How high do you rev your 440s?
#3093022
11/10/22 01:54 AM
11/10/22 01:54 AM
Posts: 1,319 Loudoun County, VA
Brad_Haak
Loudoun County, VA
As in 3.75" stroke combos, not 4.15" +
My old build made peak HP at 6300-6400, I shifted at 6500 and went through the traps at 6800+
New combination makes peak HP at 6800 and I expect will go through the traps at 7000+... won't know where it'll want to be shifted until it sees the track again
Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: How high do you rev your 440s?
[Re: Brad_Haak]
#3093036
11/10/22 03:59 AM
11/10/22 03:59 AM
Posts: 291 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Man, good question. I'm trying to keep RPM down, because I got a stock crank with stock rods and swinging TRWs. But the higher I shift the faster it goes
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: Brad_Haak]
#3093038
11/10/22 05:03 AM
11/10/22 05:03 AM
Posts: 10,081 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thx My guess is it will like 6800 shift points, because actual shift point (data logged) is most likely a couple hundred rpm higher than when you shift. So start at 6600 Imho and go up in steps, after getting a base line that is solid info to work from.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Brad_Haak]
#3093054
11/10/22 08:37 AM
11/10/22 08:37 AM
Posts: 1,781 Keymar, MD
DusterKid
Keymar, MD
Most of my 440 combo's which have been fairly mild (under 11:1, hydraulic flat tappet cams in the .530ish range and steel heads reworked) I always shifted at 6,000. My current engine is still mild by most standards, 10:9:1 with TF 240 heads and a .557 solid cam. If I'm running 1/8th mile I shift at 6,000, but if I run 1/4 mile I shift at 6500. Doesn't seem to make a difference, but with the gearing and tire size it seems to be more consistent in the 1/4 if I shift at 6500.
[Re: J_BODY]
#3093066
11/10/22 09:25 AM
11/10/22 09:25 AM
Brad_Haak
Loudoun County, VA
I don't have a data logger, but I'll have a playback tach for the first time ever
[Re: Brad_Haak]
#3093067
11/10/22 09:26 AM
11/10/22 09:26 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
My old stock stroke 440 w/ a pretty big roller and Indy SRs (unported) liked 6800. That was the combo that went 10.40s at 128-129 mph at 3700 lbs. My older mild 509 cammed iron head motor liked 6000-6200...11.40s at 117 mph in the same car.
Brad, I think you'll be in the 6800 ballpark.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: lewtot184]
#3093082
11/10/22 10:15 AM
11/10/22 10:15 AM
Brad_Haak
Loudoun County, VA
I suppose I should mention the bottom end has an Eagle crank, Eagle rods, and Ross pistons
The only RPM-related concern might be the oiling system, but the upgrades done to it w/ the last build were targeted at better oil control at high(er) RPM
[Re: Brad_Haak]
#3093087
11/10/22 10:56 AM
11/10/22 10:56 AM
Posts: 570 UK
rb446
UK
In my opinion there's only 1 oiling system for 7k rpm and thats external, I know many have been ok with 1/2" internal and have lived but back in the day when I built my 440SP motor I looked at the oiling system and there was no question about it to me about not using it.
My motor ran to 6800rpm every run NA making just 515-ish fwhp with its stock bottom end and BV 906's and a .650" sft cam, 4.88's/32's, with N20 it trapped@7450, I only did that once!!, that motor is still running today albeit with a smaller cam. My mate with his 600hp 440 and 1/2" internal lasted 2 seasons@6800 and then threw 2 rods.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#3093090
11/10/22 11:03 AM
11/10/22 11:03 AM
Posts: 722 Lake Villa Il
INTMD8
Lake Villa Il
Hemi but almost stock 440 displacement. (3.75 stroke 4.31 bore). 7,600 so far.
Using Milodon 31580 oil pan and internal pickup.
[Re: J_BODY]
#3093092
11/10/22 11:05 AM
11/10/22 11:05 AM
Posts: 8,079 Tulsa OK
Bad340fish
Tulsa OK
Like Greg mentioned….. data recording can definitely make you adjust your shift light. It’s pretty interesting how much “time” can go by from: see shift light, arm moves shifter, trans makes mechanical shift My tach reads a little higher than my EFI does, it works out great, I pull the lever when I see 7000 and the actual shift takes place at 7000 +/- 50RPM or so.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3093095
11/10/22 11:19 AM
11/10/22 11:19 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Been a long time for me to have a stock stroke 440 but back in the late 1980’s I was shifting my Direct Connection copied build with the old .750 lift roller cams and was shifting from 6700-6900 rpm. Back then 9.80’s was pretty quick with the junk we had available
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Brad_Haak]
#3093124
11/10/22 12:33 PM
11/10/22 12:33 PM
Brad_Haak
Loudoun County, VA
... My old build made peak HP at 6300-6400, I shifted at 6500 and went through the traps at 6800+
Checked my notes in The Wayback Machine and remembered I used to hit the 1-2 shift at 6200 and the 2-3 at 6500. Sounds comparable to new engine going 1-2 at 6500 and 2-3 at 7000.
