Stage V head studs #3095744
11/20/22 12:08 PM
11/20/22 12:08 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Anyone know if the Stage V Hemi heads require something special for head studs? Using Barton T&D rockers. Can i use bolts? This build is 12:1 compression hot street deal.
Re: Stage V head studs [Re: mopar dave] #3095754
11/20/22 12:50 PM
11/20/22 12:50 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
They are stock thickness. But I forgot if the Ray Barton rockers take a shorter stud there. I can't use head bolts in an aluminum block. Edit: Ray's website says it uses stock head bolts.
2011 Drag Pak Challenger
Re: Stage V head studs [Re: rickseeman] #3095763
11/20/22 01:15 PM
11/20/22 01:15 PM
Mt Morris Michigan
Mt Morris Michigan
ok, i guess i should have looked there first. Thanks, i'll check that out.
Re: Stage V head studs [Re: mopar dave] #3095809
11/20/22 03:20 PM
11/20/22 03:20 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've been seeing some ARP head stud kits on ebay.
Re: Stage V head studs [Re: rickseeman] #3095818
11/20/22 03:52 PM
11/20/22 03:52 PM
moparx Offline
moparx  Offline
just my opinion as a career machinist of 45 years before retirement, and still practicing my craft today, i would use studs in all performance builds utilizing aluminum heads.
studs, in my opinion, offer a better clamping load.
i am no engine builder, but clamping large work pieces to CNC machining tables, studs always worked better than bolts.
just my opinion, your mileage will vary.
beer
