Re: Found it!....Stupid Hemi
[Re: Dragula]
#3088464
10/23/22 03:28 AM
10/23/22 03:28 AM
Posts: 710 Lake Villa Il
INTMD8
Lake Villa Il
Maybe I'm wrong but I've read that some Indy rockers, depending on when they were made, lack oiling holes.
The stock ductile rockers I'm using have an oil hole for the pushrods and the valve tip.
I'm running them with no restrictors and pushrod oiling. Still went from 20-50 to 5-30 oil due to high pressure.
I would think you could achieve what you need by adding oiling holes to your current rockers and removing any restrictors.
Aside from that, not sure of the exact details of your springs/setup but wouldn't usually correlate a dual spring with damper as a high end spring for high lift street use.
I like PSI ML springs with exceldyne locks/retainers for whatever it's worth.
[Re: INTMD8]
#3093486
11/11/22 03:22 PM
11/11/22 03:22 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
So in mocking this up, I am wanting some custom ARP fasteners. I faxed over a quick CAD drawing of what I want to ARP, and then called them....Man are they backed up on custom orders....Like 6 months I am told....
So this may take all winter....
[Re: Cab_Burge]
#3095730
11/20/22 11:11 AM
11/20/22 11:11 AM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
My Headers are welded and you will have to pull the bars on an E Body to get them out of the car but could just leave them laying around the bars when you pull a motor. Bartons stuff is very very nice. To me if 5 K fixes the problem and more research is needed before you spend the 5K for the Barton set up that is much cheaper than a costly repair to a set of heads or a complete motor. How much is in your motor now, so it is like buying an insurance policy. The spray bars need to be looked at and cleaned also. This type of motor like said above is really not built for the street. Even the 1966/7 motor had next to nothing for cam lift, 68/69 a little more and 70/71 went to Hyd.to make them live on the street. These motors need there yearly once over and checked. One other thing, I believe in a lot of Oil both quanity and quality and pressure/volume.Maybe not what a race motor will get in pressure but still a high number.This is not a quick fix untill the problem is nailed down to what has happened or your problem will reoccure again and again so make the change that will fix it once. It takes time so take that time withour any emotions to cloud your decisions. I say that because we all have been in a similiar situation and toss money that is not needed trying for a quick fix. Good Luck
1971 HEMI E BODY REGISTRY
[Re: Dragula]
#3095764
11/20/22 01:17 PM
11/20/22 01:17 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I welded up my Hooker Super Comp Hemi headers on my E Body also. I have a AlterKation from suspension so no torsion bars either.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dragula]
#3096265
11/22/22 10:44 AM
11/22/22 10:44 AM
Posts: 10,020 MN
JERICOGTX
MN
Would have been a good place to install V band clamps. Could still take a couple tubes out for starter replacement.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3096275
11/22/22 11:23 AM
11/22/22 11:23 AM
Dragula
Would have been a good place to install V band clamps. Could still take a couple tubes out for starter replacement. I can pull the starter with just loosening the header slightly...It doesn't have to be removed, or any of the tubes...
[Re: Dragula]
#3096318
11/22/22 01:59 PM
11/22/22 01:59 PM
6PKRTSE
Motor City
Would have been a good place to install V band clamps. Could still take a couple tubes out for starter replacement. I can pull the starter with just loosening the header slightly...It doesn't have to be removed, or any of the tubes... Yes, same here. I can change my starter without removing the header. I did you V Band clamps on the collectors.
[Re: 6PKRTSE]
#3096356
11/22/22 04:41 PM
11/22/22 04:41 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
5210 Super Comps? 2& 1/8" primary, 3&1/2 collector? (just checking to see what I have to look forward to)
Rich H.
Esse Quam Videri
[Re: Dragula]
#3096390
11/22/22 07:31 PM
11/22/22 07:31 PM
Posts: 43,110 Bend,OR USA
Cab_Burge
Mines pretty easy to work on considering the big Hemi in there.... When I first saw this picture all those pipes it reminded me of snake mating season Don't get weird when you get old, like me please
[Re: powertrip]
#3101315
12/11/22 02:19 PM
12/11/22 02:19 PM
Dragula
Smart and didn't cost you 5K, I like it! Hope this solves your spring problems, what springs have you gone with? I had Pacalloy and then Howards....It does not seem brand specific.....Would love a set of Bartons, but not in the budget right now....Hell, if this works, I don't even have to put a new cam I bought in it...
[Re: Dragula]
#3101403
12/11/22 07:40 PM
12/11/22 07:40 PM
Posts: 1,505 TN
SCATPACK 1
TN
[b][/b] Mines pretty easy to work on considering the big Hemi in there.... That header shot from the bottom is beautiful. Nice car for all the work you have put into it.
Old Geezer Racing
