So Im getting ready to get my 14 Ram project under way, I like to build a daily driver into something unique, I built a "daCuda" out of a 00 Dakota, it was Sassy grass green with a 70 Hockey stripe and a shaker hood.
My Ram is going to be Either F8 green, Jamaica Blue, or EV2 Orange, planning the round slash cut charger tips, and grafting the center air grabber bulge from a 71/72 Runner onto a flat Ram hood. and use an electric motor to open the air grabber rather than use vacuum.
Can any of you guys give me a rough idea on dimensions of the fiberglass center bubble? The ram hood is aluminum, so I might end up buying a glass bulge hood and graft the center to the glass hood so its easier to work with unless by some miracle the basic arc of the two hoods match up.
Thinking of doing a 71 charger R/T themes stripe that comes off the hood and down the side of the truck.
thanks in advance....
