1971 camshaft pn 3671-475 info? #3092546
11/08/22 12:41 PM
11/08/22 12:41 PM
PINE VALLEY
Ray S Offline OP
Ray S  Offline OP
PINE VALLEY
My 71 413-1 has a pn 3671-475 (RV/truck) cam, and I can't find any info on it, anywhere, at all.
Does anyone have open-close specs for it?
Someone posted these
https://www.bigblockmopar.nl/tech/chrysler-corporation-valve-action-timing
http://victorylibrary.com/mopar/mpcam-tech-c.htm
but sadly no 413s at all.
Re: 1971 camshaft pn 3671-475 info? [Re: Ray S] #3092573
11/08/22 02:04 PM
11/08/22 02:04 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Ray, if you are looking for a cam for your engine talk to Mike Jones. He has an RV grind specifically for big block mopar motorhomes.
If I recall correctly seems I read somewhere that the 413 cam was about .190 @ .50 duration and 390 lift w/ 1.5 rockers. It was smaller than even the stock base model 440's.
I can't find or recall where I might have read it though.
Re: 1971 camshaft pn 3671-475 info? [Re: mgoblue9798] #3092596
11/08/22 03:43 PM
11/08/22 03:43 PM
PINE VALLEY
Ray S Offline OP
Ray S  Offline OP
PINE VALLEY
Thanks - even the 440 specs I've found are probably for cars, not the RVs, like "CHRYSLER CORPORATION VALVE ACTION & TIMING 1970 - 1976"
I might re-cam one day but not soon, I'd like to know what they come with to start...
FWIW I did just find these RV cam threads:
https://www.forbbodiesonly.com/moparforum/threads/440-rv-cam-specs.163412/post-911549616
"stock mh cam was the same as the non hp cam basically 68 to end of production"
https://www.forbbodiesonly.com/moparforum/threads/72-rv-413-engine-questions.128425/#post-910646662
"My 413 had the stock 2.08/1.74 valves that came in the 915 head"
I have the FSM and parts books, but they don't provide specs
