Re: It's a turd, what to look for?
[Re: parksr5]
#3088903
10/24/22 05:06 PM
10/24/22 05:06 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Dwayne spec'd the new cam for this combination, out of respect for him, I didn't post up the exact specs of the new cam. If he's okay with me posting them, I'll gladly share them.
You can post them if you like, especially since everyone is so sure that it’s wrong. Even though that same cam(and a bigger one) has already gone mid-11’s in a similar combo. A cranking compression test would help shed some light on that situation.
[Re: krautrock]
#3088906
10/24/22 05:11 PM
10/24/22 05:11 PM
Posts: 888 Oh
parksr5
Oh
was the "301" intake and Edelbrock 800 carb on the motor on the dyno??
looks like your TCI converter is supposed to be about 1500rpm higher than stock. is it flashing to 3500rpm?? Yes, both the intake and 800 carb were run on the engine on the dyno. I feel that the converter was not flashing at 3500rpm but, not too much lower.
[Re: lewtot184]
#3088907
10/24/22 05:14 PM
10/24/22 05:14 PM
Posts: 888 Oh
parksr5
Oh
IMO i wouldn't use that xe274 cam with stock manifolds, and definitely wouldn't use the 250@.50" with manifolds. that being said losing about .25 of a second with manifolds vs the headers does make some sense. with the "250" cam put the headers back on. you need the separation of the exhaust pulses plus the have more volume. i also i would take a very serious look at fuel delivery. dumb things can happen between the tank and carb; cracked hose, pump push rod, inadequate pump, etc. my experience with those 800 carbs has been they are more likely to be rich than lean as they come out of the box. Correct, the xe274 cam is not really set up for stock manifolds but, I wasn't unhappy with the results when I tried it. About what I would have thought. The headers will not be going back on as I'm interested in the FAST class, I've been making changes to move in that direction. The fuel delivery issues are up on the list of things to check.
[Re: parksr5]
#3088923
10/24/22 06:50 PM
10/24/22 06:50 PM
Posts: 6,135 Melbourne , Australia
LA360
This is more a general question, do the F.A.S.T guys dyno their engines with their exhaust manifolds with part of the exhaust?
Alan Jones
[Re: parksr5]
#3089042
10/25/22 08:13 AM
10/25/22 08:13 AM
Posts: 3,916 usa
lewtot184
usa
IMO i wouldn't use that xe274 cam with stock manifolds, and definitely wouldn't use the 250@.50" with manifolds. that being said losing about .25 of a second with manifolds vs the headers does make some sense. with the "250" cam put the headers back on. you need the separation of the exhaust pulses plus the have more volume. i also i would take a very serious look at fuel delivery. dumb things can happen between the tank and carb; cracked hose, pump push rod, inadequate pump, etc. my experience with those 800 carbs has been they are more likely to be rich than lean as they come out of the box. Correct, the xe274 cam is not really set up for stock manifolds but, I wasn't unhappy with the results when I tried it. About what I would have thought. The headers will not be going back on as I'm interested in the FAST class, I've been making changes to move in that direction. The fuel delivery issues are up on the list of things to check. my quickie guess is the engine is in the process of eating the fuel pump push rod. that would account for the majority of power loss. just a first place to look guess.
[Re: parksr5]
#3089044
10/25/22 08:21 AM
10/25/22 08:21 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I can tell you one thing...Dynomax Super Turbo mufflers are great for a nice mellow sound, but flow like garbage. Get a straight through style muffler.
[Re: LA360]
#3089045
10/25/22 08:23 AM
10/25/22 08:23 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
This is more a general question, do the F.A.S.T guys dyno their engines with their exhaust manifolds with part of the exhaust? yes with the ones i have seen.
JAKES AUTOMOTIVE
[Re: JAKE68]
#3089051
10/25/22 09:07 AM
10/25/22 09:07 AM
Posts: 5,159 CT
GTX MATT
CT
So in a nutshell changes are
Ported factory intake instead of the RPM Manifolds with Super Turbos instead of headers and Flowmasters Custom cam instead of XE274 800 AVS instead of 850 HP Holley
Assuming you don’t have a fuel supply issue, if the cam is right and you’re determined to make it work with the manifolds i’d try the RPM again with the 850. Maybe your ported intake doesn’t work that well. If it picks up alot try the AVS to see if it likes it or not compared to the Holley.
I also think Super Turbos aren’t a great choice, but not sure if it matters with the manifolds or not. Thats where I’d go after the intake if you’re determined to make it work.
[Re: an8sec70cuda]
#3089208
10/25/22 09:46 PM
10/25/22 09:46 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
I can tell you one thing...Dynomax Super Turbo mufflers are great for a nice mellow sound, but flow like garbage. Get a straight through style muffler. One of my old street and strip drag cars would pickup .9 ET (12.23 with them on and 11.39 removed) and 9+ MPH (109.4 versus 117.8 with them off with no other changes ) by removing the 2.5 inch pipes with the old Turbo muffs with 2.5 inch O.D. tailpipes that exited in front of the rear tires on my 1969 Dart GTS 440 powered My Duster had a set of the cheaper crimp together Magnaflow 14x7x 3.0 inlet and outlet oval muffs straight through with perforate pipe, it ran 7.01 ET in the 1/8 mile with them on and 6.98 with them off Those muffs were mounted behind the rear end between the 1/4 panels in rear sub frames. That really surprised me and impress me I can't find them anywhere to buy them now
[Re: lewtot184]
#3089315
10/26/22 10:38 AM
10/26/22 10:38 AM
Posts: 55 CT
roadrunner2
CT
Two replies I’ve seen on here that bare looking at. First is the fuel pump push rod. I had this issue with mine. Only lost .125 but killed a ton of speed. Second is the turbo mufflers. Not a good choice for flow especially with a 500” engine. I switched from Pypes Street Pros to their Race Pros and picked up a bunch.
Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’ Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST. 10:1 451” replaced with 14:1 499”.
[Re: LA360]
#3089327
10/26/22 11:14 AM
10/26/22 11:14 AM
Posts: 74,947 U.S.S.A.
JohnRR
U.S.S.A.
This is more a general question, do the F.A.S.T guys dyno their engines with their exhaust manifolds with part of the exhaust? The F.A.S.T. guys that are serious I imagine would ? I'm in the process of restarting my F.A.S.T. build and when it goes on the Dyno it will be with the manifolds I plan to run. I'll also bring my headpipes and a second shorter set if the ones I plan to run won't fit the space allowed.
[Re: moparx]
#3089328
10/26/22 11:22 AM
10/26/22 11:22 AM
JohnRR
U.S.S.A.
how much could the exhaust manifolds be ported ? if that is a possibility, do the FAST guys do anything in addition to having that gritty stuff [i forget the name] pumped through them ? There are things one can do, port matching is a must. The last set of stock manifolds I tweaked for a friends build needed at least an 1/8" of material ground out of the port entrances on at least 2 surfaces to get it to match the gasket. I have a set of reworked A body 383 manifolds that have had as much grinding as can be down withOUT cutting them in half and a piece welded in place where there was an internal divot to clear the flange bolt install. The divot was removed , welded from the outside and the flange tapped for a stud instead of the bolt. After all the work was done they were Jet Hot coated inside and out, I don't know if they were extrude honed. The manifolds were done by the late Greg Gessler. I am going to try to compare them to an untouched set when I dyno to see how much it picks up.
[Re: JohnRR]
#3089531
10/26/22 10:57 PM
10/26/22 10:57 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
...........by the late Greg Gessler.
Crap. Another good one. Sad and sorry to hear
[Re: BSB67]
#3089544
10/27/22 12:23 AM
10/27/22 12:23 AM
Posts: 1,819 South Bend
John Brown
South Bend
Crap. Another good one. Sad and sorry to hear Same here. Greg Gessler did a pair of exhaust manifolds for my FAST 70 Nova small block car. This is the first I had heard of his passing. RIP Greg. -> Greg Gessler obit <-
