Page 6 of 17 1 2 4 5 6 7 8 16 17
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3090700
10/31/22 01:32 PM
10/31/22 01:32 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by ZIPPY
Oh yeah, Jeff. Current favorite is this Mirka dry guide coat.
https://www.amazon.com/Mirka-9193500111-P-Dry-Guide-Coat/dp/B01GA7DVVQ
OK. I've always used the SEM stuff.
69 GTX 68 Road Runner
Re: Slow Progress at Zippy Performance [Re: JERICOGTX] #3090703
10/31/22 01:43 PM
10/31/22 01:43 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: JERICOGTX] #3090704
10/31/22 01:44 PM
10/31/22 01:44 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
My guide coat of choice.....when im done priming i just put some reduced basecoat in the gun. Turn the PSI way down, like to 5-10 and then just dust it on primer
....BAD A$$ STREET CAR.....
Re: Slow Progress at Zippy Performance [Re: n20mstr] #3090739
10/31/22 02:52 PM
10/31/22 02:52 PM
moparx Offline
moparx  Offline
i'm always in awe when someone posts pics of great body work. bow
my talent in that department is just which BFH to use, or which crowbar size is appropriate, maybe a combination of each. biggrin
beer
Re: Slow Progress at Zippy Performance [Re: moparx] #3091067
11/02/22 06:37 AM
11/02/22 06:37 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
I always have mondo respect for the dude hammering away in his garage late at night and having a go at doing almost everything he can on his ride himself.
Kudos Zippy, keep the pix coming man, great work ! up
Re: Slow Progress at Zippy Performance [Re: LAD 524] #3091077
11/02/22 08:06 AM
11/02/22 08:06 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Wow Rich! You're persevering all the bad stuff well and it'll be nice when you're done. Good work
Re: Slow Progress at Zippy Performance [Re: n20mstr] #3091141
11/02/22 12:36 PM
11/02/22 12:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Our guide coats usually come from a spray can unless we have some dark color available for the gun done the same way as Tony
Re: Slow Progress at Zippy Performance [Re: Al_Alguire] #3091605
11/04/22 12:23 PM
11/04/22 12:23 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
More of the same kind of thing.
My wife eats lucky charms, and I only get the box.
But, if they provide any good luck then I'll take all I can get!
Yes, I could have flipped the cardboard over, but needed the plain side to face down because
that's where I made my pencil marks. So: It's "fun, distracting and unprofessional side up".
You'll notice the cut metal isn't anywhere near the size of the templates, this is by design.
The templates are supposed to be slightly oversize. Rough cut new metal to the template, hold securely in place, partially cut through both
new and repair layers at the same time, peel back the bad stuff, hold the new stuff in place and tack it.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3091608
11/04/22 12:36 PM
11/04/22 12:36 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Here it is flipped over, showing the side that will be visible when the door is opened, after the skin is installed.
Still needs rectangular bumper hole cut out.
Now finish rust and paint removal, 2-3 coats of epoxy in and out, prep the new skin with epoxy and a little sound deadener
on the inside, then the skin will be ready to install.
I could have bought complete door shells for $1800 instead of two skins for $600 and done all this work
(normally skins are $800 but I found both skins discounted, one locally at Roseville on sale and the other from Jegs
with slight shipping damage/edge dents that came out with a few minutes of hammer and dolly work).
Why not use complete reproduction door shells? For labor savings, complete door shells would be the way to go, but
I fit the quarter panels using these original doors,
would rather not mess up the gaps in a new way and then have to fix that, fix any other issues they may have, and plus these originals were plenty savable. No reason to scrap them for a couple rust spots, they don't grow on trees...its not 1982 anymore.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3091622
11/04/22 01:34 PM
11/04/22 01:34 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I use frozen pizza boxes the same way Rich! grin
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Slow Progress at Zippy Performance [Re: DynoDave] #3091638
11/04/22 02:21 PM
11/04/22 02:21 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Looks good!
Wray Schelin's YouTube channel is also great for metal fab info. He hates bondo so he shows people how to take metal work as far as needed to make it right. He also makes the shrinking discs used for metal finish work.
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3091717
11/04/22 08:45 PM
11/04/22 08:45 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
You'll probably live longer...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Slow Progress at Zippy Performance [Re: Brad_Haak] #3091787
11/05/22 07:59 AM
11/05/22 07:59 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I agree with the original stuff. Any body that thinks Goodmark or AMD just bolts on and needs a prime coat is living in La La land. Many times it's quicker to fix the old stuff than fit the new stuff. Great progress.
Doug
Re: Slow Progress at Zippy Performance [Re: dvw] #3094375
11/15/22 01:56 PM
11/15/22 01:56 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Hopefully this is not so exciting that it breaks the internet wink
Left door is coming along quicker than the right door, which I guess figures since it's the second one and
I had a better idea of what to expect.
Super complex and highly professional blasting rig came through again. $20 second hand pressure blaster with a few parts replaced.
As for the media, "Black Blast" (coal slag) from Menards is expensive but rips through the rust and coatings much quicker than silica sand.
PPE/Respirator required. 2 coats of SPI black epoxy. I would probably dip the entire car in epoxy if I could.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3094382
11/15/22 02:27 PM
11/15/22 02:27 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Interior of new skin, scuffed e-coat and applied a few coats of epoxy.
Next day, masked off and shot a thinner (lightweight racing?) layer of sound deadener just like OE, but less sloppy.
Added the rectangular bumper hole to the repaired area of the structure, hammered and dolly the skin partially into place, (not shown) test fit on the car to confirm gaps were correct, pulled back off, hammer and dolly work to finish the skin install, spot welded the skin to the structure every 6 inches or so, prepped/smoothed the welds. Flipped it over, removed ecoat, 3 coats of epoxy, minor filler work, sealed bodywork with epoxy, (shown) 3 coats of 2k surfacer.
Tonight, guide coat and blocking. I think I got this one straighter, earlier/up front than the other side.
Goal with every panel is to repair everything, block each individual part out to 220, then when all panels are to that point, block the whole
vehicle in 320 + whatever finer grit I'll probably decide to go with. Basecoat TDS says 400 dry, 500 wet. My sprayout over 600-sanded 2K looks nice. Will probably get some extra materials, and shoot a whole old door skin or the remnants of a quarter panel for practice and to decide which one really suits me better.
When this door is finished to 220 that will complete the first stage of my master plan for the exterior+ trunk.
Engine compartment, cowl, bulkhead and A pillars will come next.
The engine is still in the car, so that's going to require a little bit of work to pull the 451.
Being a sentimental idiot, I will need to hear it run again before it comes out
and plan to run plenty of fogging oil through it.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3094383
11/15/22 02:32 PM
11/15/22 02:32 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Bodywork is tough to do right.
Good job, Rich! That car's going to be amazing!
'63 Dodge 330
11.19 @ 121 mph
Re: Slow Progress at Zippy Performance [Re: GY3] #3094389
11/15/22 02:43 PM
11/15/22 02:43 PM
N
n20mstr Offline
n20mstr  Offline
N
I love your plan, pretty much how i do it, but i like to use spray polyester. I like blocking the panels into each other (doors qtrs, fenders) then carfefully take it apart for paint . It gives you really nice body lines and super flat flow from panel to panel
Re: Slow Progress at Zippy Performance [Re: n20mstr] #3094396
11/15/22 02:58 PM
11/15/22 02:58 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Haven't any experience with poly primer yet, but after the multiple rounds on the quarter panels with regular poly filler on the fenders and quarters to get them straight, I can see now that maybe poly primer would have got me where I wanted to be, sooner/faster.
I'm probably an odd duck in that I'm totally comfortable with old stuff hardly anyone is interested in like lead/body solder and single stage paint, but have not tried poly primer.
There's always the next project smile
Thanks!
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: GY3] #3094397
11/15/22 03:05 PM
11/15/22 03:05 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thank you Mark! No rust, and straight are really my only priorities right now.
after that, the topcoat will make it or break it.
If nobody highly skilled offers to shoot it for me (which I assume will happen, given the lame response received so far)
then I'll have to buy extra materials, practice, develop something on my own and set up the shop a little
differently to do a makeshift booth. Tentative plans have been made and so on.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3094429
11/15/22 05:09 PM
11/15/22 05:09 PM
an8sec70cuda Offline
Looks great Rich! Can't wait to see the finished product...I'm sure you can't either. That's gonna be one nice GTX!
CHIP
'06 GMC 2500HD LBZ Duramax
