OBD1 Fuel Sync 92Ramcharger #3085050
10/11/22 09:56 AM
10/11/22 09:56 AM
NW PA
V10nacuda Offline OP
NW PA
Any lifelong Mopar Techs that remember the OBD1? ...Fuel Sync Question..
Swapped a 5.2 from another truck that was getting 15mpg. Did the timing chain and Dist because one of the tabs broke while disassembling. I marked everything exactly & it runs well EXCEPT MILEAGE!! I discovered this Fuel Sync procedure using a meter. I see there is a procedure using a good scan tool, but not sure if there is something for OBD1....
So for you guys that have done this is there an option for an OBD1 truck and is the meter procedure as accurate as the scan tool... Or any other suggestions?
Re: OBD1 Fuel Sync 92Ramcharger [Re: V10nacuda] #3086107
10/14/22 09:11 PM
10/14/22 09:11 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Im not a lifelong tech- but- only current way i know of to do fuel sync in snap on "mt2500 red brick" with the appropriate year insert. maybe the solus does it too? lots of money though....
Re: OBD1 Fuel Sync 92Ramcharger [Re: jerseybud] #3086134
10/15/22 01:35 AM
10/15/22 01:35 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just read this post and I’m interested in this procedure too, I have the Solus Ultra Snapon scanner box, didn’t get the manual. My Ram van went from 15 down to 12 after going back thru the trans.? thinking about fuel trim thing, but not knowing about this fuel sync thing. I hope someone comes on with answers to your question.
Re: OBD1 Fuel Sync 92Ramcharger [Re: cudaman1969] #3086212
10/15/22 11:14 AM
10/15/22 11:14 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
What motor are you talking about? Pre 92/93(depending on what motor) are throttle body injection. You can set the fuel sync on the magnum motors like this:
TDC #1 ON THE COMPRESSION STROKE Set the distributor like this...
Re: OBD1 Fuel Sync 92Ramcharger [Re: Moparite] #3086409
10/15/22 11:48 PM
10/15/22 11:48 PM
NW PA
NW PA
Doesn't that procedure just get you in the ballpark, just enough to get it running? That was my impression about that procedure. Yes it's a Magnum engine 92 to the exact. I just thought there was a more accurate way of doing it. Like some of said if it was OBD2 you could actually do it with an expensive Snap-On scanner. With it being OBD1 what's the alternative?
Re: OBD1 Fuel Sync 92Ramcharger [Re: V10nacuda] #3086433
10/16/22 09:23 AM
10/16/22 09:23 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Well this procedure is in the service manual for a 96. I believe the later ones you can use a scanner that will take into consideration the wear such as timing chain and distributor gear wear to be accurate. I have not heard of any other explanation.
Re: OBD1 Fuel Sync 92Ramcharger [Re: V10nacuda] #3086483
10/16/22 01:54 PM
10/16/22 01:54 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I don't see how it could matter much. Cam signal is just an on/off deal once per distributor rotation. Don't see how injectors being out of phase with it by a degree or two could make much difference. Lots of older v8 fuel injection systems were batch fired one bank all at the same time.
In your deal the motor went from one veh to another, diff trans, tires, etc. Lots of variables other than just fuel sync.
Re: OBD1 Fuel Sync 92Ramcharger [Re: mgoblue9798] #3086690
10/16/22 10:55 PM
10/16/22 10:55 PM
NW PA
NW PA
I wasn't aware that older systems functioned that way...I'm just trying to narrow it down.. I'm just angry because same motor same transmission and a lighter vehicle by about #800 to a thousand pounds I was hoping not to lose mileage with upcoming gas prices!
Re: OBD1 Fuel Sync 92Ramcharger [Re: V10nacuda] #3086722
10/17/22 06:51 AM
10/17/22 06:51 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
This is why i asked for the year. If it's a magnum you need to set the fuel sync, If it was a LA there is no setting it because it's throttle body injection.
Re: OBD1 Fuel Sync 92Ramcharger [Re: Moparite] #3086821
10/17/22 11:46 AM
10/17/22 11:46 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Is the rear end ratio the same in both trucks?
Re: OBD1 Fuel Sync 92Ramcharger [Re: stumpy] #3086852
10/17/22 12:57 PM
10/17/22 12:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I just did my 01 5.9, I set distributor close to where it showed in book then used the Snapon scanner to sync it (it did it on its own) seems to run better. I just overhauled the trans and Van went from 15-16 to 12 mpg (4.10 rear) we’ll see how it does now. Also I changed nothing on the engine other than trans. One other thing I had to adjust the cable to the pressure lever (shifting hard)
Re: OBD1 Fuel Sync 92Ramcharger [Re: stumpy] #3086868
10/17/22 02:16 PM
10/17/22 02:16 PM
NW PA
NW PA
Yes
Re: OBD1 Fuel Sync 92Ramcharger [Re: stumpy] #3086869
10/17/22 02:17 PM
10/17/22 02:17 PM
NW PA
NW PA
That's crazy it lost that by just a trans rebuild?
Re: OBD1 Fuel Sync 92Ramcharger [Re: Moparite] #3086871
10/17/22 02:23 PM
10/17/22 02:23 PM
NW PA
NW PA
Originally Posted by Moparite
Quote
92 RC to a 93 Dakota same trans and gear... Both Magnum motors
Re: OBD1 Fuel Sync 92Ramcharger [Re: V10nacuda] #3086988
10/17/22 09:34 PM
10/17/22 09:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Well I might have found the problem and it could be yours too, crank sensor. I removed it during trans in and out, I did have trouble with this sensor before with losing power. I’ll go buy a new one from Dodge, the auto parts ones are junk from what I hear.
