Re: Rumors re MoPig progress may be true
[Re: moparx]
#3092111
11/06/22 07:32 PM
11/06/22 07:32 PM
Posts: 1,182 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: racerx]
#3092199
11/07/22 12:50 AM
11/07/22 12:50 AM
Brad_Haak
Loudoun County, VA
Brad... were you planning to run an air pan with that hood? Yep
[Re: Brad_Haak]
#3092218
11/07/22 07:25 AM
11/07/22 07:25 AM
Posts: 4,076 Mo.
racerx
Mo.
Brad... were you planning to run an air pan with that hood? Yep Keep this updated if possible been trying to figure out a design for mine, but my intake sits to high
[Re: racerx]
#3092227
11/07/22 09:11 AM
11/07/22 09:11 AM
Brad_Haak
Loudoun County, VA
Gonna make a new one the same way I did one before: - find a drop-style air cleaner base that lowers the filter surface below the surface of the hood - cut out a cardboard template that matches the underside of the hood that you want to seal off - cut out an opening in the template where the air cleaner base will mount - get a sheet of thin luan (?) wood and cut to match cardboard template - pop-rivet or screw air cleaner base to wood sealing plate - get some fire-resistant foam (I use what Moroso sells) - it requires trial & error test fittings to determine how much foam to glue on perimeter of sealing plate
If you have room for an air filter, installing the complete filter housing holds the sealing plate in place
Otherwise, the hood itself when closed may hold it in position; that's how my last one worked
[Re: Brad_Haak]
#3092233
11/07/22 09:55 AM
11/07/22 09:55 AM
Brad_Haak
Loudoun County, VA
Here's the one for this hood...
[Re: Brad_Haak]
#3092239
11/07/22 10:11 AM
11/07/22 10:11 AM
Brad_Haak
Loudoun County, VA
I'm expecting the Braswell base on the right will lower the plate enough to use w/ this head & intake combo that pushes the carb mounting surface up even more than before. Since I have only 4150 carbs, I've probably got more options for air cleaner configurations.
[Re: racerx]
#3092309
11/07/22 02:06 PM
11/07/22 02:06 PM
Brad_Haak
Loudoun County, VA
What intake you use? That wood looks kind of thick. The wood is only ~ .200" thick, yet still does a good job of isolating heat from the carb. You can put your hand on the hood when the engine's been running and feel a noticeable temp diff between the hood exposed to under-hood heat and the hood isolated by the sealing pan. I have a Trick Flow intake on top of Victor heads, so a tall intake w/ raised intake ports shifts the carb up quite a bit.
[Re: racerx]
#3093025
11/10/22 01:58 AM
11/10/22 01:58 AM
Brad_Haak
Loudoun County, VA
Anyone have any thoughts or experience with knowing what happens when your hood scoop is too big? Does it jack with your tune, or...? Thx
[Re: Brad_Haak]
#3093065
11/10/22 09:23 AM
11/10/22 09:23 AM
Brad_Haak
Loudoun County, VA
Anyone have any thoughts or experience with knowing what happens when your hood scoop is too big? Does it jack with your tune, or...? Thx After further digging into the subject... I guess this will be "interesting" to figure out on my own Long story short is that scoop opening is waaaaaayyyyy too freakin' big IMO, but it is what it is
[Re: Brad_Haak]
#3093069
11/10/22 09:29 AM
11/10/22 09:29 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
It is big, but it isn't THAT tall. Not way up in the "good" air so to speak. Although the 6 pack hood I used to have on my car was worth a tenth to a tenth and a half when it was sealed to the carb. So they do work even when they're kinda short.
[Re: an8sec70cuda]
#3093080
11/10/22 10:07 AM
11/10/22 10:07 AM
Brad_Haak
Loudoun County, VA
I saw the same amount of improvement from sealing the stock T/A scoop setup vs running the scoop w/o a fresh-air plate
As far as the scoop being "too big", I'm not the first -- or only -- person to run a Big-N-Ugly one. VFN doesn't offer this style any longer (not on their web site now), but "340Rick" had theirs on his Chally. Not identical, but still pretty close.
[Re: Brad_Haak]
#3093218
11/10/22 06:59 PM
11/10/22 06:59 PM
Posts: 1,030 ohio
67mprfan
ohio
While you are fabbing up your air pan. Is it possible to maybe leave enough area to build some sort of dam to slow the air down
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#3093341
11/11/22 09:17 AM
11/11/22 09:17 AM
Brad_Haak
Loudoun County, VA
While you are fabbing up your air pan. Is it possible to maybe leave enough area to build some sort of dam to slow the air down I have a couple of ideas on things I may need to try out, including plugging off one half of the scoop, air "baffles" (like you mentioned), spring-loaded trap doors to allow some amount of excess airflow to vent...
[Re: Brad_Haak]
#3093357
11/11/22 09:58 AM
11/11/22 09:58 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
If the scoop is sealed to the hood then I would imagine it would build pressure and maybe not be as turbulent as it would be if there was no pan or sealing to the hood. I know some EFI guys I follow have noted positive manifold pressure with those lexan scoops.
68 Barracuda Formula S 340
[Re: BloFish]
#3093445
11/11/22 01:32 PM
11/11/22 01:32 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Lexan scoops are an issue, they simply don't have enough volume in that small space, so yes they need to be vented. A properly sized scoop for the engines needs does NOT need to be vented in any way. There are anumber of sources out there to help determine what sixe your engine actually NEEDS. Here is just one article on the subject but its not difficult to calculate the volume needed https://www.enginelabs.com/engine-t...p-speed-with-a-forward-facing-air-inlet/
