Page 2 of 4 1 2 3 4
Re: 563 Dyno results [Re: JERICOGTX] #3089823
10/28/22 09:08 AM
10/28/22 09:08 AM
NC
440Jim Offline
440Jim  Offline
NC
Nice to see the results after all the delays.
Very good post with combo summary and dyno results all in one place.
733.0 ft-lbs at 5700 rpm
869.8 hp at 7000 rpm
I bet it would hold close to that HP at higher RPM.
Re: 563 Dyno results [Re: 440Jim] #3089825
10/28/22 09:15 AM
10/28/22 09:15 AM
MN
JERICOGTX Offline OP
MN
I was asked how high I was willing to spin it, and told him I didn’t want to go over 7000, and would most likely be shifting it at 6800. It’s a bracket engine. I want it to last a long time.
69 GTX 68 Road Runner
Re: 563 Dyno results [Re: JERICOGTX] #3089848
10/28/22 10:14 AM
10/28/22 10:14 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Glad to see you worked thru the issues and got it done.
Nice numbers!!
Looking forward to the track results next spring.
Re: 563 Dyno results [Re: fast68plymouth] #3089852
10/28/22 10:27 AM
10/28/22 10:27 AM
MN
MN
Nice numbers!!
Thanks Dwayne! And thank you for setting up a great set of heads.
Re: 563 Dyno results [Re: JERICOGTX] #3089857
10/28/22 10:49 AM
10/28/22 10:49 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Congrats on the successful dyno runs. That should put you in the 9 teens or oh's. You say you just want it to get down the track, hang out with your friends at the dragstrip. I know better. You want an 8 second time slip! What is it going to take, 8.86?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 563 Dyno results [Re: Hemi_Joel] #3089868
10/28/22 11:22 AM
10/28/22 11:22 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very impressive and such a clean looking engine!
'63 Dodge 330
11.19 @ 121 mph
Re: 563 Dyno results [Re: Hemi_Joel] #3089869
10/28/22 11:27 AM
10/28/22 11:27 AM
MN
MN
Wallace calculator shows it “should run 8.85 @ 152 mph. But we all know that is with optimum conditions, and sea level. We don’t race at either of those. While yes, I’d love to see a 8.9999 before the 4th of July, and collect yet another dinner from you, I’ll be content with a 9.teen, and have it repeat all day.
Re: 563 Dyno results [Re: JERICOGTX] #3089871
10/28/22 11:32 AM
10/28/22 11:32 AM
MN
MN
Here is a video of the last pull made.
https://youtube.com/shorts/azNwnnbJtFU?feature=share
Enjoy.
Re: 563 Dyno results [Re: Hemi_Joel] #3089873
10/28/22 11:43 AM
10/28/22 11:43 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
iagree........just ask Doug about that 8 smoke
Love the way the car sits cool
Re: 563 Dyno results [Re: JERICOGTX] #3089875
10/28/22 12:11 PM
10/28/22 12:11 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
If you want to run in the 8's ....its practically a no brainer. SLip the "correct" carb spacer primer whistling in there and im sure it will go DEEP into the 8's up
Seriously.....congrats, that a bad A$$ bracket engine grin
....BAD A$$ STREET CAR.....
Re: 563 Dyno results [Re: n20mstr] #3089889
10/28/22 12:44 PM
10/28/22 12:44 PM
central il.
second 70 Offline
second 70  Offline
central il.
Great job Jeff. I can see you in Joel's pocket already.
Re: 563 Dyno results [Re: second 70] #3089901
10/28/22 01:12 PM
10/28/22 01:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sounds like a runner, dont see why you cannot get her into the 8's with that piece. As for carb spacers, ehh. I have dynoed alot of engines and seems you can stack them to the ceiling and make more power and put it in the car and see ZERO gains. Its all about plenum volume for the given combo, if its good its good. FWIW we have had the best luck with the ones we have made for our stuff to match the carb size more than a generic spacer. I believe that is do more to fuel shear atomization and droplet size than anything else.
Re: 563 Dyno results [Re: JERICOGTX] #3089918
10/28/22 01:54 PM
10/28/22 01:54 PM
moparx Offline
moparx  Offline
i would have a bigger smile that wouldn't wipe off................ biggrin
congratulations on that combo ! up bow
beer
Re: 563 Dyno results [Re: moparx] #3089937
10/28/22 02:55 PM
10/28/22 02:55 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Nice combo. Can't wait for on track results.
Re: 563 Dyno results [Re: Al_Alguire] #3089964
10/28/22 04:19 PM
10/28/22 04:19 PM
N
n20mstr Offline
n20mstr  Offline
N
Al , these carb spacers work wonders , and only one needed 😂
Re: 563 Dyno results [Re: n20mstr] #3089967
10/28/22 04:32 PM
10/28/22 04:32 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have one of those with the lettering blacked out. It has a hot side and a cold side.... grin
'63 Dodge 330
11.19 @ 121 mph
Re: 563 Dyno results [Re: JERICOGTX] #3089978
10/28/22 05:08 PM
10/28/22 05:08 PM
Did you try making any pulls with the air sensor disconnected and remove with the carb open to the room air only?
If so what was the differences? If not shruggy
Re: 563 Dyno results [Re: Cab_Burge] #3089984
10/28/22 05:27 PM
10/28/22 05:27 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Congratulations Jeff! Can't wait to see what it does in the car.
Re: 563 Dyno results [Re: JERICOGTX] #3089989
10/28/22 05:59 PM
10/28/22 05:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice job to all involved. That car is going to run just as good as it looks!
Rich H.
Esse Quam Videri
Re: 563 Dyno results [Re: tboomer] #3089994
10/28/22 06:26 PM
10/28/22 06:26 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
Congratulations! That bullet should put you right into the 8's.
Page 2 of 4 1 2 3 4
