Hey, beer drinkers! Forget sipping your beer out of the small hole of a can.
There’s a more enjoyable way to drink a can of beer these days, and that’s with The New Draft Top Easy Can. It removes the top of almost any beer or soda can. It’s on sale as a part of our Every Friday is Black Friday promotion, costing you only $15.99, no coupon required! However, there’s limited inventory, so act fast and kickstart your holiday shopping.
It removes the tops of aluminum cans ranging from 8oz to 16oz (and some 19oz cans with standard tops). Thanks to the four rotational blades designed to create a smooth, safe-to-drink rim, you won’t have to worry about cutting your lip or mouth area either. The Draft Top’s patent-pending design features a pressure-regulated handle, a fully-embedded magnet, a lanyard hole and a textured grip.
The Draft Top is perfect for beer-loving adults and soda-drinking individuals. It gives you more room to add alcohol to a non-alcoholic beverage, such as seltzer or cola. It was successfully funded on Kickstarter, supported by 16,735 backers and is well-reviewed on Amazon.
======= Good, Bad, or “I don’t have any trouble guzzling my beer now”
Re: $16 beer can top remover
[Re: 360view]
#3095751 11/20/2212:43 PM11/20/2212:43 PM
Drinking beer out of aluminum is not ideal. But drinking it out of and open top cup is better than out of a small hole in a pop-top can or bottle. Pouring out into a glass is best. Savoring the aroma is part of the experience. Maybe this thing that turns a pop-top into a cup is a good compromise? Still will there be an aluminum taste?
[img]http://i.imgur.com/boeexFms.jpg[/img] 31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3095948 11/21/2210:10 AM11/21/2210:10 AM
And drinking beer at Hooters, gets you kicked out...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3096010 11/21/2212:46 PM11/21/2212:46 PM
A friend of mine has one of these. Oddly enough it actually does better the beer experience as opposed to a normal can. I thought it was dumb at first but now I need to order me one haha.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: moparx]
#3096057 11/21/2202:45 PM11/21/2202:45 PM
[Re: Hemi_Joel]
#3096079 11/21/2203:44 PM11/21/2203:44 PM
Finally! A voice of reason!
[Re: moparx]
#3096164 11/21/2208:59 PM11/21/2208:59 PM
So, how many think pouring out the beer into the right shaped glasses producing “just enough” head of foam improves the drinking experience?
Many years ago I visited a brewery near Winston Salem where a plant engineer said they “overcarbonated” their beer expecting it to be poured into a glass where part of the bubbles popping would create “just right” taste.
[Re: JERICOGTX]
#3096308 11/22/2201:22 PM11/22/2201:22 PM
