Aluminum block #3094558
11/16/22 02:18 AM
11/16/22 02:18 AM
Kansas
Thelma133 Offline OP
Kansas
How do you gents with aluminum blocks, with no petcocks, remove water from it for the winter??
Re: Aluminum block [Re: Thelma133] #3094567
11/16/22 05:49 AM
11/16/22 05:49 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I would drain the water from the radiator re-fill with antifreeze, run the block to temp and store for the winter, flush it in the spring.
Re: Aluminum block [Re: RATTRAP] #3094572
11/16/22 07:25 AM
11/16/22 07:25 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Drill and tap a hole in the side of the block, and install a petcock.
My aluminum INDY block is half filled with Rock Block, and a hole was drilled at the top of the fill.
But as RATTRAP has said, just drain the radiator, and fill with antifreeze, and run the water pump to circulate.
69 GTX 68 Road Runner
Re: Aluminum block [Re: JERICOGTX] #3094575
11/16/22 08:07 AM
11/16/22 08:07 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You can also blow compressed air in the upper hose and it will blow it out the lower. It would remove enough to not worry about freezing but won't get all of it.
68 Barracuda Formula S 340
Re: Aluminum block [Re: Thelma133] #3094699
11/16/22 02:29 PM
11/16/22 02:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
easy live somewhere warmer laugh2
Re: Aluminum block [Re: RATTRAP] #3094916
11/17/22 11:25 AM
11/17/22 11:25 AM
NC
440Jim Offline
440Jim  Offline
NC
I agree. With the water pump running, it will mix the new antifreeze and the left over water in the block. So don't use that premixed antifreeze.
Re: Aluminum block [Re: JERICOGTX] #3094970
11/17/22 01:28 PM
11/17/22 01:28 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
1) iagree
2) as Al stated move some where warmer
c) dont use coolannt - thats how I do it.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Aluminum block [Re: Thelma133] #3095465
11/19/22 11:50 AM
11/19/22 11:50 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I use a brake vacuum pump or the same tube with wire bent as a hook with the tube taped to it and syphon the liquid out.I was doing this with a Koleno block for the past 15yrs.
Re: Aluminum block [Re: Clanton] #3095487
11/19/22 12:36 PM
11/19/22 12:36 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I just winterized mine for the winter even though I have a heated garage. I do it every winter just in case my furnace were to break. I just drain most of the water and top off with antifreeze and fire it up until warm and circulating. Then drain it all in the spring again.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Aluminum block [Re: 6PKRTSE] #3095532
11/19/22 02:42 PM
11/19/22 02:42 PM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^ This is kind of what i do but my garage doesn't have control heat, but it's insulated and i just run 50/50 mix. but i do have a cast iron block tho. i have a thermometer on my bench with a 12 oz bottle of water that never freezes. twocents
Re: Aluminum block [Re: Thelma133] #3095556
11/19/22 03:42 PM
11/19/22 03:42 PM
I think every aluminum block with coolant passages need to have non corrosive coolant in them year around twocents work
Re: Aluminum block [Re: Cab_Burge] #3095561
11/19/22 03:56 PM
11/19/22 03:56 PM
moparx Offline
moparx  Offline
maybe not necessarily coolant, but some kind of additive to prevent corrosion due to electrolysis.
maybe one of those anodes attached to a radiator cap ? shruggy
beer
Re: Aluminum block [Re: moparx] #3095723
11/20/22 10:52 AM
11/20/22 10:52 AM
PA
moparacer Offline
moparacer  Offline
PA
Mine gets antifreeze no matter what....Being in the radiator business for 35 years, I have seen what a little water in the right spot can do if it freezes.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Aluminum block [Re: moparacer] #3095745
11/20/22 12:15 PM
11/20/22 12:15 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Zero experience with filled blocks. I can say, from experience, that water comes out of both sides of the drained block. No way would I trust draining only one side. I run softened water with water pump lube during the race season, and softened water and coolant, mixed 50-50. I then check for -25 -30 fahrenheit. This is an iron R1 block.
Re: Aluminum block [Re: moparacer] #3095811
11/20/22 03:22 PM
11/20/22 03:22 PM
moparx Offline
moparx  Offline
i absolutely agree, especially if even there is a TINY chance a temperature MAY dip below freezing.
beer
