Re: Door hinges
[Re: Wirenut]
#3090208
10/29/22 02:20 PM
10/29/22 02:20 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
IIRc NAPA sells a pin kit with bushings.You do have to drill to install the bushings Seems many have used them and they are supposed to be good.I have to do the DS door on my 65 Belvedere.Have 2 bad hinges from the DS. Rocky
Chrysler Firepower
Re: Door hinges
[Re: moparx]
#3090257
10/29/22 05:04 PM
10/29/22 05:04 PM
Posts: 630 Ct
Wirenut
Ct
Re: Door hinges
[Re: MoparMike1974]
#3090715
10/31/22 02:09 PM
10/31/22 02:09 PM
Posts: 19,355 north of coder
moparx
I dont recommend using the bushings for the lower hinge. There is a reason the factory only put them in the top hinge. Look around for the kit with oversize pins so you dont need to install bushings. I also recommend replacing the S spring since they are almost always grooved.
i seem to remember the oversize pins were the ford pins, but i could be wrong. [it wouldn't be the first, and i'm sure it won't be the last time i'm wrong...... ] and replacing the spring is a good idea as well. especially since you have the hinge apart already.
Re: Door hinges
[Re: EW1BH27]
#3091242
11/02/22 07:50 PM
11/02/22 07:50 PM
Posts: 630 Ct
Wirenut
Ct
Thanks this seems more than reasonable cost wise . Oddly enough the drivers side seems pretty good and the passenger side not .
Re: Door hinges
[Re: Wirenut]
#3091456
11/03/22 05:13 PM
11/03/22 05:13 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Superbird Bob.
superbirdbob@aol.com
Abe Lincoln
Re: Door hinges
[Re: MoparMike1974]
#3091896
11/05/22 08:32 PM
11/05/22 08:32 PM
Posts: 1,754 Phila
PhillyRag
Phila
Care to explain why that is?
Re: Door hinges
[Re: PhillyRag]
#3092196
11/07/22 12:35 AM
11/07/22 12:35 AM
Posts: 350 Grand Prairie, Texas
miketyler
I’ve read the same about the original design with lower hinge taking the major portion of the weight load. With the door open, doesn’t the top hinge bear the same weight load, though in opposite direction, as that on the bottom hinge? Ie, the top hinge is in tension while the bottom hinge is in compression. Yes, I’m sure there is a reason why they didn't design the lower hinge to be bushed. Hopefully someone can help me understand,
Re: Door hinges
[Re: Wirenut]
#3092341
11/07/22 03:31 PM
11/07/22 03:31 PM
moparx
Anyone have a link to the over sized pin kit . Ford was mentioned but what year and application? the only thing i remember about this, it's a ford pickup, and i'm thinking around 78 or so model year. i'm going on my memory alone [ ], so if you have a pin in hand, or the hinge, i can only suggest taking it to a parts store and comparing it to what is on the "help" rack. if you are successful, please let us know what you find.
Re: Door hinges
[Re: MoparMike1974]
#3092428
11/07/22 10:06 PM
11/07/22 10:06 PM
Posts: 1,754 Phila
PhillyRag
Phila
It can be done, here's pic of set from ebay
