Re: OBD1 Fuel Sync 92Ramcharger
[Re: cudaman1969]
#3086212
10/15/22 11:14 AM
10/15/22 11:14 AM
Posts: 983 rust belt
Moparite
rust belt
What motor are you talking about? Pre 92/93(depending on what motor) are throttle body injection. You can set the fuel sync on the magnum motors like this: TDC #1 ON THE COMPRESSION STROKE Set the distributor like this...
[Re: V10nacuda]
#3086722
10/17/22 06:51 AM
10/17/22 06:51 AM
Moparite
rust belt
In your deal the motor went from one veh to another, diff trans, tires, etc. Lots of variables other than just fuel sync.
This is why i asked for the year. If it's a magnum you need to set the fuel sync, If it was a LA there is no setting it because it's throttle body injection.
[Re: stumpy]
#3086868
10/17/22 02:16 PM
10/17/22 02:16 PM
Posts: 767 NW PA
V10nacuda
NW PA
[Re: stumpy]
#3086869
10/17/22 02:17 PM
10/17/22 02:17 PM
Posts: 767 NW PA
V10nacuda
NW PA
That's crazy it lost that by just a trans rebuild?
[Re: Moparite]
#3086871
10/17/22 02:23 PM
10/17/22 02:23 PM
Posts: 767 NW PA
V10nacuda
NW PA
This is why i asked for the year. If it's a magnum you need to set the fuel sync, If it was a LA there is no setting it because it's throttle body injection. 92 RC to a 93 Dakota same trans and gear... Both Magnum motors
[Re: V10nacuda]
#3086988
10/17/22 09:34 PM
10/17/22 09:34 PM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
That's crazy it lost that by just a trans rebuild? Well I might have found the problem and it could be yours too, crank sensor. I removed it during trans in and out, I did have trouble with this sensor before with losing power. I’ll go buy a new one from Dodge, the auto parts ones are junk from what I hear.
