Main cap slide hammer #3095727
11/20/22 11:03 AM
11/20/22 11:03 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What kind of slide hammer you guys using to remove main caps and where did you find it?
Re: Main cap slide hammer [Re: mopar dave] #3095731
11/20/22 11:12 AM
11/20/22 11:12 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
just a long 3/8x16 bolt with a slug of steel and hole drilled in it
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Main cap slide hammer [Re: Jerry] #3095740
11/20/22 11:34 AM
11/20/22 11:34 AM
Mt Morris Michigan
Mt Morris Michigan
wasn't sure what the thread size was, but i found a 5/16 bolt that fits perfectly. It has 13 threads and only 3/4 long, so maybe 18 thread?
Re: Main cap slide hammer [Re: mopar dave] #3095746
11/20/22 12:23 PM
11/20/22 12:23 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
All thread rod, 12"-18" long, a nut & big washer and a 1" deep impact socket will work. Nothing fancy needed, the caps are not that tight.
Brian
Re: Main cap slide hammer [Re: '72CudaRacer] #3095749
11/20/22 12:36 PM
11/20/22 12:36 PM
Mt Morris Michigan
Mt Morris Michigan
Sweet! Thank you.
Re: Main cap slide hammer [Re: mopar dave] #3095761
11/20/22 01:14 PM
11/20/22 01:14 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Lowes
Without Data, you’re just another guy with an opinion.
Re: Main cap slide hammer [Re: sr4440] #3095836
11/20/22 05:09 PM
11/20/22 05:09 PM
NH, USA
toddinNH Offline
Egghead
toddinNH  Offline
Egghead
NH, USA
Originally Posted by sr4440
Lowes
Site needs a like button.
Re: Main cap slide hammer [Re: sr4440] #3095845
11/20/22 06:18 PM
11/20/22 06:18 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, i just made one with threaded rod and used a large adjustable wrench for the weight. They popped right off. Thanks
Re: Main cap slide hammer [Re: mopar dave] #3096038
11/21/22 01:56 PM
11/21/22 01:56 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Here are a couple I use . Gary
Re: Main cap slide hammer [Re: Gabby63] #3096064
11/21/22 03:15 PM
11/21/22 03:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Also nice for pulling transmission pumps.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Main cap slide hammer [Re: pittsburghracer] #3096105
11/21/22 05:23 PM
11/21/22 05:23 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I made this bridge out of some scrap. Works good for pulling the caps on my Indy Maxx block
Re: Main cap slide hammer [Re: cl440] #3096206
11/21/22 11:26 PM
11/21/22 11:26 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Where is the water drain plug in the Indy max block?? I have one also.
Re: Main cap slide hammer [Re: Thelma133] #3096267
11/22/22 10:46 AM
11/22/22 10:46 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Should be drilled and tapped for a 1/8" pipe plug.
69 GTX 68 Road Runner
Re: Main cap slide hammer [Re: cl440] #3096269
11/22/22 10:47 AM
11/22/22 10:47 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I made a bridge for mine as well. Removes the main caps off in a nice easy way.
Re: Main cap slide hammer [Re: JERICOGTX] #3096270
11/22/22 10:52 AM
11/22/22 10:52 AM
an8sec70cuda Offline
iagree Same here. 3 pieces of square tubing, one piece of threaded rod, and a nut.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Main cap slide hammer [Re: an8sec70cuda] #3096279
11/22/22 11:32 AM
11/22/22 11:32 AM
NC
440Jim Offline
440Jim  Offline
NC
Getting the caps off a cross bolted block typically isn't too bad.
The real benefit, IMO, of the "bridge"; is for installing them. Pushes straight and smooth. Tapping with a mallet can make the bearing shell fall out...
Re: Main cap slide hammer [Re: 440Jim] #3096313
11/22/22 01:40 PM
11/22/22 01:40 PM
NY
challenger451ci Offline
NY
That's very cool! I made a bridge for pulling similar to the others, but use long threaded rods threaded into the main stud holes and try to drive each side down even with two wrenches which is a huge PIA. The bridge you made is very slick for driving the caps straight.
