Re: Converting to electric choke on Holley 750DP
[Re: 1972Rallye]
#3093595
11/12/22 12:09 AM
11/12/22 12:09 AM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
I would go ahead and drill it, you can always block it off if it doesn't work out.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: TJP]
#3093894
11/13/22 10:30 AM
11/13/22 10:30 AM
Posts: 1,964 Apollo, PA.
B1MAXX
Apollo, PA.
You got the wrong hole targeted its one of the lower plane ones and holley makes a a little spacer to bring it up the the housing height.
the one up and left from the one your looking at
[Re: B1MAXX]
#3093907
11/13/22 11:24 AM
11/13/22 11:24 AM
Guitar Jones
the one up and left from the one your looking at I was wondering about that but since I don't have one in my hand I wasn't sure.
[Re: B1MAXX]
#3093911
11/13/22 11:39 AM
11/13/22 11:39 AM
Posts: 15,291 Omaha Ne
TJP
Omaha Ne
the one up and left from the one your looking at Hmm, never seen a spacer But you may be right ? In the pictures provided it's hard to see which holes line up when the choke is mounted. FWIW: The hole with the brass restriction is the one that needs the manifold vacuum source.
[Re: TJP]
#3093915
11/13/22 11:45 AM
11/13/22 11:45 AM
B1MAXX
Apollo, PA.
the one up and left from the one your looking at Hmm, never seen a spacer But you may be right ? In the pictures provided it's hard to see which holes line up when the choke is mounted. FWIW: The hole with the brass restriction is the one that needs the manifold vacuum source. yes Ill look in a minute when I go out to the shop
[Re: B1MAXX]
#3093941
11/13/22 01:15 PM
11/13/22 01:15 PM
Posts: 837 Highland, Michigan
1972Rallye
Highland, Michigan
Ok I 'm going to delete my original post the original poster has the right hole...... the one I referenced is for the vacuum sec. on the main ody I checked that hole, that the original poster shows is drilled straight through to the center cavity. That's exactly what I needed to know. I wasn't sure if it connected the the lower hole in my second pic to form an L-shaped passage or went straight through to the center. Thanks!
[Re: 1972Rallye]
#3094033
11/13/22 09:44 PM
11/13/22 09:44 PM
TJP
Omaha Ne
Ok I 'm going to delete my original post the original poster has the right hole...... the one I referenced is for the vacuum sec. on the main ody I checked that hole, that the original poster shows is drilled straight through to the center cavity. That's exactly what I needed to know. I wasn't sure if it connected the the lower hole in my second pic to form an L-shaped passage or went straight through to the center. Thanks! L shaped as straight through would be above the throttle blades giving you "venturi" or ported vacuum versus manifold vacuum which is what is needed for the choke to function properly Don't forget the gasket ( usually cork) to seal that passage when mounting the assembly
