SCAT versus Molnar versus Oliver Rods
#3085805
10/13/22 07:12 PM
10/13/22 07:12 PM
Posts: 173 California
GTXMEX
California
Re: SCAT versus Molnar versus Oliver Rods
[Re: GTXMEX]
#3085809
10/13/22 07:45 PM
10/13/22 07:45 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Oliver are the best of the group you listed and Molnar are the best budget rod. I ordered mine (Molnar) last November and I’m still waiting.
[Re: GTXMEX]
#3085827
10/13/22 08:49 PM
10/13/22 08:49 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
Actually all of the above! Scat for my 500 hp motor, Molnar for the 713 hp motor and Oliver for the 1050 hp motor.
[Re: markz528]
#3085832
10/13/22 09:13 PM
10/13/22 09:13 PM
Posts: 9,791 MI, usa
dvw
MI, usa
I've been very happy with Molnar's quality. The machining and weights were spot on. My 580" with 4.5 stroke motor sees 7200 rpm every pass. I did spin a bearing last year. But it had nothing to do with the rod or crank. I went right back to the same parts. For info read here; http://www.cpbulletpistons.com/tom-molnar-rods-review.phpDoug
[Re: GTXMEX]
#3085834
10/13/22 09:17 PM
10/13/22 09:17 PM
Posts: 4,205 New York
polyspheric
New York
Rod quality and price are sold by horsepower levels, but it's not really relevant. The factors (NA only) are 1:1 with reciprocating weight (piston etc. + upper rod 1/2) and inverse to the square of peak RPM. What breaks the rod (assuming the bolts hold up) is closing the throttle as the piston passes over TDC even with the spark off.
Boffin Emeritus
[Re: moparx]
#3085966
10/14/22 01:03 PM
10/14/22 01:03 PM
Posts: 2,603 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Oliver rods are made in America, I assume are much better and I assume are 3 times the price. So I don't think this is a fair comparison.
2011 Drag Pak Challenger
[Re: rickseeman]
#3085976
10/14/22 01:27 PM
10/14/22 01:27 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Oliver rods are made in America, I assume are much better and I assume are 3 times the price. So I don't think this is a fair comparison. I have heard they are some of the best. However the 501" Small Block Mopar build that Ron Silva did(the thread is on here somewhere) made me think otherwise. He had all kinds of problems with crooked bores and maybe more on his oliver rods.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: rickseeman]
#3085977
10/14/22 01:27 PM
10/14/22 01:27 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
I am not so sure I would endorse the use what is available mantra. We did and it bit us in the [censored] in the Vette. We needed to freshen up th engine in it and had been waiting on Cariilo Aluminum rods for the engine and they were not going to make it in the timeframe we needed to make the race in Norwalk. So the decision was made to go back to what we had always used before, a big name brand aluminum rod company that had been in this engine for YEARS. The hesitation was they had been purchsed by an equity company not so long ago, one hat has been buying up aftermarket parts manufacturers for awhile. Well after a few pulls on the dyno and two passes later here is the result of using what was available in a time frame VS waiting. FWIW the rings are still loose on the piston, the pin if still free on the small end, other than the hearing being folded up it the surface of it looks new, as it always has. Also two others were found with cracks. Again these were brand new rods with a few pulls on the dyno and 2 passes on them.
[Re: GTXMEX]
#3086122
10/14/22 10:51 PM
10/14/22 10:51 PM
polyspheric
New York
IIRC a while back China supplied the raw forging and the final machining was done here, so fit & finish may be excellent. So...? China is not as thorough about inclusions (slag, other material not intended to be included, in fairly large particles) if these occur at a highly stressed point...BOOM.
Boffin Emeritus
[Re: Al_Alguire]
#3086229
10/15/22 12:06 PM
10/15/22 12:06 PM
Posts: 1,262 New York, USA
Chargerfan68
New York, USA
I am not so sure I would endorse the use what is available mantra. We did and it bit us in the [censored] in the Vette. We needed to freshen up th engine in it and had been waiting on Cariilo Aluminum rods for the engine and they were not going to make it in the timeframe we needed to make the race in Norwalk. So the decision was made to go back to what we had always used before, a big name brand aluminum rod company that had been in this engine for YEARS. The hesitation was they had been purchsed by an equity company not so long ago, one hat has been buying up aftermarket parts manufacturers for awhile. Well after a few pulls on the dyno and two passes later here is the result of using what was available in a time frame VS waiting. FWIW the rings are still loose on the piston, the pin if still free on the small end, other than the hearing being folded up it the surface of it looks new, as it always has. Also two others were found with cracks. Again these were brand new rods with a few pulls on the dyno and 2 passes on them. Now this looks similar to the destruction in Steve Morris’ 4000+ HP engin in his wagon. I’m sure you’ve seen that on his channel…..more severe with much smaller shrapnel. But his small rod end still attached to piston and freely moving just like yours. Interesting. Wonder if they are the same manufacturer. Sorry for your carnage.
[Re: Sammy]
#3086253
10/15/22 01:28 PM
10/15/22 01:28 PM
rickseeman
Stuttgart, Arkansas
I spin my little smallblock and make over 1000 hp so I'm not taking any chances on any Chinese part. Oliver rods are tge only way to go but damn, they are very costly. When building a 1000 hp small block I can't believe you're worried about the cost of rods.
[Re: Sammy]
#3086404
10/15/22 11:05 PM
10/15/22 11:05 PM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I spin my little smallblock and make over 1000 hp so I'm not taking any chances on any Chinese part. Oliver rods are tge only way to go but damn, they are very costly. But not as costly as part of a rod sticking out of a block. I could only get Molnar's 3000 hp rated H beams in 7.00 length. Cost me a few hundred extra, but considering I will be spinning a 2400 bob weight 4.560 stroke to 7400, probably my best bet? They are heavy, about 900 grams, so maybe it worked out like it should.
