Re: Concreted in Aluminum Indy blocks.
[Re: birdtracker]
#3095341
11/18/22 07:30 PM
11/18/22 07:30 PM
Posts: 4,169 Mo.
racerx
Mo.
for my use I wish I could of got a filled block. I found this water block and after 3 different pressure tests and having the sleeves installed, cam bearings, line bored, finished honed and then assembled found out it leaked coolant into the oil. So then after another 6 month go around of trying sealers and changing the oil and cleaning out valve covers, oil, pan and filter, I decided to fill it to the bottom of the water pump opening. No coolant, just a oil heater in the oil pan to warm it up before running. I made 3 back to back to back 1/4 mile passes and oil temps never got over 190 degrees. So the answer to why fill an aluminum block is how deep are you into it. Some day if I have to take a cylinder head off I will look and see how it lasted.Birdtracker Interesting here what fuel do you run and was this block ever see street time?
[Re: birdtracker]
#3095526
11/19/22 01:32 PM
11/19/22 01:32 PM
Posts: 4,169 Mo.
racerx
Mo.
I had an iron block 440 that was filled to the top of the freeze plugs that I drove on the street thousands of miles with no heat related problems. With all the aluminum blocks out there I can't see an issue with a 1/2 fill and running it . Birdtracker Birdtracker.....with the thermal expansion of aluminum block and concrete, have you notice any issues with the concrete separating inside or around the cylinders or for that question anyone have experience this?
