Defrost mode 1986 D150
#3087460
10/19/22 12:40 PM
10/19/22 12:40 PM
Posts: 22 NC
psg
NC
I have recently noticed my defrost mode is no longer functioning. To be honest I do not know if it ever worked but I think it did. I have had the truck for a few years and half of the time it was not running because of a major engine upgrade. My orginal 360 is now a happy 360 with new eldebrock intake, cam, headers etc.
The new intake requires a repositioning of the AC compressor and I have not done that as of yet. So here is the question, with the A/C no longer functioning and the electrical and and all hoses removed, will that affect the defrost function? I have vacuum to the heat doors because I can physically move them to the open position and push the heat button and they will close. The dash vents are always open and air is moving through them but the defrost mode does not function. I have hot air at my feet and vents but can't get it up on the window and just wonder if the absence of A/C components is at the base of my problems. Any thoughts? tnx psg
Faith in every footstep, faith in every mile
Re: Defrost mode 1986 D150
[Re: psg]
#3087465
10/19/22 12:46 PM
10/19/22 12:46 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#3087474
10/19/22 01:13 PM
10/19/22 01:13 PM
Posts: 22 NC
psg
NC
With that then, any thoughts on my next step, is it likely behind the controls or at the defrost door? Maybe you can also identify the module or "can" in the heater return line hose in the engine compartment that has a vacuum line attached to it. It doesn't seem to be doing anything. tnx psg
[Re: psg]
#3087477
10/19/22 01:22 PM
10/19/22 01:22 PM
Posts: 15,806 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Have you seen the duct work going to the defrost vents? These could have come apart.
Facts are stubborn things.
[Re: psg]
#3087530
10/19/22 04:26 PM
10/19/22 04:26 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
check the back of your heater control. There is a series of small vacuum lines going there, that have a rubber block holding the lines. This deteriorates. I had the same problem with an '86 I had.
1981 Dodge D150 360 auto
[Re: basketcase]
#3087564
10/19/22 06:33 PM
10/19/22 06:33 PM
Posts: 22 NC
psg
NC
Thanks basket case, I guess it is time to pull more things apart...I was hoping to avoid the process but it seems like a reasonable next step. psg
[Re: Sniper]
#3087585
10/19/22 07:52 PM
10/19/22 07:52 PM
Posts: 2,221 ILLINOIS
volaredon
ILLINOIS
I dunno about trucks, but cars of that era would default to defrost if vacuum was lost to the controls.
I would pull the line off the vacuum can that controls defrost and see if you are getting constant vacuum there, if so the control unit is probably the issue. I was just gonna suggest that. That said I have a project in the garage, an 85 d150.part of the project includes adding "factory" ac to a truck that originally came w/o I have most of 3 factory ac heater boxes to scrounge and cherry pick the best components from to (hopefully) build up 2 "factory ac" boxes among the pile. I say most o, because one housing is busted all to hell probably from rough removal) not done by me, was a swap meet find as it sits) My main concern is can anyone tell me if the gaskets and seals within are available anywhere, whether nos or possibly from one of the aftermarket rubber/weatherstrip places for these trucks?
[Re: Sniper]
#3087605
10/19/22 08:33 PM
10/19/22 08:33 PM
Posts: 10,525 Freeport IL USA
poorboy
Freeport IL USA
I would pull the line off the vacuum can that controls defrost and see if you are getting constant vacuum there, if so the control unit is probably the issue. I agree. Then to carry it farther, if the control valve is the issue, you should be able to remove the vacuum from the control and have air coming out of the defroster ducts, then all you need is temp control. I seldom switch off from defrost during the winter, and normally control the inside temp by fan speed, but usually my winter trips are not very long. For the record, without the AC, the defrost isn't nearly as quick clearing the windshield. The AC removes the moisture from the air that hits the glass, that dry air clears the glass 2x as fast. That was the main reason AC became common on vehicles, faster clearing of the windshield in defrost mode. I believe that the Government required (or mandated) AC to be included at one point in time.
[Re: poorboy]
#3088949
10/24/22 08:52 PM
10/24/22 08:52 PM
Posts: 22 NC
psg
NC
So I dived into the climate control and found the two vacuum line groups at the back of the control module. Everything seemed fine. I followed the left group which are all black lines that lead to a connector which attaches to additional black lines. It turns out there is one line, which is short and not connected to anything, open and does not appear broken or torn at the end. I cannot find anything to connect it to. It is only about 4-5 inches long. Any thoughts? Is there a circuit diagram for these lines?
"I would pull the line off the vacuum can that controls defrost and see if you are getting constant vacuum there, if so the control unit is probably the issue."
I am not sure which can works the defrost. I have only found two behind the glove box.
