starter for 71 Dart with 440 #3092787
11/09/22 10:34 AM
11/09/22 10:34 AM
alabama, usa
burks340 Online content OP
burks340  Online Content OP
alabama, usa
does anyone know what starter that will work on my 71 dart 440 engine indy ez heads old cppa 2'' headers i have a 90 model dakota starter and the header hits at very bottom across the elecrical wire of starter .it likes 1'' bolting up to head . all info appreciated.
Last edited by not_a_charger; 11/09/22 12:46 PM. Reason: I edited the title to get more responses
Re: hi [Re: burks340] #3092807
11/09/22 11:19 AM
11/09/22 11:19 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think MSD or RobbMC will have a starter that might clear. twocents
Re: hi [Re: bobby66] #3092894
11/09/22 04:19 PM
11/09/22 04:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Either the above, or a clockable starter, or one of those terminal relocation kits should work.
Re: starter for 71 Dart with 440 [Re: burks340] #3092990
11/09/22 10:54 PM
11/09/22 10:54 PM
Did you remove the plastic wire relocater bracket? If not try that and hook both starter wires up directly to the starter terminals scope up twocents
Re: starter for 71 Dart with 440 [Re: Cab_Burge] #3093005
11/10/22 12:06 AM
11/10/22 12:06 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Agree it worked on my 440 with headers.
Re: starter for 71 Dart with 440 [Re: Dabee] #3093148
11/10/22 01:48 PM
11/10/22 01:48 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Yep! Did that on my low deck w/Edelbrock heads and 1 7/8 CPPA headers.
Re: starter for 71 Dart with 440 [Re: Dcuda69] #3093271
11/10/22 10:00 PM
11/10/22 10:00 PM
alabama, usa
alabama, usa
its a denso starter
Re: starter for 71 Dart with 440 [Re: burks340] #3094021
11/13/22 08:53 PM
11/13/22 08:53 PM
st louis MO
beeliever Offline
beeliever  Offline
st louis MO
part # 17010 and 17181 are both nippondenso style starters BUT 17181 is the smallest and you will have to remove the battery cable plastic adapter
Re: starter for 71 Dart with 440 [Re: beeliever] #3094040
11/13/22 10:16 PM
11/13/22 10:16 PM
alabama, usa
alabama, usa
i havent made a purchase on a new starter yet. i have took some measurements i've only got 6'' from mounting surface on tranny to header the robbmc starter is 8'' .i have come to conclusion that thhe starter cant be much longer than 6'' and it needs to be clockable if its a little longer than 6'' i can ding the header. can some1 list some 6'' clockable starters the part #'s would be a big help
Re: starter for 71 Dart with 440 [Re: beeliever] #3094055
11/14/22 01:10 AM
11/14/22 01:10 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
99608 Remy was new and looked like the 17181 Denso. So was cheaper as no core charge since new.
I never tried to pull the plasic adapter off yet just got it.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: starter for 71 Dart with 440 [Re: 340SIX] #3094122
11/14/22 12:52 PM
11/14/22 12:52 PM
moparx Offline
moparx  Offline
just a few days ago, someone said the smallest starter out there is for a 2005-2008 [or so] ram truck with a manual transmission.
the number i wrote down for this was 410-48238, from amazon.
how true this is, i don't know. just tossing this out there.
beer
Re: starter for 71 Dart with 440 [Re: moparx] #3095006
11/17/22 03:20 PM
11/17/22 03:20 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
beer
Hmm I see
https://www.amazon.com/2005-2008-56029274AA-M000T21271-M000T21271ZC-M000T21271ZCKD/dp/B01L2RTHX0
which also has the advantage of terminals on the rear of the solenoid, as compared to
https://www.rareelectrical.com/i-26...r-dodge-engines-383-400-413-426-440.html
Anyone guess if this 410-48238 will bolt onto a 1971 413? Is the nose right?
Re: starter for 71 Dart with 440 [Re: Ray S] #3095030
11/17/22 04:29 PM
11/17/22 04:29 PM
alabama, usa
alabama, usa
i just purchased a CVR starter#1338 its a 10 position clockable starter . gonna see if its gonna fit and clear my old cppa 2'' tube headers when i have time its definately smaller than the denso starter i had clearance issues with so yes the denso is for sale .
Re: starter for 71 Dart with 440 [Re: burks340] #3096396
11/22/22 08:06 PM
11/22/22 08:06 PM
alabama, usa
alabama, usa
i finally got the cvr starter i wrapped it with blue painters tape to keep it from getting scratched so i could send it back if it didnt clear the headers . had to clock it a few times to dial it in it clears the headers .i couldnt believe it fit but i definately got the headers bolted up .i bought these headers used and had them ceramic coated some1 cut the front tubes #1 and #2 off near the header collector and welded a tube for it to slide down in by doing that it made it a lot easier to get them up from underneath car. i had to remove steering colum to get #1 tube down into sleeve and on passenger side i cant use my mopar performance valve covers cuz it hit #2 tube so gonna run old stock valve covers with my indy ez1 heads . with my engine combo and gear if it will run 7.40 in the eighth i'll be satisfied and pleased. well gotta get back to turning some wrenches . thanks to every1 that replied to my post.
