Door hinges #3089923
10/28/22 02:13 PM
10/28/22 02:13 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Is there a preferred go to for replacement door hinges or rebuild kits or rebuilder ? 65 B body
Re: Door hinges [Re: Wirenut] #3090208
10/29/22 02:20 PM
10/29/22 02:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRc NAPA sells a pin kit with bushings.You do have to drill to install the bushings Seems many have used them and they are supposed to be good.I have to do the DS door on my 65 Belvedere.Have 2 bad hinges from the DS. Rocky
Chrysler Firepower
Re: Door hinges [Re: therocks] #3090223
10/29/22 03:01 PM
10/29/22 03:01 PM
moparx Offline
moparx  Offline
from the dusty corners of my noodle, i seem to recall dorman, or the "help" brand repair kit for a ford truck [?] had the correct bushings and pin length[s] for most mopar door hinges, and was usually on stock at most [?] parts stores.
if this isn't correct, please correct me !
beer
Re: Door hinges [Re: moparx] #3090257
10/29/22 05:04 PM
10/29/22 05:04 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
I’ll check it out .
Re: Door hinges [Re: Wirenut] #3090262
10/29/22 05:40 PM
10/29/22 05:40 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
OT of sorts but when I read the Title of this thread it reminded me of when I said to my very young something about him being perplexed at the time about something not to get worried about. I said "don't worry there are things that you just can't fix, like there are no words that rhyme with orange" to which his response was "Door hinge" shock well that was close enough for me to put that to rest. laugh2
Re: Door hinges [Re: A12] #3090461
10/30/22 12:53 PM
10/30/22 12:53 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Go to ForBBodiesOnly.com and look for MoparLeo. Hes in CA and rebuilds hinges. Stellar work and fair price IMO. Realize not that difficult to do if the hinges arent worn too bad but mine were and he utilized upsized pins and other details to address. If you cant find it, PM me and I will provide his email address/phone number.
Re: Door hinges [Re: BryanRad] #3090582
10/30/22 11:55 PM
10/30/22 11:55 PM
Maryland
MoparMike1974 Offline
Maryland
I dont recommend using the bushings for the lower hinge. There is a reason the factory only put them in the top hinge. Look around for the kit with oversize pins so you dont need to install bushings. I also recommend replacing the S spring since they are almost always grooved.
Re: Door hinges [Re: MoparMike1974] #3090597
10/31/22 06:04 AM
10/31/22 06:04 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks for all the help
Re: Door hinges [Re: Wirenut] #3090653
10/31/22 10:53 AM
10/31/22 10:53 AM
IMGTX Offline
IMGTX  Offline
I have rebuilt many of my own hinges with the Dorman pin and bushing kits.
A good piece of advice is to spend a few dollars and get a drill bit long enough to go through both sides of the hinges when you drill them for the bushings. It is pretty much impossible to line the top and bottom holes up by drilling one side then the other. If the holes aren't lined up the hinge bushings will be short lived.
Re: Door hinges [Re: MoparMike1974] #3090715
10/31/22 02:09 PM
10/31/22 02:09 PM
moparx Offline
moparx  Offline
i seem to remember the oversize pins were the ford pins, but i could be wrong. [it wouldn't be the first, and i'm sure it won't be the last time i'm wrong...... whistling biggrin]
and replacing the spring is a good idea as well. especially since you have the hinge apart already.
beer
Re: Door hinges [Re: Wirenut] #3090763
10/31/22 03:58 PM
10/31/22 03:58 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
If you want to send them out, member moparleo does professional restoration of them. Here's his profile and an eBay ad of his.
https://board.moparts.org/ubbthreads/ubbthreads.php/users/21276/moparleo.html
https://www.ebay.com/itm/141816569176
Re: Door hinges [Re: EW1BH27] #3091242
11/02/22 07:50 PM
11/02/22 07:50 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks this seems more than reasonable cost wise .
Oddly enough the drivers side seems pretty good and the passenger side not .
Re: Door hinges [Re: Wirenut] #3091456
11/03/22 05:13 PM
11/03/22 05:13 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Superbird Bob.
superbirdbob@aol.com
Abe Lincoln
Re: Door hinges [Re: MoparMike1974] #3091896
11/05/22 08:32 PM
11/05/22 08:32 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Care to explain why that is?
Re: Door hinges [Re: PhillyRag] #3091933
11/06/22 08:22 AM
11/06/22 08:22 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Anyone have a link to the over sized pin kit . Ford was mentioned but what year and application?
Re: Door hinges [Re: Wirenut] #3091934
11/06/22 08:23 AM
11/06/22 08:23 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
The only problem I see with the rebuild service is I would have to remove both doors and store them at the same time . Space is tight right now
Re: Door hinges [Re: PhillyRag] #3092196
11/07/22 12:35 AM
11/07/22 12:35 AM
Grand Prairie, Texas
miketyler Offline
miketyler  Offline
I’ve read the same about the original design with lower hinge taking the major portion of the weight load. With the door open, doesn’t the top hinge bear the same weight load, though in opposite direction, as that on the bottom hinge? Ie, the top hinge is in tension while the bottom hinge is in compression. Yes, I’m sure there is a reason why they didn't design the lower hinge to be bushed. Hopefully someone can help me understand,
Re: Door hinges [Re: miketyler] #3092262
11/07/22 11:54 AM
11/07/22 11:54 AM
IMGTX Offline
IMGTX  Offline
It seems to me the bottom wasn't thick enough to hold bushings. They had to pack springs & detention rollers into the hinges so making them thick enough to put bushings in them would make for a heavy costly hinge.
Modern cars without the detention stops in the hinges are pretty light duty top and bottom but the doors are pretty light duty also so shruggy
Re: Door hinges [Re: Wirenut] #3092341
11/07/22 03:31 PM
11/07/22 03:31 PM
moparx Offline
moparx  Offline
the only thing i remember about this, it's a ford pickup, and i'm thinking around 78 or so model year.
i'm going on my memory alone [laugh2], so if you have a pin in hand, or the hinge, i can only suggest taking it to a parts store and comparing it to what is on the "help" rack.
if you are successful, please let us know what you find.
beer
Re: Door hinges [Re: MoparMike1974] #3092428
11/07/22 10:06 PM
11/07/22 10:06 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
It can be done, here's pic of set from ebay
