Stupid question, how much tranny fluid #3095058
11/17/22 06:44 PM
11/17/22 06:44 PM
BDW Offline OP
BDW  Offline OP
So it looks like my transmission needs to come out for a rebuild.
I'd like to put it up on my Kwik Lift to make it easy.
Unfortunately I discovered the problem by draining the fluid and seeing the mess in the pan.
So that's the background, now for the stupid question.
What's the minimum fluid needed to drive the car on the lift, without causing further damage?
Trying to eliminate dumping $100 worth of fluid back in it, only to be thrown away.
Re: Stupid question, how much tranny fluid [Re: BDW] #3095061
11/17/22 06:59 PM
11/17/22 06:59 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Per my '80 FSM for 727 transmission:
7.3 pints in transmission
8.6 pints in converter
...and in your case why not just get the cheapest Walmart mix?
Re: Stupid question, how much tranny fluid [Re: Diplomat360] #3095068
11/17/22 07:17 PM
11/17/22 07:17 PM
Guitar Jones Offline
Just pour in 4-6 quarts of the cheapest stuff you can find.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Stupid question, how much tranny fluid [Re: Guitar Jones] #3095070
11/17/22 07:29 PM
11/17/22 07:29 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
What kind of ramp is that?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Stupid question, how much tranny fluid [Re: 70sixpkrt] #3095076
11/17/22 08:03 PM
11/17/22 08:03 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Pull it on with a cable hand winch and don't look back.
Re: Stupid question, how much tranny fluid [Re: 6PakBee] #3095101
11/17/22 10:31 PM
11/17/22 10:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Also known as a Come along. Others available elsewhere, might even be able to rent one or similar at home depot etc.
shruggy
HF COME ALONG
Re: Stupid question, how much tranny fluid [Re: 70sixpkrt] #3095106
11/17/22 10:43 PM
11/17/22 10:43 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I don’t know, but I like it up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Stupid question, how much tranny fluid [Re: 70sixpkrt] #3095111
11/17/22 10:50 PM
11/17/22 10:50 PM
Looks like wood or some other man made composite material shruggy
Re: Stupid question, how much tranny fluid [Re: Guitar Jones] #3095113
11/17/22 10:58 PM
11/17/22 10:58 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
If it's going to get torn apart, rinsed, rebuilt, etc...I'd guess you could put any ole oil in there for long enough to get it up a ramp. Am I wrong???
Re: Stupid question, how much tranny fluid [Re: BloFish] #3095280
11/18/22 04:46 PM
11/18/22 04:46 PM
moparx Online content
moparx  Online Content
that is called a "Kwick Lift".
you drive up it like a big set of those common wheel ramps [that are everywhere], then use your floor jack to jack up the whole setup until you can lower the rear "piers" or stands, then lower your jack so the rear units support the whole setup.
this gives you about 18" or more height than the tires sitting on the ground would.
when you are done, lower the back, drive off, unpin the ramps from the front "piers", then set against the wall or just drive back on the ramps at floor level.
it's a pretty neat deal in my opinion, but it costs around $1300.00 or so new.
beer
Re: Stupid question, how much tranny fluid [Re: moparx] #3095469
11/19/22 12:07 PM
11/19/22 12:07 PM
BDW Offline OP
BDW  Offline OP
Thx for all the replies, I bit the bullet and dumped $70 worth of +4 in it, and was able to drive it. Little hairy lining it up and backing up the ramp.....................
Kwik Likft is nice, but heavy to move and put together, and you have to be able to get the car on it. I bought this used for $400 when I did the initial 518 install.
I thought about the come-along, but would need some sort of cross bar at the back, then wrap all the way around and pull cable underneath to front, and then have something in front to attach to, a disaster in the making for me.
Now I can take my time and get the trans out, and go from there.
The thing that really sucks, was this trans was sitting there for a year while waiting for parts and getting the new motor installed.
Literally drove the car 4 times with new motor, and it feels strong, now I have to pull the trans and probably spend another $2k to get going again.................
