Re: I like these wheels BUT ... [Re: slantzilla] #3086332
10/15/22 05:51 PM
10/15/22 05:51 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Another thing I don't like about all of these black anodized wheels is that they fade to brown over time from being out in the sun light.
The fading isn't from sunlight, its from cleaners and detergents - which basically remove the anodizing - its a chemical thing.
As for the wheels in question, they're powdercoated, not anodized.
Quote
the width/offset of my 15X10s is off. The wheel itself is almost 11" wide
Maybe you should go measure a bunch of other wheels, stock or otherwise. The width is ALWAYS measured inside the beads and the offset is taken from that dimension. So in your case the wheels will measure 10" between the inside of the beads and a 5-1/2" backspace will be 6" from the mounting face to the outside edge of the wheel.
Re: I like these wheels BUT ... [Re: Stanton] #3086362
10/15/22 08:24 PM
10/15/22 08:24 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
11" is the inside measurement.
They are cheap Chinese wheels. You get what you pay for.
Re: I like these wheels BUT ... [Re: slantzilla] #3086406
10/15/22 11:20 PM
10/15/22 11:20 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
And there you have it up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: I like these wheels BUT ... [Re: BloFish] #3086448
10/16/22 10:39 AM
10/16/22 10:39 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Well of course ! Thanks for your valuable input.
Re: I like these wheels BUT ... [Re: Stanton] #3086458
10/16/22 11:29 AM
10/16/22 11:29 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Originally Posted by Stanton
I'm also thinking of the possibility of making a quick and dirty turntable, position the wheel, position a die grinder with a flap wheel and sand off the powdercoat on the rim. Then go with progressively finer flap disks till its to my satisfaction. You'd need to prep the surface for paint so you may as well just stick at it down to bare aluminum and polish it. Just a thought.
Polishing aluminum is polishing aluminum. I think the simple turntable idea is a good idea. Figure out how you're going to set the edge(s) of your polished area. Be careful and get after it.
Do you happen to have an old aluminum rim you can test your idea(s) on?
Re: I like these wheels BUT ... [Re: Fat_Mike] #3086459
10/16/22 11:43 AM
10/16/22 11:43 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: I like these wheels BUT ... [Re: Neil] #3086460
10/16/22 11:59 AM
10/16/22 11:59 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Originally Posted by Neil
That's all fine and dandy but I don't want to strip the whole wheel. Besides, a good powdercoat stripper is as close as your nearest auto supply ...
Re: I like these wheels BUT ... [Re: Stanton] #3086491
10/16/22 02:08 PM
10/16/22 02:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Look at the bright side, if you screw them up or don't like them when you're done, you're not out much. All 4 of mine with front runners, slicks, and lug nuts were less then $800.
