Going rate to recore a 26" HD Radiator ?
#3093728
11/12/22 02:59 PM
11/12/22 02:59 PM
Posts: 581 Texas
Texican
Texas
I have a 096 Radiator for my Six Pack Challenger and it's is in excellent condition but needs a new core.
I know the prices have gone up A LOT, but what is the gong rate I should be expecting ?
I live just North of Dallas and I just received a quote for $900.
Any feedback would be appreciated.
Thanks, Mike
Re: Going rate to recore a 26" HD Radiator ?
[Re: Matt M]
#3095265
11/18/22 03:46 PM
11/18/22 03:46 PM
Posts: 19,243 north of coder
moparx
any more, a guy needing a radiator re-cored, might just as well use glen ray. the only shop around here is a place that works primarily on semi's and heavy equipment, and prices accordingly, often way more than having glen ray work done. plus, it only cares about function, so slobbery solder joints are the norm, and tanks are not handled with any kind of care. often coming back with more dents than they started with. for a ton of years, there was a shop just a couple houses up the side street from me, that everyone [and i mean everyone !] took their radiators to because he knew the trade well, and it showed in his work. when he retired, his one boy took over the shop, moved it out of town, and it slowly died and closed up because the work just wasn't the same. the only options around now for anyone wanting a radiator in these parts, is glen ray, or buy a reproduction or cross flow replacement.
[Re: Matt M]
#3095407
11/19/22 02:08 AM
11/19/22 02:08 AM
Posts: 1,745 Phila
PhillyRag
Phila
I used Glen-Ray too. Very happy with them $900 plus shipping So seems like $1,000 with shipping both ways. Guessing doesn't matter whether 318 or hemi. Another reason why hobby has grown out of reach for many.
[Re: PhillyRag]
#3095492
11/19/22 01:02 PM
11/19/22 01:02 PM
Posts: 15,203 Omaha Ne
TJP
Omaha Ne
I used Glen-Ray too. Very happy with them $900 plus shipping So seems like $1,000 with shipping both ways. Guessing doesn't matter whether 318 or hemi. Another reason why hobby has grown out of reach for many. no offense but had to comment, Quality costs $$ and Glen Ray IMO is unequalled. I went through a fiasco several years back on a customer's 22" equipped R/T that cost me more time and money than I wanted to total up. And you guessed it, it was a heating issue. All temp measurements were being taken with a laboratory grade digital meter and type k thermocouple's New core from a local shop that does outstanding work (but he skipped the chapter on thermal efficiency of cores), freshly rebuilt motor, block check - negative, Water pump- negative Pulley ratios- Stock Fan - Stock Restricted exhaust - negative Have heads rechecked by another shop- negative Pull engine, remove freeze plugs, find 2 or 3 inside block. AH HAH! Remove errant plugs, reinstall motor, NO Change Pull engine again send to other shop, complete teardown / rebuild again, sonic check bores (only.030 but?) reinstall and Same Sh-t Finally call Glen Ray, he listens to my sob story, says send me the radiator if it does not fix your issue, I will fly down to assist. If we can' resolve the issue, you owe me NOTHING! OK, Your on and I'll take that bet. 2weeks or so later the radiator is reinstalled and POOF!!!! the heating issue is GONE! That was about 10 years ago and per the owner it has never gone above 190 under any conditions including parades on 95 degree day etc. I can't remember the cost of Glen ray's radiator but If I had paid 10 or 20X I would have been way ahead $$ wise He has since done a few other "problem" vehicles with the same success BTW: The owner later told me the problem had plagued the car since he owned it (~15 years)
[Re: TJP]
#3095545
11/19/22 03:22 PM
11/19/22 03:22 PM
Posts: 27,447 So Cal
autoxcuda
So Cal
I used Glen-Ray too. Very happy with them $900 plus shipping So seems like $1,000 with shipping both ways. Guessing doesn't matter whether 318 or hemi. Another reason why hobby has grown out of reach for many. no offense but had to comment, Quality costs $$ and Glen Ray IMO is unequalled. I went through a fiasco several years back on a customer's 22" equipped R/T that cost me more time and money than I wanted to total up. And you guessed it, it was a heating issue. All temp measurements were being taken with a laboratory grade digital meter and type k thermocouple's New core from a local shop that does outstanding work (but he skipped the chapter on thermal efficiency of cores), freshly rebuilt motor, block check - negative, Water pump- negative Pulley ratios- Stock Fan - Stock Restricted exhaust - negative Have heads rechecked by another shop- negative Pull engine, remove freeze plugs, find 2 or 3 inside block. AH HAH! Remove errant plugs, reinstall motor, NO Change Pull engine again send to other shop, complete teardown / rebuild again, sonic check bores (only.030 but?) reinstall and Same Sh-t Finally call Glen Ray, he listens to my sob story, says send me the radiator if it does not fix your issue, I will fly down to assist. If we can' resolve the issue, you owe me NOTHING! OK, Your on and I'll take that bet. 2weeks or so later the radiator is reinstalled and POOF!!!! the heating issue is GONE! That was about 10 years ago and per the owner it has never gone above 190 under any conditions including parades on 95 degree day etc. If I can't remember the cost of Glen ray's radiator but If I had paid 10 or 20X I would have been way ahead $$ wise he has since done a few other "problem" vehicles with the same success BTW: The owner later told me the problem had plagued the car since he owned it (~15 years) Was the Glen Ray core: - higher fin count ?
- higher tubes/inch density (more cooling tubes) ?
[Re: TJP]
#3095656
11/20/22 12:45 AM
11/20/22 12:45 AM
Posts: 1,745 Phila
PhillyRag
Phila
I used Glen-Ray too. Very happy with them $900 plus shipping So seems like $1,000 with shipping both ways. Guessing doesn't matter whether 318 or hemi. Another reason why hobby has grown out of reach for many. no offense but had to comment, Quality costs $$ and Glen Ray IMO is unequalled. I agree about quality/$$, but with dwindling rad. shops these days, that price will become the "norm". Same can be said about paint/body shops not doing classic cars, except the "expert few". Lots of entry level hobbyist can't afford these prices for non-high-dollar cars. Have say 50-70K to spent on a performance car? Restore a 73 318 car or just buy a newer challenger/charger/etc.
