Re: 413/440 crank pilot/register dimensions [Re: moparx] #3101421
12/11/22 08:26 PM
12/11/22 08:26 PM
PINE VALLEY
Ray S Offline OP
Ray S  Offline OP
PINE VALLEY
Originally Posted by moparx
i just measured a 440 crank in an engine i have on the stand.
it happens to be an eagle 8 bolt crank, so take these dimensions for what they are worth.
One other dimension I'd like if possible - the offset from the face of the flange to the block mating surface.
I'm assuming is is ~.61 from what I could find and the B/W drawing posted earlier.
I'm now making an offset metrology plate (blue) and one plug(red) for the crank adapter from JVX with the same .697
diameter as the input shaft.
Re: 413/440 crank pilot/register dimensions [Re: Ray S] #3101947
12/13/22 02:31 PM
12/13/22 02:31 PM
moparx Offline
moparx  Offline
using a straight edge from the crank flange to the bell mounting surface in several places, i got 0.600 [six hundred thousandths]
beer
Re: 413/440 crank pilot/register dimensions [Re: moparx] #3101957
12/13/22 02:54 PM
12/13/22 02:54 PM
PINE VALLEY
Ray S Offline OP
Ray S  Offline OP
PINE VALLEY
beer
Awesome, thanks.
I was just estimating from the brewersperformance drawing, scaled to the dimensions there, so .610 was not bad.
beer
