Re: torque specs for BMP aluminum block
[Re: mopar dave]
#3094639
11/16/22 11:56 AM
11/16/22 11:56 AM
Posts: 18,792 Las Vegas
Al_Alguire
Las Vegas
Block torque specs are here. You should have gotten an instruction sheet with it as well. And yes you should torque ALL the fasteners when checking clearance, runout etc. https://billmitchellproducts.com/tech/
[Re: RATTRAP]
#3094915
11/17/22 10:21 AM
11/17/22 10:21 AM
Posts: 16,790 Western NC
440Jim
Western NC
I read the torque spec's in the PDF and has the mains being torqued to 100 FT Lbs. & the side bolts torqued to 45 FT Lbs. My KB blocked is stamped to torque the mains to 120 FT Lbs. & 80 FT Lbs. on the side bolts Different block, different fasteners, etc. For example, the side bolts on the BMP block are 3/8" dia. And the block should be machined at the same specs it is assembled at.
[Re: Dragula]
#3094971
11/17/22 12:30 PM
11/17/22 12:30 PM
Posts: 1,940 Byron, NY
W.I.N. Racing
Byron, NY
Follow the directions for the block you have...
'02 D1500, Blown/Inj BAE, Veny Heads,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
