Real Life Ported E-head VS TrickFlow 270 Comparison
#3096167
11/21/22 09:18 PM
11/21/22 09:18 PM
Posts: 2,275 Kissimmee, Florida
aarlucas
Kissimmee, Florida
I see everyone looking for the performance of the TF270 heads. I figured I would post real life side by side comparisons for everyone to see. First, I will list the car and engine combo. The car, 225" slip joint dragster, 4.10 gear, PG w/1.80 first gear, Coan 5800 converter, 2 1/8" tube headers and total weight is 1770. The short block is one I built 19 years ago for my 1970 Cuda. This engine has about 2000 street miles on it and I have no clue how many 1/4 and 1/8 mile passes it has...a lot though! I love it because I put gas in it, cool it off an hit the start button and go again, virtually zero maintenance between rounds or races! The engine: (With E-Heads)451CI - .055 over stock stroke 10.7-1 CR (0 Deck) Cam - Comp Cams 258 and 262 @ .050 631/631 lift, spec'd by Dewayne Porter for me in 2005. Heads E-heads ported by Dewayne Porter, 303 flow @ .600 Intake was a box stock Holley Street Domination Carb was a 4150 1000cfm Holley The Engine now: (TF270)451CI - .055 over stock stroke 11.0-1 CR (0 Deck), this is because the CC is smaller Cam - Comp Cams 258 and 262 @ .050 631/631 lift, same cam Dwayne Porter cam, no changes. Heads out of the box TF270's Intake Indy MW tall manifold (box stock) Carb - Gen 3 1050 Holley Domination So far I only have four runs on this new combo, still fine tuning it. Below are side by side comparisons with almost identical weather.
Head E-Head TF270
Launch RPM 5200 4800
60' Time 1.141 1.084
330' Time 3.379 3.213
660' Time 5.311 5.029
660' MPH 126.36 134.73
1000' Time 7.008 6.621
1320' Time 8.470 7.996
1320' MPH 152.99 162.82
No clue how to load a chart, this took forever to get right (formatted in a legible format!) I believe with a little more tuning and the right air, low 7.9's or high 7.8's are very possible with this current combo. Dewayne, if you read this, that little street cam you spec'd for me years ago has been amazing!! However, I think a new one might be in order now for the new combo as this one just doesn't have the higher RPM range this set up needs now. With the e-heads, I was trapping at 6800, now I am trapping at 7300 and I have to much converter slippage too, not because of the cam...just because I do, for now .
Re: Real Life Ported E-head VS TrickFlow 270 Comparison
[Re: aarlucas]
#3096201
11/21/22 11:16 PM
11/21/22 11:16 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
That’s awesome info, thanks for sharing. 100-ish hp just from a head, intake and carb swap is super promising for the 270’s! What pistons and rods are in the shortblock? 7300 is nothing to sneeze at.
[Re: Blusmbl]
#3096260
11/22/22 10:35 AM
11/22/22 10:35 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
[Re: aarlucas]
#3096291
11/22/22 12:26 PM
11/22/22 12:26 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Impressive gains for sure!!
Looks like between the heads, intake, and carb you’re up about 100hp.
When you say the “tall” Indy MW manifold...... do you mean the 440-3 or the 440-3X?
An interesting test prior to the head swap would have been the 1050 carb on a std port Ede SV intake.
[Re: AndyF]
#3096296
11/22/22 12:40 PM
11/22/22 12:40 PM
Posts: 5,163 CT
GTX MATT
CT
Is the 1770 without driver?
[Re: AndyF]
#3096377
11/22/22 06:02 PM
11/22/22 06:02 PM
aarlucas
Kissimmee, Florida
Andy, I read the articles you did when I was deciding which heads to buy. I wasn't looking to set the world on fire, was just hoping to break into the 7's with what I would call a street engine. Hell, I ran this engine on the street for 15 years, so I guess it really is one . I seen you were sending the manifold to Wilson, but I never seen the results after you got it back from them. They are only 100 miles from me, so I have considered taking it to them. Which porting service did you get? I have also eyeballed that cam Dwayne did for you as well. Because I have low compression, I was thinking that cam would be about perfect. Dwayne, what can you tell me about the cam and how it would work in the dragster. Rick
[Re: aarlucas]
#3096389
11/22/22 07:25 PM
11/22/22 07:25 PM
Posts: 31,042 Oregon
AndyF
Dwayne, I had to look this up. There are two manifolds, as you are aware. I have the 7.25" high, which is the 3X. Wow, the 3X is a BIG intake manifold. I'm surprised it is working that well for you. If you have the money and time I'd recommend testing an Edelbrock Super Victor with Max Wedge ports. The Edelbrock SV should be a better intake for your engine than the 3X. But of course, what you have seems to be working pretty well so no need to change if you don't want to.
[Re: aarlucas]
#3096467
11/23/22 08:10 AM
11/23/22 08:10 AM
Blusmbl
Plymouth, MI
Blusmbl, I have Ross pistons and Manley H-Beam rods. Thanks! Again, your combo is working super well together, and has really highlighted how great those heads are out of the box.
[Re: Dragula]
#3096482
11/23/22 09:45 AM
11/23/22 09:45 AM
Posts: 1,131 Loudoun County, VA
Brad_Haak
Loudoun County, VA
So, just to throw some water on this, does anyone know how the TF270's compare against either the Indy -1 or 325 heads? I can tell you from a flow bench perspective, these top out around 380cfm, and the B1 heads go +420cfm.... TF advertises 350-ish, IIRC Comparing it to a B1 is a bit apples to oranges, given the B1 requires special pistons, etc., whereas the TF is basically a bolt on.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: aarlucas]
#3096483
11/23/22 09:48 AM
11/23/22 09:48 AM
Brad_Haak
Loudoun County, VA
Chip, I was hoping for 8.2's so I was extremely surprised too! The gains showing up right from the 60-ft is pretty impressive, too.
