It hammered at 162K + fees or 165K in 2008, Not making any money at the BIN price
Note the the disclaimer on the VIN. But I believe that's their CTA just in case
VIN BS23R0B412035
Exterior Color BURNT TAN METALLIC
Interior Color TAN
Cylinders V8
Engine Size 426
Transmission AUTOMATIC
Description
Lot #1274 - 21,500 original miles. Excellent interior, engine compartment and body condition. Older paint. Extremely rare -- #4 of 4 painted in Burnt Tan metallic and #10 of 10 with electric windows. Manufactured at Hamtramck, MI, assembly plant on Tuesday, July 7, 1970. #260 of 262 hardtops. Personally inspected, authenticated and certified in 2002 by Galen Govier as a numbers matching original vehicle. Included is complete inspection report and photos, including 7 VIN numbers and 3 Broadcast Sheets. Matching numbers include: dash VIN, primary body code on radiator support, secondary body code on cowl, Fender Tag, VIN stamped on engine, engine ID stamped on oil pan, VIN stamped on transmission, VIN decal on driver's door plus 3 Broadcast Sheets (which is 2 more than usual). VIN BS23R0B412035 registered in Chrysler Registry. Options: 426cid with (2) 4-barrel carbs, 425hp HEMI V8, 727 TorqueFlite automatic with slap-stick shifter, Burnt Tan metallic (ft6) with tan interior, vinyl bucket seats with wood grain console, light package, Rallye instrument cluster including tachometer and 150mph speedometer, carb fresh air package with Shaker Hood, power windows, music master AM radio, HEMI suspension with front sway bar, correct collapsible spare tire, inflation canister and jack, original owner's manual and some prior owner documentation. Converted to electronic ignition. Original distributor included.
Financing
Enter an Estimated Bid:
See your low payment:
To learn more
CALL 888-793-9789 or
Get Pre-Approved now!
**VIN NOTICE: DEPENDING ON THE STATE OF REGISTRATION OF THE BUYER, THE VEHICLE MAY REQUIRE AN INSPECTION AND BE SUBJECT TO A STATE-ISSUED VIN AND/OR OTHER REQUIREMENTS OF THAT STATE.** Articles and News
