Forward Facing Hood Scoop……… #3093709
11/12/22 01:47 PM
11/12/22 01:47 PM
Heaven
EvilB1Dart Offline OP
Heaven
NO MONSTER SCOOPS!!!
Doing some changes to the car and thinking about a few options for a forward facing scoop. I’ve always been a cowl hood person because they look great on just about any car, make a car look more aggressive and work relatively well for the most part. Thinking about the following ideas:
1. New flat hood and forward facing scoop. I’ll have to find a nice one that isn’t HUGE to offset the balance/look of the car. Some of those scoops look ridiculous, especially on a smaller car LOL. I want the hood and scoop to be separate of each other.
2. Keep the cowl hood, cut it and incorporate a forward facing scoop. Hood would slide-on around the scoop. I’d rather they be separate and scoop/pan be 1-piece together sealing around the carb.
3. Keep the cowl hood, cut it and build or buy a pre-fabbed lexan scoop. I know of a few companies/shops that make them, and Mike at Comp Chassis builds quality ones as well. No mailbox sizes either LOL!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Forward Facing Hood Scoop……… [Re: EvilB1Dart] #3093715
11/12/22 02:02 PM
11/12/22 02:02 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Always liked the raised AAR style hood, just not 6 inches high like these. I'd go 3", basically a cowl with a mopar touch
Re: Forward Facing Hood Scoop……… [Re: EvilB1Dart] #3093723
11/12/22 02:45 PM
11/12/22 02:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Ken (strokerpost) had a small aero on his dart that looked good.
Re: Forward Facing Hood Scoop……… [Re: justinp61] #3093757
11/12/22 05:01 PM
11/12/22 05:01 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Wes , come on now . You know when you spray grin enough , a scoop don’t matter .
....BAD A$$ STREET CAR.....
Re: Forward Facing Hood Scoop……… [Re: n20mstr] #3093770
11/12/22 05:28 PM
11/12/22 05:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I made a Super Shaker for my Challenger.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Forward Facing Hood Scoop……… [Re: 6PKRTSE] #3093788
11/12/22 06:21 PM
11/12/22 06:21 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I had a few 6 pak scoops on my car, I made a taller version to allow for a taller induction, but I noticed that the mounting points were getting hammered & cracking the fiberglass, even with extra reinforcing underneath. At speeds of 145+mph, the wind was hard on that hood so I changed to a cowl. No more hood damage & we even gained 2mph & increased e.t by 0.02. I'm not going forward facing again.
Re: Forward Facing Hood Scoop……… [Re: rebel] #3093827
11/12/22 10:44 PM
11/12/22 10:44 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Option 1.
A nice NEW style scoop (pro stock style) that's separate from the flat hood. I hate the older style aero scoops as well as lexan lol...
Casey FJ
Re: Forward Facing Hood Scoop……… [Re: rebel] #3093834
11/12/22 11:14 PM
11/12/22 11:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That means it was working to good, catching too much air. I’m the opposite I think the cowl hoods look awful, brand X look. Make the hood bump then start opening the hole till ET falls off. Try to keep frontal area as small as possible. At 100 mph and above you’re pushing a 4x8 sheet of plywood. The old snorkel type worked very well
Re: Forward Facing Hood Scoop……… [Re: cudaman1969] #3093866
11/13/22 09:10 AM
11/13/22 09:10 AM
gregsdart Offline
gregsdart  Offline
So the question becomes what scoop has a properly sized opening, with the intake opening in clean, above the boundry layer air? Any Pro Stock designs point to a style that will fit your needs?
Re: Forward Facing Hood Scoop……… [Re: gregsdart] #3093869
11/13/22 09:42 AM
11/13/22 09:42 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We just switched to a flat hood and a Makrolon clear scoop. It's sealed, haven't really got any conclusive data so far to compare it to the suitcased sized unsealed 6 pak but so far it has just beat it on mph and ET. I was going to put a sensor in there to log and see how much pressure was it was building, currently running 140+ on a good day, when the 655 goes back in we're hoping to see nearer 150, as it should be 200hp more. You can barely see it from a distance.
Re: Forward Facing Hood Scoop……… [Re: rebel] #3093871
11/13/22 09:47 AM
11/13/22 09:47 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^This is what I'm experiencing right now been looking into cowl hoods but trying to find one that suits my liking is the issue. I'm not into the total brand loyal thing but like was said before 70 RR/GTX's came with cowls.^^^
Re: Forward Facing Hood Scoop……… [Re: EvilB1Dart] #3093874
11/13/22 09:53 AM
11/13/22 09:53 AM
New York
polyspheric Offline
polyspheric  Offline
New York
For those concerned with the frontal area of a forward scoop: the opening area varies inverse to the top speed (slower car = bigger scoop).
Bigger than you need just increases aero drag.
Boffin Emeritus
Re: Forward Facing Hood Scoop……… [Re: polyspheric] #3093933
11/13/22 12:49 PM
11/13/22 12:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Having dome all of the above I prefer a flat hood with a real scoop on it. I am hoping the new car will work with just the cowl it had when I got it but fear it wont and ill end up adding a scoop to the cowl.
Re: Forward Facing Hood Scoop……… [Re: Al_Alguire] #3093936
11/13/22 12:58 PM
11/13/22 12:58 PM
Chesterfield Twp. Mi.
John Burdine Offline
This is my favorite forward facing scoop. Could be trimmed down a bit lower.
Re: Forward Facing Hood Scoop……… [Re: John Burdine] #3093946
11/13/22 01:28 PM
11/13/22 01:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My Super Shaker clears my tunnel ram and two 1050's. The bubble still mounts to the engine and seals to the hood.
Re: Forward Facing Hood Scoop……… [Re: 6PKRTSE] #3093953
11/13/22 02:03 PM
11/13/22 02:03 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Mine has a small aero scoop. I like that you can se over it easily.
Re: Forward Facing Hood Scoop……… [Re: slantzilla] #3094098
11/14/22 10:05 AM
11/14/22 10:05 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have to believe unless the engine sets really high the lexan scoop would be the best. It's out of the boundry layer. Make it only as big as needed. As mentioned a fast car doesn't need much. It doesn't obstruct vision. As Casey and I can a test the scoops we are forced to use are huge air catchers. I've also tested sealed and unsealed. Sealed beyound the 1/8 is worth a fair amount on my car. About .05 and over 2 mph.
Doug
Re: Forward Facing Hood Scoop……… [Re: dvw] #3094099
11/14/22 10:12 AM
11/14/22 10:12 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Just came across a Virginia law from 1991 that says my scoop is illegal (too high). The way the law is written, even a stock T/A scoop probably wouldn't pass. If I "interpret" the law to how I think it was intended to apply, the T/A would pass... but the Drag Pak-ified scoop on my car now is still about 3/4" too high. whistling
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Forward Facing Hood Scoop……… [Re: EvilB1Dart] #3094124
11/14/22 01:05 PM
11/14/22 01:05 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Hey Wes! I kinda like the looks of the scoop you have, it's prob one of only a few that looks right IMO. Like Tony has mentioned (maybe others too?) you might not need another scoop for best performance. If there is about 3" above the carb, and the distance of the scoop to windshield is 'correct' all the foundations are there to make it work. I'd tape off the cowl, and put strings around the end of the scoop and video during some runs. That'll give you an idea if it's working! This all is assuming you have the underhood sealed from the carb all the way to the windshied gap. Get some laps in N/A and sort the car and it'll all come together.
Re: Forward Facing Hood Scoop……… [Re: HardcoreB] #3094214
11/14/22 08:29 PM
11/14/22 08:29 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Alan Jones
