Initial and Total Timing '69 Road Runner 383 #3095388
11/18/22 11:29 PM
11/18/22 11:29 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Just rebuilt the original 383 in the road runner. Measured 9.0-1 compression, iron heads with Summit small cam (214/224 @ .050" = .444/.466), stock exhaust manifolds and stock intake with Edelbrock 650. I used the Summit electronic dizzy and ECU with vacuum advance.
Suggestions for initial and total timing for street driving??
Re: Initial and Total Timing '69 Road Runner 383 [Re: VITC_GTX] #3095394
11/19/22 12:23 AM
11/19/22 12:23 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You have a dial back timing light?
Abe Lincoln
Re: Initial and Total Timing '69 Road Runner 383 [Re: VITC_GTX] #3095395
11/19/22 12:23 AM
11/19/22 12:23 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
18 initial and 34 total. Adjust as needed. twocents
Re: Initial and Total Timing '69 Road Runner 383 [Re: bobby66] #3095403
11/19/22 01:20 AM
11/19/22 01:20 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
34 total. Initial and springs wherever you like it.
I want my fair share
Re: Initial and Total Timing '69 Road Runner 383 [Re: bobby66] #3095405
11/19/22 01:57 AM
11/19/22 01:57 AM
CA
crackedback Online content
crackedback  Online Content
CA
These sound #'s good!
Sort out initial first. probably land in the 14-18 range, then total wherever it doesn't detonate. 34 is a good start.
Re: Initial and Total Timing '69 Road Runner 383 [Re: dart4forte] #3095412
11/19/22 02:27 AM
11/19/22 02:27 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Good question. I do have one of these.
Looks like I should start in the 14-18 range and then I'll have to fill in my slots in the plate of the distributor to limit the mechanical advance.
Thanks.
Re: Initial and Total Timing '69 Road Runner 383 [Re: VITC_GTX] #3095421
11/19/22 07:08 AM
11/19/22 07:08 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
get into the distributor and see if the centrifugal advance plate has a number on it. the number will tell how many centrifugal degrees are in the distributor. the mopar electronic distributors had 13 degree plates for 26 degrees total at the crank. i've found that a lot of initial timing in these stock or near stock builds burn crummy. i wouldn't do more than 10 degrees initial with a 13 degree plate. this is what i do and have noticed a cleaner burn and the engine drives good. i've done all kinds of curves from aggressive 9 degree plates to 15 degree plates with varying springs. smaller cams are more efficent in the lower and mid rpm range and don't need aggressive timing. aggressive timing is just a crutch for inefficient cams or poor tune-ups.
Re: Initial and Total Timing '69 Road Runner 383 [Re: lewtot184] #3095470
11/19/22 12:12 PM
11/19/22 12:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Smallish cam & iron heads & pump gas @ 9.0:1, I'm thinking 10-12 initial, 36 max mechanical, and run vac advance.
Used to routinely run that on stock 383s, woke them up from the factory setting. That was at sea level & in a warm (Calif) environment, pump premium.
You might find yours wants the total limited as already mentioned, as I'm not sure every aftermarket distributor has the same curve.
Gear ratio & cruise RPM can be factors as well.
Re: Initial and Total Timing '69 Road Runner 383 [Re: topside] #3095516
11/19/22 02:14 PM
11/19/22 02:14 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
something that can be done if you don't want to take the distributor apart to find out what it is is to put a 35-36 degree mark on the dampener and power time the engine. basically you can measure 2.25" from the TDC mark in the clockwise direction and place a mark on the dampener. this should get you close to 36 degrees. disconnect the vacuum advance and rev the engine until maximum centrifugal advance is acheived while aligning the 36 degree mark at the zero on the timing tab. then just let the initial be what at is and don't worry about it. hopefully your vacuum advance is adjustable, and you can play with that .
Re: Initial and Total Timing '69 Road Runner 383 [Re: lewtot184] #3095521
11/19/22 02:23 PM
11/19/22 02:23 PM
CA
CA
Stock 318's like 10-12 initial timing
initial is the foundation for all other timing events. My suggestion is give the engine what it wants at idle, then build from there.
The old school wherever it lands is a poor approach. JMO.
Re: Initial and Total Timing '69 Road Runner 383 [Re: crackedback] #3095553
11/19/22 03:36 PM
11/19/22 03:36 PM
iagree That is what I use on my street and strip BB motors on pump gas up wrench
Idling from 12 to 18 BTDC and all in (34 to 36 BTDC depending on the altitude by 2400 RPM up scope up
Re: Initial and Total Timing '69 Road Runner 383 [Re: VITC_GTX] #3095605
11/19/22 07:49 PM
11/19/22 07:49 PM
Minn
SportF Offline
SportF  Offline
Minn
If you are interested in performance, I suggest you ask a bunch of mopar drag racers at the track what they do. Their answers are probably different from that of which you hear here. Best of luck.
Re: Initial and Total Timing '69 Road Runner 383 [Re: SportF] #3095635
11/19/22 10:37 PM
11/19/22 10:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
On A fresh motor, I'd suggest 10-12 initial, 36 total with or without VA. Once broke in then start playing with it to see what it likes. The msot important part is Break the motor in and give the rings time to seat. twocents beer
Re: Initial and Total Timing '69 Road Runner 383 [Re: SportF] #3096007
11/21/22 12:29 PM
11/21/22 12:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This worked for me in 06 at the Pure stock drags, it was suggested that I run 42 total by a veteran PS racer from Detroit , I went as high as 39 and dumped a couple gallons of 110oct on top of the1/4 tank 93oct for piece of mind, the car picked up a couple tenths ...
Re: Initial and Total Timing '69 Road Runner 383 [Re: JohnRR] #3096123
11/21/22 06:27 PM
11/21/22 06:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
This. 42 degrees was pretty common. I ran 39-40.
Re: Initial and Total Timing '69 Road Runner 383 [Re: BSB67] #3096124
11/21/22 06:39 PM
11/21/22 06:39 PM
[quote=SportF]If you are interested in performance, I suggest you ask a bunch of mopar drag racers at the track what they do. Their answers are probably different from that of which you hear here. Best of luck.
[/quote ] Every time I have tried setting the verified total timing above 36 BTDC at any 1/4 mile track doing testing on every BB Mopar I've tuned slowed the car down in the ET and MPH shruggy
Don Wann, NHRA division 7 long time Mopar drag racer, had told me years ago that the 1963 Plymouth M.W. Savoy he owned and raced like 42 BTDC total timing, so I tried that on my legal 1963 415 HP Max Wedge NHRA stocker and it slowed down confused
I learn later that he didn't build the motors for his cars, a machine shop did them for his sponsor and it ended up that they had put a later year (1967 and later) timing cover on his M.W. motor with the original dampener making it read falsely tsk
My message is trust and VERIFY scope up twocents
Re: Initial and Total Timing '69 Road Runner 383 [Re: Cab_Burge] #3096211
11/21/22 11:58 PM
11/21/22 11:58 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Mopar action this summer mentioned 33-35 is sweet spot for power on a big block. I had found 34 worked best years ago. One time I had the distributor out, it bumped to 33 when I locked it down. I left it there and noticed no difference really so I’d vouch for their numbers.
Mopar used to say in the speed books that you should run 38. Back in the 70s you probably didn’t have a problem finding better fuels. I tried 38 and I got .5 mpg better, but it ran rough. I think it was signs of pre-ignition. Backing it down, that stock 383 hp smoothed out at 34 and was the smoothest engine I’ve ever had. That one was all factory built when I tore it down for a new chain and seals.
Re: Initial and Total Timing '69 Road Runner 383 [Re: SomeCarGuy] #3096261
11/22/22 10:35 AM
11/22/22 10:35 AM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
38 is from Basic Startup and Adjustment and Ignition Tuning for Maximum Performance taken directly from the Mopar Performance Small Block V-8 Electronic Ignition Kit instruction sheet
56 BTDC all in.
http://www.mopar1.us/engine2.html
Engine Heads Timing Specification
A Production - Pre '89 (Iron) 35 BTDC
A Production - '89 & Newer (Iron) 32 BTDC
A W2 (Iron) 35 BTDC
A W5 (Alum.) 35 BTDC
B/RB Production (Iron) 38 BTDC
B/RB Stage I, II, III, IV, V (Iron or Alum) 38 BTDC
B/RB Indy (Alum) 35 BTDC
B/RB B1 (Alum) Under 475 cu. in. 37-39 BTDC
B/RB B1 (Alum) Over 475 cu. in., Under 15.0:1 Ratio 36-38 BTDC
B/RB B1 (Alum) Over 475 cu. in., Over 15.0:1 Ratio 34-36 BTDC
B/RB B1 TS 34 BTDC
Hemi All (Iron or Alum) 35 BTDC
Re: Initial and Total Timing '69 Road Runner 383 [Re: Ray S] #3096423
11/22/22 10:18 PM
11/22/22 10:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
56 BTDC all in.
A W2 (Iron) 35 BTDC
B/RB B1 TS 34 BTDC
In my experience some motors will tolerate that Much vacuum advance and others will not. IMO it is best to break the motor in on the conservatives side and then start experimenting twocents
Re: Initial and Total Timing '69 Road Runner 383 [Re: SomeCarGuy] #3096468
11/23/22 08:14 AM
11/23/22 08:14 AM
Minn
SportF Offline
SportF  Offline
Minn
[. Everybody at the track is running 38, with a few at 36. The only guys running 34 degrees is when they are trying to slow the car down to meet an index. Now maybe when you are at sea level it makes a difference, that I don't know.
