amount of horsepower #3096118
11/21/22 06:20 PM
11/21/22 06:20 PM
Sacramento
morgdavex Offline OP
Sacramento
is there a rule of thumb ,that with ideal conditions. a certain amount of cfm added equals(x) amount of horsepower?
Re: amount of horsepower [Re: morgdavex] #3096142
11/21/22 07:44 PM
11/21/22 07:44 PM
AndyF Offline
AndyF  Offline
Are you talking about head flow? The rule of thumb for head flow is that cfm is 2 hp. So a head that flows 300 cfm should be capable of supporting 600 hp. This is barely a rule of thumb since it is only roughly correct but it gets you in the ballpark. The assumption is that the engine builder doesn't do anything stupid either upstream or downstream of the heads.
Re: amount of horsepower [Re: AndyF] #3096152
11/21/22 08:19 PM
11/21/22 08:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
And that it is a V8, a 4cyl is 1 to 1.
Re: amount of horsepower [Re: morgdavex] #3096235
11/22/22 06:52 AM
11/22/22 06:52 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
2 hp per cfm is a very solid N/A build, but if by "ideal conditions" you're referring to a maximum effort N/A build, well past 2 hp per cfm is routinely observed. For example, a PROPERLY ported W8 at 400 cfm, with the required supporting cast, will push well past the 800 hp level without breaking a sweat. 2.4-2.5 is obtainable, but requires serious refinement in every aspect of the engine.
With so many variables in play to maximize a particular combination, peak head flow being part of the overall package, is not the end all number in determining maximum power output. Not all cylinder head flow is created equal.
Re: amount of horsepower [Re: jim sciortino] #3096238
11/22/22 08:00 AM
11/22/22 08:00 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
.257xcfm@28hsig =hp of 1cylinder x # of cylinders. As stated anything done to increase VE will bring HP up. Formula only works with ACCURATE data.
