This is a rather basic question, but I've been away from the auto service industry for a LONG time!!
Back years ago, all the antifreeze was green. Today, there are several different colors. Do these different types of antifreeze require different testers? I'm concerned about the concentration of antifreeze to water. I don't want the coolant to freeze due to it not having enough antifreeze in the mix.
I have an 25+ year old Prestone dial type tester. It was the basic, cheap tester. Can I use it for all of the various types of antifreeze being sold today?
Re: Antifreeze Tester [Re: QuickDodge] #3096060
11/21/22 02:56 PM
11/21/22 02:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I still use the same cheap Matco tester I bought 30 years ago and it still works on everything I work on at the dealership.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Antifreeze Tester [Re: QuickDodge] #3096119
11/21/22 06:20 PM
11/21/22 06:20 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The anti freeze that won't kill the dog is made from different stuff, so it takes a different tester, so I would guess that the other non toxic brands would also.
Re: Antifreeze Tester [Re: 71birdJ68] #3096236
11/22/22 07:37 AM
11/22/22 07:37 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
You can usually tell by the look compared to the correct mix. Most places sell only mixed antifreeze, If you want the non mixed stuff you have to look for it.
Re: Antifreeze Tester [Re: Moparite] #3096252
11/22/22 09:44 AM
11/22/22 09:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by Moparite
Quote
I haven't had a problem finding the concentrated stuff anywhere I have looked. It's on the shelf.
Re: Antifreeze Tester [Re: QuickDodge] #3096426
11/22/22 10:26 PM
11/22/22 10:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The premixed should have the protected temperature on the back of the jug. Also if you buy the non diluted and mix yourself do not use tap water but rather distilled. i likely have the same prestone tester (actually 2) as well as a few others. they all read about the same BUT I have not tried them on the environmentally friendly stuff
beer
Re: Antifreeze Tester [Re: TJP] #3096612
11/23/22 05:59 PM
11/23/22 05:59 PM
5thAve Offline
5thAve  Offline
I've noticed with the one that I have that when Prestone switched to the yellowish antifreeze in their bottles the tester doesn't work as well as it does with the green stuff.
I don't think I've ever tried it with newer stuff.
Re: Antifreeze Tester [Re: 5thAve] #3096696
11/24/22 12:20 AM
11/24/22 12:20 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I'm pretty sure any tester will be accurate enough to determine freeze points. If you're that worried grab a refractometer...that'll handle about anything ya need.
https://www.amazon.com/Antifreeze-C...&hvtargid=pla-568291110880&psc=1
Re: Antifreeze Tester [Re: TJP] #3096863
11/24/22 04:22 PM
11/24/22 04:22 PM
moparx Offline
moparx  Offline
The premixed should have the protected temperature on the back of the jug. Also if you buy the non diluted and mix yourself do not use tap water but rather distilled. beer
another thing to consider, is adding an anode radiator cap or something similar.
an anode will keep dissimilar metals [such as an aluminum water pump and housing and an iron block] from reacting with each other, creating deposits in the cooling system that will, over time, affect the cooling ability of the entire system.
beer
Re: Antifreeze Tester [Re: QuickDodge] #3097551
11/27/22 01:55 PM
11/27/22 01:55 PM
Chicago
PurpleBeeper Offline
Chicago
Short answer - your old Prestone float tester will work just fine. It measures specific gravity of the coolant, which still uses ethylene glycol regardless of which color it is.....so the testers still work fine. Someone mentioned the stuff that won't kill your dog (e.g. Sierra), which is made with propylene glycol, and he's correct, the tester would be off a little bit with Sierra antifreeze
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
