Re: Roller cam and bronze distributor gear
[Re: Moparmaniacc]
#3094278
11/15/22 06:01 AM
11/15/22 06:01 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Don't use that stock intermediate shaft or a used gear of any type. As mentioned above, Hughes Engines sells the bronze gear and the melonized gear. With a new cam, I would use the melonized gear for longevity.
Make sure you use a distributor collar to limit the up and down movement of the gear. Left uncontrolled, the gear can move up and down too much, which really accelerates wear, especially on the bronze gear. Also check your intermediate shaft bushing for excessive play.
I have wondered if cryogenicly treating the bronze gear would be of any benefit, but have never tested that idea.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3094285
11/15/22 08:50 AM
11/15/22 08:50 AM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
That's such an unbelievable rookie mistake I would be woried what else that "builder" did.
[Re: Moparmaniacc]
#3094288
11/15/22 09:02 AM
11/15/22 09:02 AM
Posts: 1,117 Loudoun County, VA
Brad_Haak
Loudoun County, VA
OP - Who / where is this builder? I'm also located in Northern Virginia. Thx Also, I have a spare new 440 Source bronze gear on shaft , if you need one. However, I also recommend going w/ the Hughes (Crane) melonized gear, if they're still available.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3094294
11/15/22 09:49 AM
11/15/22 09:49 AM
Posts: 1,696 central il.
second 70
central il.
I remember when Chance (or Chase) still worked at Crane. He told me they never had any problems or failures using a stock gear on Mopar roller cams when used with a regular oil pump. Said it was only when you went up to HP or HV did it cause problems.
[Re: second 70]
#3094379
11/15/22 02:11 PM
11/15/22 02:11 PM
Posts: 381 Denver CO
bennydodge
Denver CO
I believe Crane used iron gears on many of the roller cams they made-pressed on I think?? This allowed the use of the stock intermediate shaft.
73 Challenger 340(416),E-heads, 727, 3.23 SG 2015 Challenger R/T classic B5, wife's car 2010 Ram 3500 Crew Cab SLT dually 4X4 2016 Challenger Hellcat Redline Red A8
[Re: bennydodge]
#3094385
11/15/22 02:36 PM
11/15/22 02:36 PM
Posts: 3,916 usa
lewtot184
usa
I believe Crane used iron gears on many of the roller cams they made-pressed on I think?? This allowed the use of the stock intermediate shaft. they did it on some chevy cams. not easy to do on mopar big block. there aren't any timing concerns when doing a pressed gear on a small block chevy. if the cam was ran with an iron gear for any length of time i'd yank the cam for full inspection. if the gear on the cam has any damage it will probably wreck a bronze gear.
[Re: lewtot184]
#3094504
11/15/22 09:59 PM
11/15/22 09:59 PM
bennydodge
Denver CO
When I looked many years ago all the crane hydraulic rollers for small block Mopars had iron gears. I can't speak to what they did on big block Mopars.
[Re: bennydodge]
#3094576
11/16/22 08:14 AM
11/16/22 08:14 AM
Posts: 6,220 nowhere
Sniper
nowhere
When I looked many years ago all the crane hydraulic rollers for small block Mopars had iron gears. I can't speak to what they did on big block Mopars. It's the gear and rear journal that is pressed on. Good luck finding one now.
