Re: video of test drive around block [Re: HardcoreB] #3085398
10/12/22 12:06 PM
10/12/22 12:06 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Originally Posted by HardcoreB
Nice to see the car up and running again!
Thank you.Sometime life gets in the way but I do what I can.
Re: video of test drive around block [Re: Clanton] #3085403
10/12/22 12:12 PM
10/12/22 12:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got a bunch of brass set screws[150 pc] from McMaster Carr for 30$ so I have plenty of jets to adjust the afr and already put in some intermediate jets to startinstead of the air bleeds or emulsion.jsut an fyi.
Re: video of test drive around block [Re: Clanton] #3085445
10/12/22 01:42 PM
10/12/22 01:42 PM
moparx Online content
moparx  Online Content
pretty cool test ride, even if i only got to ride along in the camera. boogie
beer
Re: video of test drive around block [Re: moparx] #3085727
10/13/22 10:48 AM
10/13/22 10:48 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
beer
I enjoy the drive also but my interest was afr most of all then to watch the vac/boost reading and throttle opening for drivability and if you noticed I get boost when the sec's start to open about 1/4 throttle[linkage ratio]. any input on this?
Re: video of test drive around block [Re: Clanton] #3085954
10/14/22 12:42 PM
10/14/22 12:42 PM
i wish i could offer you some input, but i have zero supercharger experience.
however, i would make a "guess" that pulley ratio would have something to do with that.
are you running 1:1 or a slight overdrive ratio ?
if the AFR was reasonable when the boost came in, i think i would be happy with that. provided it stayed in the proper range with no detonation when floored as well.
i'm trying to learn all i can about this, as i would like to use an 8-71 on an early 392 to put in my "eternal project", that 33 dodge humpback delivery.
Cab knows way more about this than i probably ever will.
beer
Re: video of test drive around block [Re: moparx] #3086005
10/14/22 02:18 PM
10/14/22 02:18 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
beer
My pulley % is 10% OD 14# I have the afr lean to keep the plugs clean driving to the staging lanes but now I need some fuel to drive it around the
neighborhood and be safe under more driving conditions at the track the main[3rd circuit] jets made the afr 11.5 to 1 so I will take from the main what the intermediat jets use.I need to track the rpm drop going from 1 to 2nd part throttle and I think it was 1500 rpm so on a shift it would go from 3500 rpm to 2k with 3.73 gear 28" tire 5k stall 9.5" vert
Re: video of test drive around block [Re: Clanton] #3086017
10/14/22 02:48 PM
10/14/22 02:48 PM
too bad you aren't closer, i would like to convince you to try a pair of Thermo-Quads. biggrin
i really like those, and it would be fun to tune those on your combination.
i want to try a set on an 8-71 on an early 392. that is the setup i would like to use in my 33 dodge humpback delivery.
beer
Re: video of test drive around block [Re: moparx] #3086184
10/15/22 10:26 AM
10/15/22 10:26 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
beer
That sounds like a lot of work to fit/test a carb that is small for me[linkage,fuel line...] not even getting into the powervalve side on those carbs to adapt them.I sold a box of about 8 to a PA member a long time ago for under 100$ I believe.
Re: video of test drive around block [Re: Clanton] #3086535
10/16/22 03:10 PM
10/16/22 03:10 PM
man, i would have jumped on that deal in a heartbeat ! [i'm always too late and a dollar short !]
you are right about how much work it would be to fit up a pair of those carbs. plus, the tuning would certainly be "entertaining" to say the least.............
beer
