Bracket Racers using Sniper or Holley & no Mufflers Q
#3092570
11/08/22 01:56 PM
11/08/22 01:56 PM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
So I got a price on a new billet carb, and I am thinking of running my Sniper 4500 on my bracket car instead....But it has short 4" header collectors and no mufflers....Can you still tune it without mufflers?
Anyone bracket race one of these?
Re: Bracket Racers using Sniper or Holley & no Mufflers Q
[Re: Dragula]
#3092588
11/08/22 03:12 PM
11/08/22 03:12 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
If you run a LONG header extension it will work
[Re: Dragula]
#3092616
11/08/22 04:40 PM
11/08/22 04:40 PM
CSK
Pattison Texas
you can put the o2 in one tube, some will disagree with that but just keep an eye on the spark plgs, My Holley HP efi only has 1 o2 on the left bank,
[Re: Dragula]
#3092624
11/08/22 05:32 PM
11/08/22 05:32 PM
Posts: 30,947 Oregon
AndyF
Anyone bracket race one of these? Yes it can be tuned with a short collector and no muffler. Put the O2 sensor in one of the header tubes about midway between exhaust port and the collector. That will give you a good reading for anything above 2000 rpm. You might be able to tune the idle also, or you might have to manually tune the idle. I tune several fast bracket cars (8.50 chassis cars) and that is the way we do it. Usually best if you can put the O2 sensor in the #1 or #2 pipe but any pipe can be made to work if you can't put it in a front pipe. In your picture you might want to go into the #8 pipe up near the valve cover but it depends on your harness layout. I'd use the #1 pipe if possible but sometimes you have to do what you have to do.
[Re: jwb123]
#3092636
11/08/22 06:14 PM
11/08/22 06:14 PM
CSK
Pattison Texas
Just from my experience with an o2 data logger, if you run it in the collector, it will read lean at idle and normal at WOT. As mentioned, put it in one of the tubes. I would use cylinder 5 or 7 just because they usually run the leanest. Unless you have a 5 7 swap camshaft. The other thing is I would call Holley, I don't think the O2 sensors tune much at WOT, they mainly are used for part throttle and cruising, that is where they learn and adjust the fuel maps. At WOT they are good for a data logging function. They tune at WOT
[Re: Dragula]
#3092641
11/08/22 06:21 PM
11/08/22 06:21 PM
Posts: 710 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Not hard, under "system ICF" open close loop/learn click "enable closed loop above XXXXX" (2000?)The closer the O2 to the collector, the higher the RPM. Then just manually tune the idle.
Joe
Without Data, you’re just another guy with an opinion.
[Re: Dragula]
#3092652
11/08/22 07:00 PM
11/08/22 07:00 PM
Posts: 566 Texas
RustyM
Texas
Yes, it will work .Yes, you need to read plugs and know what your o2 is reading compared to your plugs but, yes, it will be fine, even in closed loop. Lots of guys running well over 200 mph with holly systems and o2 bungs in places that make a fella scratch his head wondering "how the heck does that work" ? But, it does.May take a little work to get everything dialed in but, to my understanding and, seeing what people are successfully doing , I would sure give it a shot. Andy F. has done quite a bit of work with the holley systems now, feel sure he would be a reliable resource.
[Re: Dragula]
#3092669
11/08/22 07:50 PM
11/08/22 07:50 PM
CSK
Pattison Texas
If the injectors flow enough yes, the Super Sniper has 8 injectors & so does the 4500
[Re: Dragula]
#3092731
11/08/22 11:59 PM
11/08/22 11:59 PM
Posts: 702 Lake Villa Il
INTMD8
Lake Villa Il
Not sure the best way to change for E85. Can you change injector flow rate?
If you can change something to compensate for the additional fuel required, next question is, are the injectors large enough to handle that additional flow?
Also, are they stainless internal injectors? If not, can be gummed up rather quickly on E85, even if using the right filter. (6 micron fiberglass)
[Re: INTMD8]
#3092761
11/09/22 08:58 AM
11/09/22 08:58 AM
sr4440
Central TEXAS!!!!
Changing for e85 is not hard, in the sniper software,go fuel, target A/F ratio, make sure table is in 2d mode, highlight the entire table, Left click, select "Offset selected" Enter *.67. Now everything is at the E85 ratio, you have a starting point. Joe
[Re: sr4440]
#3092806
11/09/22 11:18 AM
11/09/22 11:18 AM
INTMD8
Lake Villa Il
Would that not only work if you can change the stoich value for the fuel? (maybe you can).
Otherwise if programmed for gasoline stoich, richening target a/f ratio would just make it very rich.
[Re: sr4440]
#3092811
11/09/22 11:29 AM
11/09/22 11:29 AM
Posts: 8,156 Plymouth, MI
Blusmbl
Plymouth, MI
You'll also have to change the fuel type to ethanol in the software. If you don't do that, just changing the target AF tables will make it too rich.
Reading up on it from a couple different forums, it sounds like E85 isn't suggested on most of the Sniper systems due to the injectors they use not being compatible with E85 and also the uncoated/bare aluminum parts inside the unit itself.
[Re: Blusmbl]
#3092920
11/09/22 05:58 PM
11/09/22 05:58 PM
sr4440
Central TEXAS!!!!
Reading up on it from a couple different forums, it sounds like E85 isn't suggested on most of the Sniper systems due to the injectors they use not being compatible with E85 and also the uncoated/bare aluminum parts inside the unit itself. Yep, forgot that part, it's when you do the initial engine setup. Joe
[Re: sr4440]
#3092999
11/09/22 11:36 PM
11/09/22 11:36 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
You could probably tune it by ear for idle and part throttle and get pretty close. Just pretend its a carb and you don't have an air fuel meter. Once you get to 3000RPM or so the 02 sensor readings should work fine.
I don't know how the sniper stuff works but you will need to get it tuned in to where you feel it is good at idle and low load and then lock the table and turn any learning off so it doesn't just keep dumping fuel trying to hit a target that cannot be achieved.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
