Re: 3" or 3.5" exh
[Re: Mally69]
#3095115
11/17/22 10:01 PM
11/17/22 10:01 PM
Posts: 40,823 Bend,OR USA
Cab_Burge
My old pump gas BB stroker motor in my street Duster ran 7;00 in the 1/8 mile locally with the 3.0 inch exhaust system on it, it had a set of MganFlow 14 inch oval x 7 .0inch high side inlet with center exit straight through pipes mounted behind the rear end between the rear subframes and the rear 1/4 panel. I remove the complete exhaust system, it had a set of Hedman fenderwell race headers on the 505 C.I. stroker motor with 3.0 inch pipes back to the muffs behind the rear end with the muffs exiting at the rear bumpers and it ran 6:98 in the 1/8 mile. Not enough gain for me to worry about. I thought it was probably the loss of weight that affected the ET and MPH  It would run 9.993 in the 1/4 mile at 134.6 mph corked up with the air cleaner on weighing 3450 Lb. with me in it running on 91 octane non ethanol Oregon swill  it was a real hoot to drive on the street and sometimes at the track
Re: 3" or 3.5" exh
[Re: Sunroofcuda]
#3095126
11/17/22 10:40 PM
11/17/22 10:40 PM
Posts: 92 PA
Mally69
PA
Whats ur mufflers?? Have any vids?? Im curious what you have. Im kinda fussy about exhaust sound. I like more of a deep roar or even the scream of the X-pipe. I try to avoid anything that will make the exhaust cackle on acceleration.
Re: 3" or 3.5" exh
[Re: Mally69]
#3095137
11/18/22 12:18 AM
11/18/22 12:18 AM
Posts: 589 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Once that exh gases cool around the rear end, you can decrease the size of the tailpipes with little effect on HP. It will also quieten the car some and the further rearwards and the bigger the mufflers are the quieter it will be as well. My 572 Hemi, runs 3.5" collector into a 3.5" in/out X pipe, after the X it tapers nicely to 3" at the rear end and 3" out the back with into large case 3" Magnaflows at the very rear of the car. Fuel tank is in the trunk so have the space. Car is pretty quiet with 11:1 CR and over .700" lift roller.
Re: 3" or 3.5" exh
[Re: Mally69]
#3095227
11/18/22 01:10 PM
11/18/22 01:10 PM
Cab_Burge
I think that motor, it was a longtime ago that I built and dyno that motor (it made 727 HP in Klamath Falls, OR at 4300 Ft above sea level) that 9.99 run was with a set of CNC ported 440-1 heads with an Indy 400-3 intake with Wilson 2.0 inch tall anti reversion space with a stock Holley 9375 non HP 1050 CFM Dominator. That car and motor exceeded my wildest hopes regularly
Re: 3" or 3.5" exh
[Re: Cab_Burge]
#3095239
11/18/22 01:28 PM
11/18/22 01:28 PM
Posts: 4,154 Wichita
GY3
Wichita
We've been 10.01 @ 133 mph at 3,700 lbs. with 3" exhaust.
Dynomax Ultraflow mufflers.
Re: 3" or 3.5" exh
[Re: Mally69]
#3095287
11/18/22 04:00 PM
11/18/22 04:00 PM
Posts: 17,225 north of coder
moparx
on my charger, i'm going 3 1/2 into a 3" xpipe, then couple to the existing 3" over the axle pipe, 3" rearward from there into a race bullet of some kind, then a fabricated [by me] turndown 6" or so, wide. if i don't like the sound, i will install something where the factory mufflers were [possibly another race bullet ?]. after it's all done, i'll send the total system out for coating. and believe it or not, i have run a strait 4" pipe [adapted from the 3" over the axle pipe] to the bumper along side of the factory gas tank. it fit fine with no clearance issues.
Re: 3" or 3.5" exh
[Re: moparx]
#3095300
11/18/22 04:47 PM
11/18/22 04:47 PM
Posts: 92 PA
Mally69
PA
on my charger, i'm going 3 1/2 into a 3" xpipe, then couple to the existing 3" over the axle pipe, 3" rearward from there into a race bullet of some kind, then a fabricated [by me] turndown 6" or so, wide. if i don't like the sound, i will install something where the factory mufflers were [possibly another race bullet ?]. after it's all done, i'll send the total system out for coating. and believe it or not, i have run a strait 4" pipe [adapted from the 3" over the axle pipe] to the bumper along side of the factory gas tank. it fit fine with no clearance issues. When will u have this done? Ill come over and check it out
Re: 3" or 3.5" exh
[Re: Mally69]
#3095380
11/18/22 09:56 PM
11/18/22 09:56 PM
Posts: 8,174 Highland, MI.
Sunroofcuda
Highland, MI.
Whats ur mufflers?? Have any vids?? Im curious what you have. Im kinda fussy about exhaust sound. I like more of a deep roar or even the scream of the X-pipe. I try to avoid anything that will make the exhaust cackle on acceleration. www.classicchambered.com . Or, search YouTube for many videos my customers post. If you go to my website, go to the "Sights & Sounds" page & enjoy.
Re: 3" or 3.5" exh
[Re: Sunroofcuda]
#3095476
11/19/22 11:21 AM
11/19/22 11:21 AM
Posts: 4,094 Motor City
6PKRTSE
Motor City
I have 3" on two cars. One dumped at the axle on the Roached Runner and one all the way back to the stock tips on the red Charger. I have 3-1/2" on my Challenger with bullet mufflers. It is load is and understatement....
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: 3" or 3.5" exh
[Re: 6PKRTSE]
#3095478
11/19/22 11:25 AM
11/19/22 11:25 AM
Posts: 92 PA
Mally69
PA
I have 3" on two cars. One dumped at the axle on the Roached Runner and one all the way back to the stock tips on the red Charger. I have 3-1/2" on my Challenger with bullet mufflers. It is load is and understatement.... Any sound clips or videos of the 3.5. And is the 3.5 worth the effort over 3inch @ roughly 700ish hp?
Re: 3" or 3.5" exh
[Re: Mally69]
#3095481
11/19/22 11:29 AM
11/19/22 11:29 AM
6PKRTSE
Motor City
I have 3" on two cars. One dumped at the axle on the Roached Runner and one all the way back to the stock tips on the red Charger. I have 3-1/2" on my Challenger with bullet mufflers. It is load is and understatement.... Any sound clips or videos of the 3.5. And is the 3.5 worth the effort over 3inch @ roughly 700ish hp? No, I don't have any sound clips that I get to post on here. At 700 I would say yes. You would want to go up to 3-1/2".
Re: 3" or 3.5" exh
[Re: 6PKRTSE]
#3095522
11/19/22 01:26 PM
11/19/22 01:26 PM
Posts: 92 PA
Mally69
PA
I have 3" on two cars. One dumped at the axle on the Roached Runner and one all the way back to the stock tips on the red Charger. I have 3-1/2" on my Challenger with bullet mufflers. It is load is and understatement.... Any sound clips or videos of the 3.5. And is the 3.5 worth the effort over 3inch @ roughly 700ish hp? No, I don't have any sound clips that I get to post on here. At 700 I would say yes. You would want to go up to 3-1/2". Sweet, so 3.5 through x pipe and then the tail pipes out the back with mufflers are ok to be 3inch? Or best to make it 3.5 the whole way out?
Re: 3" or 3.5" exh
[Re: Mally69]
#3095540
11/19/22 01:57 PM
11/19/22 01:57 PM
moparx
one thing to remember, the farther away from the head port, the colder the exhaust gasses are, and the slower they become. that's why a smaller tail pipe works. it has a tendency to keep the gas flow up. however, i have no idea how much hp my engine will make, maybe 475 ?  above a certain hp amount, you need to keep pipe size constant. let me know when you want to come over and bs.
Re: 3" or 3.5" exh
[Re: 6PKRTSE]
#3095552
11/19/22 02:35 PM
11/19/22 02:35 PM
Cab_Burge
My old pump gas 517 C.I. Street motor made 727 HP at 4300 Ft. in Klamath Falls Oregon on a fairly new, less than one year old, DTS engine. I posted on how that motor responded to removing the 3.0 inch stem from the car at the track, .02 ET and .2 MPH in the 1/8 mile gain with it off. My message is I really don't think switching from a 3.0 inch system to a 3.5 inch exhaust system will make a noticeable gain on the street or at the track: work:
Re: 3" or 3.5" exh
[Re: Cab_Burge]
#3095783
11/20/22 01:13 PM
11/20/22 01:13 PM
moparx
i remember that Cab. i think you figured the gain was just the removal of the weight of the pipes. now with that said, every 2" header i have seen has a very short collector. would any low rpm gain be seen by adding an extension, say 12-18" of 3 1/2" [the collector size] before transitioning/reducing to 3" pipe ?
Re: 3" or 3.5" exh
[Re: moparx]
#3095803
11/20/22 02:09 PM
11/20/22 02:09 PM
Cab_Burge
Every BB and 426 Street Hemi car I've raced with 727 and 833 NP 4 speed liked the 3.5 inch collector extensions  I would start with the 18 inch long extensions usually and never trim them any shorter  I did try a set of 3.5x 12 inch long extension on my old M.W. stocker and I can't remember now if they were faster or slower than the 18 inch ones were: confused:
