Re: Cam and torque converter question [Re: 6PAX] #3089205
10/25/22 09:36 PM
10/25/22 09:36 PM
I've had more bad race converters than good ones, I ended up finding out that a very good 8 inch race converter from Turbo Action was the best converter I have owned. It was made for a SS/AH back in the late 1990s, that was a GREAT street and strip converter. It would drive away very nicely from a dead stop with very light throttle pressure and set me way back in the seat when foot stalling it up around 3600 RPM before flooring it at the races boogie up
Paul Rossi use to test converters for Turbo Action and he made a comment one night when testing at O.C.I.R years ago, he said you are truly blest when you get a really good converter shruggy work That was back in the late 1970s shruggy
Re: Cam and torque converter question [Re: AndyF] #3089458
10/26/22 06:07 PM
10/26/22 06:07 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Originally Posted by AndyF
Yeah you'll be happier in the long run with a smaller cam on the street and then a regular "high performance" converter. For your engine I'd recommend something like the old Mopar Performance 528 solid. That cam works great in a 470 high performance street engine. It is big enough to make good top end power, but it will also drive really nice with a typical high stall street converter. It isn't a race cam so don't buy a race converter, just stick with high performance street parts. Call Porter Racing Heads and tell them what you're trying to do and they'll get you the correct camshaft for your application.
I think I'm going to take your advice and go with the MP528 solid cam. Will it be a direct swap for the Howard's cam/lifters I have now or will I have to change the pushrods as well? I had installed new Trend pushrods when I installed the Comp Magnum rocker arm assemblies.
Re: Cam and torque converter question [Re: 6PAX] #3092534
11/08/22 11:50 AM
11/08/22 11:50 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I've been looking for a 528 Purple Shaft to no avail. I'm starting to think about maybe going with a hydraulic cam instead. Based on the specs I posted above on how my engine is built, I would appreciate any recommendations on a hydraulic cam that would be a good choice for my engine (is there a comparable hydraulic to the 528 Purple Shaft?). Again, I won't be taking the car to the track and I don't want a real high stall converter. Maybe 3000 rpm tops.
Re: Cam and torque converter question [Re: 6PAX] #3092551
11/08/22 12:47 PM
11/08/22 12:47 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the converter is too tight (low stall):
ragged idle in gear
fights the brakes
stronger shock to the axle on shifting > loss of traction
Boffin Emeritus
Re: Cam and torque converter question [Re: polyspheric] #3092561
11/08/22 01:30 PM
11/08/22 01:30 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Put one of the small Howards solids in it.
Re: Cam and torque converter question [Re: B1MAXX] #3098141
11/29/22 04:31 PM
11/29/22 04:31 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Re: Cam and torque converter question [Re: 6PAX] #3098496
11/30/22 07:41 PM
11/30/22 07:41 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I also like the old MP.528 solid. I'm running it in my 440 Shortram motor. I use the factory hi stall convertor with it and it works very well.
Re: Cam and torque converter question [Re: 6PAX] #3098577
12/01/22 05:31 AM
12/01/22 05:31 AM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
racer brown for the 528 cam
other choice would be the 280 /474 hyd mopar , do NOT use the 284 / 484 for this combo !
