big block a-100 #3094569
11/16/22 06:17 AM
11/16/22 06:17 AM
st.louis,mo.
dart games Offline OP
st.louis,mo.
i have a 1964 a-100.curently a small block thats junk.has anyone put a big block in a a100
Re: big block a-100 [Re: dart games] #3094781
11/16/22 06:27 PM
11/16/22 06:27 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Not personally but I have seen a few with big block swaps Steve Scott from the old Yahoo A100 group had a 383 powered van he raced & a friend of my neighbor built one with a 440.You most likely will have to trim some floor to fit and modify the doghouse.I have a '67 A100 van with a 318&3.91 axle,and considering a G3 Hemi swap for it.What trans and axle are in your truck? I saw your truck in the pics thread,nice looking machine.
RT
Re: big block a-100 [Re: RTSrunner] #3094826
11/16/22 10:42 PM
11/16/22 10:42 PM
st.louis,mo.
st.louis,mo.
rtsrunner.its a 360.has coolant coming out the exhaust.someone tried to bandaid it wit rebuilt heads.engine is junk.few years back on ebay.seen a a100 van with 2 440s in it.should of got it
Re: big block a-100 [Re: dart games] #3094920
11/17/22 11:36 AM
11/17/22 11:36 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I know of one guy that did..... biggrin
1981 Dodge D150 360 auto
Re: big block a-100 [Re: basketcase] #3094941
11/17/22 12:17 PM
11/17/22 12:17 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I seriously thought about it, but in the end decided to stay with the small block. Less hassles.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: big block a-100 [Re: BloFish] #3094945
11/17/22 12:27 PM
11/17/22 12:27 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Build a small block 408 stroker and save a lot of fabbing issues.
Re: big block a-100 [Re: stumpy] #3095091
11/17/22 09:26 PM
11/17/22 09:26 PM
st.louis,mo.
st.louis,mo.
stumpy.yea i was thinking about a 408
Re: big block a-100 [Re: stumpy] #3095164
11/18/22 09:48 AM
11/18/22 09:48 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I'll add one thing here. Consider a stroking a late model 5.2 or 5.9 Magnum even, which you can still find in salvage yard but, getting a slim at least around here.
Re: big block a-100 [Re: OrangeProwler] #3095257
11/18/22 03:26 PM
11/18/22 03:26 PM
moparx Offline
moparx  Offline
there was a 1965 or 66 A100 pickup up on one of those used car lot "angle iron" ramps many, many [and many more] years ago on the way to work.
i stopped to look, and it had a poly 318/727 combo.
first thing i thought of was a big block swap.
after doing some measuring, i came to the conclusion, a 383 [or 400] would fit great, requiring only motor mount biscuits and swapping the transmission guts into a big block case. [it had a shorty tail shaft and a sliding yoke like a 4 wheel drive would have]
i can't remember what the asking price was, but the body was pretty sound, while the interior was bare with ratty seat covers.
one of those things one wishes he would have bought, but on the other hand, i can't seem to finish what projects i have as it is. laugh2
beer
Re: big block a-100 [Re: moparx] #3095419
11/19/22 06:51 AM
11/19/22 06:51 AM
st.louis,mo.
st.louis,mo.
moparx.your on the right track.i contacted a guy on facebook that put a big block in.he used a 400 because its smaller.he used a powerglide because its shorter.early b body motor mounts.and a body chassis headers.anything can be done.he said the engine comes in and out on the passenger side.its a project im kicking around
279082574_5119000731472186_4979818259623651432_n.jpg279123877_5119001374805455_6316517678355003969_n.jpg62377920_2326598907379063_3467811304083816448_n.jpg
Re: big block a-100 [Re: dart games] #3095504
11/19/22 01:32 PM
11/19/22 01:32 PM
moparx Offline
moparx  Offline
i'll bet that truck is a lot of fun ! boogie
thanks for posting those pictures !
beer
Re: big block a-100 [Re: dart games] #3102752
12/16/22 01:05 AM
12/16/22 01:05 AM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
Been there, done that.. 470/727/dana
It’s a tight fit…kinda noisy too😃😃😃
Re: big block a-100 [Re: moparlulu] #3103374
12/18/22 05:07 PM
12/18/22 05:07 PM
st.louis,mo.
st.louis,mo.
mopar lulu.what motor mounts did you use.what heads are those.i wont do mine till next year.but looking at how people did theres.what trans are you using .are you using a 727 out of a rv with short tail shaft
Re: big block a-100 [Re: dart games] #3104165
12/21/22 01:05 AM
12/21/22 01:05 AM
moparlulu Offline
moparlulu  Offline
I made the motor mounts on the engine. Mounts off the frame are small block came with the truck, solid mount on the drivers side, stock rubber on the passenger. Heads are 270 trick-flow, trans is a standard length 727, just a REALLY short drive shaft!
Re: big block a-100 [Re: moparlulu] #3104429
12/22/22 06:03 AM
12/22/22 06:03 AM
st.louis,mo.
st.louis,mo.
thanks moparlulu
Re: big block a-100 [Re: dart games] #3105170
12/24/22 11:26 AM
12/24/22 11:26 AM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
Did you have any cooling issues with the big block? I have an A100 going together (I'm in Az) and I am worried that this cooling system will have a hard time with a decent small block.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: big block a-100 [Re: Jambbii] #3105195
12/24/22 12:30 PM
12/24/22 12:30 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Looks pretty straight forward...
Kevin
Re: big block a-100 [Re: Twostick] #3105281
12/24/22 04:48 PM
12/24/22 04:48 PM
st.louis,mo.
st.louis,mo.
two stick is that your truck with a hemi
Re: big block a-100 [Re: dart games] #3105392
12/25/22 10:26 AM
12/25/22 10:26 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I wish. Lol. It was at Moparfest years ago. There are usually several really nice A100s there and most of them were built and sold by the guy that built this one. Magazine pretty in every respect.
Kevin
Re: big block a-100 [Re: Twostick] #3105514
12/25/22 05:44 PM
12/25/22 05:44 PM
st.louis,mo.
st.louis,mo.
two stick.wish i can go to those shows to see trucks like that.very cool
