WIX 51607 Filter
#3088936
10/24/22 08:01 PM
10/24/22 08:01 PM
Posts: 28,576 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
What does this fit other than 1994-2002 CTD in Dodge Trucks. Anyone know other applications? I found some in the back of a cabinet and no longer have a CTD. Was going to give them to a friend who has lots of stuff he services but don't know what else they can be used on.
Re: WIX 51607 Filter
[Re: NITROUSN]
#3089144
10/25/22 03:59 PM
10/25/22 03:59 PM
Andrewh
https://www.wixfilters.com/Lookup/FilterBySize.aspx?catid=3&styleid=7look up 1-16 for the thread. it will list other filters that use that thread. you can then find the gasket id and od and see what other filters use the same thread and gasket. check those numbers on what you could use those filters on instead. seems the 2020 6.7 ram uses a simlar filter.
