Re: Red's latest project
[Re: redraptor]
#3095687
11/20/22 08:06 AM
11/20/22 08:06 AM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
After a couple months of looking and not finding what I wanted, my buddy spied a hoist kit while we were walking thru a swap meet. I read up on these but had decided against it over the expense and no direct fit for my year truck. Plus the bed needed at ton of work to support it. But after talking to the seller and walking around another hour debating I went back and made him an offer. Got it cheap for something that was never used.
[Re: redraptor]
#3095690
11/20/22 08:21 AM
11/20/22 08:21 AM
redraptor
Greenville, PA
I never heard of Uni-hoist but it appears this was made in the mid to late '70's judging by the trucks shown in the manual. Instructions show how to install on on Ford, Chevy, or Dodge by using different brackets in the kit. I couldn't use really any of them. First hurdle was to repair my existing bed as I wasn't going to buy a good bed to experiment on. Fortunately a coworker had just swapped out a bed on his shorty and the floor was in good shape where mine was shot. So I cut his up to repair mine. The center of my bed is double floor so to speak.
[Re: redraptor]
#3095698
11/20/22 09:03 AM
11/20/22 09:03 AM
redraptor
Greenville, PA
Once I got all the patch panels on I sprayed bedliner over it. I could't get the texture I wanted so I had to get a heavy nap roller and go over it. And i can't make this image right side up for some reason.
[Re: redraptor]
#3095701
11/20/22 09:22 AM
11/20/22 09:22 AM
redraptor
Greenville, PA
Got the pump and reservoir mounted. I also reinforced the frame rails on both sides in this area. I made a crossmember for the lift cylinder. I would have like to have moved it farther forward but the gas tank is in the way and I don't know of a smaller tank to fit a Gen 3.
[Re: redraptor]
#3095755
11/20/22 12:54 PM
11/20/22 12:54 PM
Posts: 737 Middle TN.
4x4 Roundup
Middle TN.
Looks great Be sure you have extra shovels and rakes when friends come over...
WANTED-- DEAD or ALIVE: '70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car. '79 Power Wagon W14JE9S137761 or 763
[Re: blaze]
#3106883
12/31/22 08:12 AM
12/31/22 08:12 AM
redraptor
Greenville, PA
Do you have any photos of the fuel filler tube? I do not. You can see the cap in a pic of the frame . I basically cut out the curve in the stock filler neck and welded it back together. It comes very close to the bed floor.
[Re: blaze]
#3106884
12/31/22 08:18 AM
12/31/22 08:18 AM
redraptor
Greenville, PA
I also wanted to tow occasionally so I modified the factory hitch to fit behind a rollpan and not interfere with bed or hinges.
