Re: Antifreeze Tester
[Re: QuickDodge]
#3096060
11/21/22 02:56 PM
11/21/22 02:56 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
I still use the same cheap Matco tester I bought 30 years ago and it still works on everything I work on at the dealership. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 71birdJ68]
#3096236
11/22/22 07:37 AM
11/22/22 07:37 AM
Posts: 969 rust belt
Moparite
rust belt
I'm concerned about the concentration of antifreeze to water. You can usually tell by the look compared to the correct mix. Most places sell only mixed antifreeze, If you want the non mixed stuff you have to look for it.
[Re: Moparite]
#3096252
11/22/22 09:44 AM
11/22/22 09:44 AM
Posts: 6,215 nowhere
Sniper
nowhere
I'm concerned about the concentration of antifreeze to water. You can usually tell by the look compared to the correct mix. Most places sell only mixed antifreeze, If you want the non mixed stuff you have to look for it. I haven't had a problem finding the concentrated stuff anywhere I have looked. It's on the shelf.
[Re: TJP]
#3096863
11/24/22 04:22 PM
11/24/22 04:22 PM
Posts: 19,307 north of coder
moparx
I'm concerned about the concentration of antifreeze to water. I don't want the coolant to freeze due to it not having enough antifreeze in the mix. The premixed should have the protected temperature on the back of the jug. Also if you buy the non diluted and mix yourself do not use tap water but rather distilled. another thing to consider, is adding an anode radiator cap or something similar. an anode will keep dissimilar metals [such as an aluminum water pump and housing and an iron block] from reacting with each other, creating deposits in the cooling system that will, over time, affect the cooling ability of the entire system.
[Re: QuickDodge]
#3097551
11/27/22 01:55 PM
11/27/22 01:55 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
Short answer - your old Prestone float tester will work just fine. It measures specific gravity of the coolant, which still uses ethylene glycol regardless of which color it is.....so the testers still work fine. Someone mentioned the stuff that won't kill your dog (e.g. Sierra), which is made with propylene glycol, and he's correct, the tester would be off a little bit with Sierra antifreeze
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
