Do big(ger) strokes exacerbate the stock block problems?
#3094291
11/15/22 09:23 AM
11/15/22 09:23 AM
Posts: 1,060 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Wondering if stroker engines are more likely to break a stock RB block than stock-stroke builds. "Hypothetically"... is a 512 build making 700 HP and 650 torque limited to 6500 RPM more or less likely to break the same block than a 451 build making 700 HP and 600 torque limited to 7000 RPM? Or, to put it a different way, what is the general consensus -- if such a thing exists -- on what increases the likelihood of a stock block experiencing main webbing damage? - RPM? - Torque? - HP? - Detonation? - High(er) compression? - Piston speed? - Curses by gypsies? - All, or some specific combination, of the above?
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Do big(ger) strokes exacerbate the stock block problems?
[Re: Brad_Haak]
#3094293
11/15/22 09:41 AM
11/15/22 09:41 AM
Posts: 12,378 Taxes & Virus's R-US, NY
Dragula
Just tore down our oldest 512RB. We have been racing one for 15 years, and we just pulled it apart, the hone was gone, and a valve lock/keeper was broken, and it was about to drop a valve....No other issues we could find. Everything else was really good....So no, I don't think so. Last pass on that engine at the end of the season was 10.76 at 125mph....
The motor was always well tuned, and rpm generally kept in the safe zone....But we ran a lot of timing, and a 1050 on her, so it saw a lot of fuel and was generally shifted between 6k-6.5k....Super consistent round to round, and just a beast. Quickest pass on it was 9.70 at 138.5mph...
[Re: Dragula]
#3094298
11/15/22 09:58 AM
11/15/22 09:58 AM
Brad_Haak
Loudoun County, VA
One of the things that got me wondering about this is a guy I know who ran a 4.15" stroker RB combo that ran in the same mid-10s range as my car did at the time. He said he loved the engine, but started hurting main bearings after switching to the bigger engine combo. As far as I know, he didn't have anything but main studs w/ a stock block and a Milodon deep pan... no idea if he did other oiling mods. But him not having bearing issues until going to the bigger crank seemed odd. AFAIK, he could have been running wrong bearing clearances, but you'd *think* he'd have addressed that if it was an issue.
[Re: Brad_Haak]
#3094307
11/15/22 10:33 AM
11/15/22 10:33 AM
Posts: 4,641 Wichita
GY3
Wichita
My 4.25 stroke RB has been together since 2016 and it sees hard street miles (over 7,000) and lots of passes at the dragstrip. I doubt many people out there hammer their stuff like I do on a regular basis. It sees the dragstrip almost every weekend in the Summer.
It makes 600 n/a and we have sprayed it with 100 shot all the way up to 250 shots of nitrous to it in the last couple of seasons. I've probably put a dozen 10 lbs. bottles through it.
I was concerned last Winter about what the bottom end would look like so I pulled it out and did a wellness check.
Honestly, the rod bearings looked good enough that I could have re-used them but put new ones in anyway. Mains looked good so they stayed. Stock mains and ARP studs. No oiling mods! It does have a balance job on it by a very good local shop.
It has a Molnar crank, 7.1" rods and Mahle pistons, so it makes for a pretty lightweight rotating assembly. This combined with the rev limiter at 6500 (and almost never bouncing off of it) and being conservative with timing is, IMO, what keeps it alive.
[Re: jwb123]
#3094322
11/15/22 11:30 AM
11/15/22 11:30 AM
Brad_Haak
Loudoun County, VA
jwb123 - What are the bore / stroke / rod length for each combination? I'll take a s.w.a.g. the 500 was 4.380", 4.15" and 6.76"...
[Re: Brad_Haak]
#3094333
11/15/22 12:21 PM
11/15/22 12:21 PM
Posts: 5,155 CT
GTX MATT
CT
I think detonation kills them, and all of the things to turn them into “torque motors” increase detonation. Detonation starts long before its audible. I think the idea that RPM will break the block is a myth (like losing torque with bigger ports) and sends people in all of the wrong directions. Peak torque is peak VE and thats where detonation is most likely.
Also, people like flat timing curves and the engines pick up power at 36-40 degrees so people run them there even though they lose peak torque. How many dyno sheets have you seen where they run a timing sweep and 33-34 makes the most torque but 36-40 makes the most horsepower?
Its apples to oranges, but look inside the bottom end of a Mitsu 4G63, regarded by many as one of the greatest engines of all time and 1000 HP capable, and tell me if it looks familiar. But they do also have much less swinging mass as well.
I believe there was a member on here making north of 1000 HP with a turbo on a stock block with a knock sensor.
[Re: GTX MATT]
#3094345
11/15/22 12:43 PM
11/15/22 12:43 PM
Posts: 698 Lake Villa Il
INTMD8
Lake Villa Il
GTX MATT- Good post. Also makes me cringe when I see timing full in 30+deg at very low rpm.
I always run less timing at peak torque (of course a bit more difficult with a distributor)
[Re: GTX MATT]
#3094348
11/15/22 12:52 PM
11/15/22 12:52 PM
GY3
Wichita
It's hard to find people that push stock blocks or maybe it's just hard to find people that are willing to talk about it? There have been a few on here like MoparBilly. There are, however, lots of people with little to no experience (more so on Facebook than here) that are more than willing to regurgitate a number they've heard on what one will hold. I've heard 600, 700, 750, etc.
[Re: jwb123]
#3094361
11/15/22 01:24 PM
11/15/22 01:24 PM
Posts: 4,205 New York
polyspheric
New York
better rod stroke ratio and therefore less piston speed Piston speed is a direct function of stroke length, rod ratio not a factor: Stroke X RPM / 6 gives speed in feet per minute
Piston acceleration includes rod ratio: Where Z = acceleration in feet per second per second N = RPM S = stroke in inches n = rod to stroke ratio Z = N^2*S*(1+(1/2n))÷2189
Boffin Emeritus
[Re: GY3]
#3094434
11/15/22 05:27 PM
11/15/22 05:27 PM
Posts: 710 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
It's hard to find people that push stock blocks or maybe it's just hard to find people that are willing to talk about it? There have been a few on here like MoparBilly. There are, however, lots of people with little to no experience (more so on Facebook than here) that are more than willing to regurgitate a number they've heard on what one will hold. I've heard 600, 700, 750, etc. I run this same 400 based 512 block and stroke since 11 Joe
Without Data, you’re just another guy with an opinion.
[Re: fbs63]
#3094441
11/15/22 06:08 PM
11/15/22 06:08 PM
polyspheric
New York
I agree, not only does a small rod ratio push the piston against the wall (more strongly than a higher ratio), but also pushes the crank in the mains in the opposite direction.
Boffin Emeritus
[Re: GY3]
#3094449
11/15/22 07:13 PM
11/15/22 07:13 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
It's hard to find people that push stock blocks or maybe it's just hard to find people that are willing to talk about it? There have been a few on here like MoparBilly. There are, however, lots of people with little to no experience (more so on Facebook than here) that are more than willing to regurgitate a number they've heard on what one will hold. I've heard 600, 700, 750, etc. That would be me. People taking it farther than I have like that orange procharged challenger with a 383, or the totally home built avenger with a turbo. I preached the importance of ignition timing and benefits of distributorless programmable ignition for years on this board to be ridiculed and doubted by the vast majority of users on this board. Now 15 years later, it has become acceptable here to embrace technology that has been available for years. It was explained to me years ago by Kenny D that it’s real easy to keep an engine alive if you time it to keep the crank rolling forward instead of pushing it down. This is an easy rule to follow with a turbocharged engine. There is no need to maximize timing to make power. All you need to do is turn up the boost. The weak link in my situation (400block/ 3.90 stroke 7000-7200 rpm shift) was the cylinder bores. They were shaped like beer kegs after years of making more power than I was told was possible. Still made good reliable power, but it ate rings every season.
[Re: TRENDZ]
#3094456
11/15/22 07:33 PM
11/15/22 07:33 PM
Brad_Haak
Loudoun County, VA
Decided to check out the price of aftermarket blocks as a tangent to this topic: https://billmitchellproducts.com/product-category/engine-blocks/mopar-big-block-2/OK, anybody else surprised that the Mopar / Callies cast iron blocks are $400 more than the BMP aluminum blocks? And that's for about 170 lbs more weight, too.
[Re: GY3]
#3094467
11/15/22 08:00 PM
11/15/22 08:00 PM
Posts: 20,111 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It's hard to find people that push stock blocks or maybe it's just hard to find people that are willing to talk about it? There have been a few on here like MoparBilly. There are, however, lots of people with little to no experience (more so on Facebook than here) that are more than willing to regurgitate a number they've heard on what one will hold. I've heard 600, 700, 750, etc. I ran 275 quarter mile 8.60@155mph passes with a stock block and 500 cubic inch 440source assembly but I was only 2500-2600 pounds. When I tore it down for rebuild I found a crack. That would be a lot of years for most on here. I feel my biggest mistake on that engine was using 440source steel caps.
[Re: pittsburghracer]
#3094474
11/15/22 08:31 PM
11/15/22 08:31 PM
Brad_Haak
Loudoun County, VA
Were thinking in retrospect that aluminum caps would have been a better choice?
[Re: Brad_Haak]
#3094475
11/15/22 08:35 PM
11/15/22 08:35 PM
Posts: 20,111 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Were thinking in retrospect that aluminum caps would have been a better choice? That’s my thinking now too but I’ll never go down the stock block road again. Heck I have a keith black sitting here for 12 years doing nothing and sold a mega block and assembly last year
