Re: tiei down car [Re: BloFish] #3085386
10/12/22 11:44 AM
10/12/22 11:44 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Originally Posted by BloFish
Keep it in neutral until strapped down tight, then place it in park. up
This is what i do.
Re: tiei down car [Re: racerx] #3085405
10/12/22 12:14 PM
10/12/22 12:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I take at least my drivers door off before winching it in the trailer so I have access to the shifter. If you have glass doors why not. My Cuda has steel doors that were gutted and I always removed it as well. Easy enough to do to gain access. I think if you mostly tow locally it likely does not matter at all. However cross country stuff IMO putting it in park is a good idea. We also use chassis stabilizers on the dragster and all tube chassis cars. Shock take a beating towing as does the chassis. Dragster gets two bladders door car/truck gets one under 4 link crossmember.
Re: tiei down car [Re: Al_Alguire] #3085449
10/12/22 01:47 PM
10/12/22 01:47 PM
moparx Online content
moparx  Online Content
are tie downs being used on the tires or the chassis ?
i have noticed lately that new cars are being transported with the tie downs looped through the wheels [when possible] or over the tires.
any opinions on these methods ?
beer
Re: tiei down car [Re: moparx] #3085506
10/12/22 03:34 PM
10/12/22 03:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
beer
If it's a standard passenger car, no big deal being strapped down at the wheels. I strap down at the chassis to avoid shock travel as much as possible (adjustable shocks).
'63 Dodge 330
11.19 @ 121 mph
Re: tiei down car [Re: dragon] #3086147
10/15/22 07:10 AM
10/15/22 07:10 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Some years ago I read a suspension book that recommended blocking the chassis on frequently trailered vehicles. When you tie it down it moves with the trailer not independent of it and to keep from damaging tuned suspensions .And I suppose these were manual trans cars. Sounds like a PIA but it wouldn't matter if the car was in neutral. twocents
BTW next time I'll try tie down then put in park! whistling
Re: tiei down car [Re: dragon] #3086188
10/15/22 10:31 AM
10/15/22 10:31 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I’m sure I’ll get called out as anecdotal, but, techs would momentarily engage park, to “fix”, stuck governor valves on A470’s.
Re: tiei down car [Re: Leigh] #3086199
10/15/22 10:53 AM
10/15/22 10:53 AM
A727Tflite Offline
A727Tflite  Offline
Actually this was done way back before the 470. I’m interested in why you mention this here.
Re: tiei down car [Re: A727Tflite] #3086208
10/15/22 11:07 AM
10/15/22 11:07 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Because the pawls or the supports didn’t break. Did they get damaged, don’t know, but we didn’t stock either.
Re: tiei down car [Re: Leigh] #3086256
10/15/22 01:34 PM
10/15/22 01:34 PM
A727Tflite Offline
A727Tflite  Offline
Understood now.
For clarification when throwing it in park at speed the pawl ratcheted off the support and simply vibrated the governor valve and weights and usually freed them up. Towing in park with a loose car had the vehicle weight loading and unloading the support putting all the load into the pawl pivot/housing.
Rail car was the worst - since the vehicles were not loaded on an angle like truck transport.
