Collector or Hobbyist license plate #3095737
11/20/22 11:25 AM
11/20/22 11:25 AM
Green Bay
Andyvh1959 Offline OP
Green Bay
Up here in Wisconsin we can get a Collector or Hobbyist license plate for older or modified vehicles. Good thing about the Collector of Hobbyist license is the one time registration, paid once and done.
I recently bought a 56 Dodge C1-B8 pickup truck, and I need to find the original name for the Collector license plate on my 56. I looked up the number on the WI DOT website and it shows the plate is still current, registered until 12/31/3999. But now I need to transfer the title (currently lost) to my name. Once my 56 is back on the road as my daily driver it could be licensed as a truck, to register every other year, or register as a Collector or Hobbyist vehicle. However, this 56 will be my daily driver, and in Wisconsin a vehicle with a Collector or Hobbyist registration cannot legally be driven/used during the month of January. I'll have to find out from my friend's at the local sheriff department why the Collector or Hobbyist plate don't allow driving the vehicle in January.
Are other specialty license plates similar in other states? I wonder too, why a WI Collector or Hobbyist plate does not allow the vehicle to be legally driven for only the month of January. In WI a vehicle with a Collector plate can be driven in January, for only five days, if the plate holder submits a MV2750 temporary registration form.
My 56 C3-B8 Dakota build
Re: Collector or Hobbyist license plate [Re: Andyvh1959] #3095918
11/20/22 11:43 PM
11/20/22 11:43 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
In IL, the collector car plate only allows vehicle use for 6 months of the year, but you can also get an extended collector car plate that can be used year around (as I understand it) without restrictions for up to 9 months, and the other three months use is for attending a show or getting the vehicle repaired. Both classic car plates exclude "daily use".
The concept of the reduced classic car plates is because the vehicles usually get used a lot less then daily drivers. The reduced price is supposed to be because the vehicle uses the roads less. Often times the States will use the specialty car plates to attach added restrictions that they can apply only to those specialty plates. IL has been known to slip a few extra restrictions in on those special plates.
Call me paranode if you want, but all of my stuff has regular plates on them. I don't trust the State leadership to act in my best interest nor on my behalf.
Re: Collector or Hobbyist license plate [Re: poorboy] #3095939
11/21/22 09:40 AM
11/21/22 09:40 AM
Green Bay
Green Bay
Not paranoid at all, realistic is more like it. Anyone that thinks the government is solely working for our best interest in naive at best, and ignorant to the truth.
Yeah, I'll likely register my pickup as a truck and pay my highway use dues so I can use it as i see fit.
Re: Collector or Hobbyist license plate [Re: Andyvh1959] #3095941
11/21/22 09:46 AM
11/21/22 09:46 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That is what I did with my 51. Regular plates.
Re: Collector or Hobbyist license plate [Re: poorboy] #3095996
11/21/22 12:05 PM
11/21/22 12:05 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have never put classic/historical plates on any of my classics. I want to drive them when I chose not when the state says I can.
Re: Collector or Hobbyist license plate [Re: Dabee] #3096080
11/21/22 03:46 PM
11/21/22 03:46 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have collector plates on a couple cars ..
anything 30 years or older, it cost 10 bucks , they ask you to limit your driving to 2500 per year , they ask you do only go too and from events , they also year of make plates for 10 bucks but, you have to go find a nice pair at the swap meet
both are a 1 time pay
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Collector or Hobbyist license plate [Re: bigdad] #3096507
11/23/22 11:08 AM
11/23/22 11:08 AM
Green Bay
Green Bay
Quite different in South Dakota than in Wisconsin. The fee for a Collector or Hobbyist plate on a pickup is $250, for a car its $200.But once paid that plate is not renewed bi-annually like a regular plate. Here in WI the Collector or Hobbyist plated vehicle is limited to no legal use in January. Also, for a pickup truck the load carried is limited to 500 lbs. Since I plan to haul motorcycles that means an officer could pull me over suspecting the motorcycle in back weighs more than 500 lb should I have a Collector plate on my 56 pickup. I think the standard plate registration fee for a 1/2 ton pickup in WI is $125 for two years.
Now, some will say "WI is expensive to register a vehicle." But, WI has no toll roads, but WI has higher gas tax, some communities have a road use tax. WI registration fee is not calibrated to the vehicle market value, same fee for a 1956 pickup or a 2022 pickup. Also, other than a few counties around Milwaukee and Madison, WI does not require a vehicle/emissions inspection in order to register your vehicle. So up here in Green Bay, if the catalytic converter has gone awry you can just cut it out of the exhaust and pipe it through (yes, you'll have to tweak an O2 sensor to avoid a fault code). Interesting thought, since I plan to mount the cab/box of my 56 Dodge pickup onto my 2001 Dakota chassis, in WI the 56 cab VIN will identify it as a 1956 Dodge. As such I can legally use it as a 1956 vehicle relative to emissions. So I can chose to not have catalytic convertors in the exhaust.
Re: Collector or Hobbyist license plate [Re: Andyvh1959] #3096543
11/23/22 12:52 PM
11/23/22 12:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No, you cannot legally do that. The federal emissions laws are related to the date of manufacture for EITHER the vehicle, or the engine, whichever is newer. Legally, you'd be required to meet 2001 emissions, all of them, including vapor capture. The feds have been cracking down, hard, of late. It's trickling down to the hoobyist level.
Re: Collector or Hobbyist license plate [Re: Sniper] #3096626
11/23/22 07:12 PM
11/23/22 07:12 PM
Green Bay
Green Bay
Ok, thanks for the clarification. So you are saying even though my Dakota will become a 56 Dodge (as the 56 serial number will become the VIN), the state will maintain the emission standards for the 2001 donor chassis under the 56 Dodge. I do hope to use the plastic fuel tank and entire fuel system (including the filler neck, hose, vent, charcoal filter, etc) from my 2001 Dakota for the 56 Dodge project. My goal is to basically turn the 2001 Dakota sheet metal into 56 Dodge sheet metal, but use all of the Dakota mechanical systems. The current cat in my Dakota works fine, so hopefully it too can move over to the 56 build.
Re: Collector or Hobbyist license plate [Re: Andyvh1959] #3096831
11/24/22 02:25 PM
11/24/22 02:25 PM
moparx Offline
moparx  Offline
anymore, in pennsylvania, there are so many antique, classic, and collector type tags available, plus year of manufacturer tags allowed, it's hard to decide exactly what a guy may want to title his ride as.
it's also just as hard for the police to decide if you have the wrong type tag in use.
in all tag descriptions, there are places your lawyer can point out that a discrepancy exists, allowing you to use the tag you have displayed.
as for example, the "antique" tag strictly states the vehicle in question must be as manufactured. it is also allowed on all vehicles 25 years old and older. you must also have a registered vehicle to use as daily transportation. there are other restrictions as well.
however giving a classic example of a vehicle that "qualifies" [and has done so for 60 years or more], is the ford "speedster".
henry never "manufactured" any example, yet in the days of old, guys removed fenders and bumpers, plus modified the bodies of model t's to go faster. not exactly in the "spirit" of the antique tag's description. it used to be necessary for four pictures to be included in an "antique" application, now, no pictures are necessary. just the 25 years and older stipulation. as this tag requires no annual safety inspection, and is a lifetime tag, more and more guys are using this tag for everything under the sun, vehicle wise.
i guess my point is, just behave yourself out there, and make sure your ride is safe.
we did this way back when, and the police gave us way more thumbs up than tickets.
my personal experience in life.
your mileage will vary.
beer
Re: Collector or Hobbyist license plate [Re: moparx] #3105586
12/26/22 04:07 AM
12/26/22 04:07 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
i have historic plates plates in missouri on 3 of my vehicles.dont needed to get them inspected no more.and the plates dont need to be renewed
Re: Collector or Hobbyist license plate [Re: dart games] #3105782
12/26/22 08:41 PM
12/26/22 08:41 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Yeah, I'm in Missouri also and I've just registered my 62 dune buggy with a 1962 year of manufacture plate.
I also registered my 1988 Plymouth Reliant K Car with 1988 year on manufacture plate too.
It's clean for an 88 and it's just a spare backup vehicle.
The 67 Plymouth Satellite that I had about 5 or 6 years ago had year on manufacture plate on it too.
Re: Collector or Hobbyist license plate [Re: SNK-EYZ] #3106644
12/30/22 01:16 PM
12/30/22 01:16 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
How a Model Year Plate almost got me arrested.
In Ohio (where I used to live) you can get a Historical plate with a one time fee that lasts forever. It's good for a vehicle over 25 years old that isn't a daily driver. Once you get the Historical plate you can then take a Model Year plate to the BMV and they will register it to your car. My wife bought me a very nice set of 1970 Ohio plates. I registered them at the BMV as required and had them on my car for years. One night as I was driving home from a local cruise I got pulled over by a young small town Cop.(we'll call him Cop#1) He wanted to know why I had Government plates on my old car. 1970 Ohio plates were red letters on white background and so are all Ohio Government plates. I tried to explain Model Year plates and he wasn't buying it. Never heard of such a thing. The plates literally say 1970 on them in the same place as Government plates would say Government. He said that just meant they where 1970 Government plates. By this time his Backup arrived (Cop#2). I could tell that cop#2 wasn't so sure that cop#1 was right but he wouldn't say anything. Cop#1 wanted to cuff me and call a wrecker. Finally another Cop shows up (Cop#3) and he is a Sgt. Cop#3 listens to Cop#1 rant. Then listens to my explanation. Cop#3 tells Cop#1 and Cop#2 they can leave. He tells me to go straight home and come back to the station tomorrow with all the paper work for the previous normal plate, the Historical plate and the model Year plate as well as the copy of the applicable laws that I told him I had and he would straighten this all out with Cop#1.
I went home and immediatly took the Model Year plate off and hung it on the wall.
Now I live in Tennessee and they have Antique plates but their law clearly states that you can not have any modifications to the engine or body. Not going to work for me. There are plenty of modified cars running around here with antique plates but I don't intend to stand on side of the road with another rookie cop for 45 minutes so no Antique plate or Model Year plate for me,
Never heard what happened to Cop#1. I imagine he got a lot of ribbing and then they all went down the road to Dunkin Donuts.
Re: Collector or Hobbyist license plate [Re: GomangoCuda] #3106792
12/30/22 09:23 PM
12/30/22 09:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
There are reasons I have and pay for regular plates on all of my stuff. I don't need to be in some flea bit tourist trap burg and have Deputy Barney see me as a great revenue source for his county. If you have regular plates like everyone one else from your state they have seen, they watch you go by, hoping your speeding.
Re: Collector or Hobbyist license plate [Re: poorboy] #3107233
01/01/23 01:49 PM
01/01/23 01:49 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have 2 WI collector plates. Never had any issue with them. Yep can't drive it in January but I see no reason to with my cars...your truck sounds different so do your research before you register. As stated...collectors are once and done, I believe hobbyists are as well. There are restrictions and guidelines for each so be sure to check with DOT. Truck plates are yearly and go by weight....emissions tests are every other year. My C truck plates are 6000 lbs and around $125/year. Saw a guy yesterday with a Collector on his Saturn......curious what he's driving today....lol
Re: Collector or Hobbyist license plate [Re: Dcuda69] #3107284
01/01/23 05:35 PM
01/01/23 05:35 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I have two WI collector plates. Each collector plate required proof of registration of another vehicle in the household with regular plates before they would be issued.
First car:
In 2008 the state required photos of my '71 Challenger to verify it was stock and not modified along with the application. I received a reply in the mail from the DMV saying it was rejected for being "modified" and hobbyist plates were being issued in 2 weeks unless I contest. With the exception of headers and MP valve covers, my '71 Challenger is stock restored including Polyglas tires.
I called the DMV in Madison and was able to get connected to the department that processes the applications. The DMV retrieved my application and the photos I submitted and said it was rejected due to the air scoop coming through the hood. I proceeded to explain to them what a shaker hood is. Then, I asked what do you use for research? Google? There was a pause, and they quietly say "yes". So, I told them to Google "71 challenger shaker". They reply "oh, you're approved". Got my collector plates a couple days later.
Second car:
I picked up a '71 Barracuda in 2020 sporting side pipes (since removed), which would disqualify it per WI DMV rules. Send in the application for collector plates and no photos. They changed the application to saying they may request photos. I was approved no questions asked. I'm guessing with the limited resources because of Covid they were just rubber-stamping approvals.
Re: Collector or Hobbyist license plate [Re: skdmark] #3107398
01/02/23 12:50 AM
01/02/23 12:50 AM
Green Bay
Green Bay
Ha. Good bet that anyone working at the DOT or DMV is a good bit younger than most anyone on this site. Also, I'd bet very few of them have NO knowledge of what real cars used to be. Case in point, why would any "stock" car havesomething sticking up through the hood? I wonder how many Plymouth Superbird or Dodge Charger Daytona, or even a 1970 Mercury Meteor owner would have to explain that their car is completely stock, even with huge wings and things sticking out. Pretty much anyone born after 1980 has little knowledge of the vehicles we strive to enjoy.
Re: Collector or Hobbyist license plate [Re: Andyvh1959] #3107470
01/02/23 11:26 AM
01/02/23 11:26 AM
KY
65pacecar Offline
65pacecar  Offline
KY
KY has a pretty easy law to use Year of Make vintage tags, you just have to keep the historical tag in the car with you in case it's requested. The car has to be registered as historic to run the old plates, I also carry a print out of the law just in case I run into an officer that questions it.
