Page 2 of 3 1 2 3
Re: Damaged cylinder head repair [Re: CSK] #3082851
10/03/22 02:09 PM
10/03/22 02:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As said EASY fix and by all means replace ALL the valves.
Re: Damaged cylinder head repair [Re: Al_Alguire] #3082860
10/03/22 02:26 PM
10/03/22 02:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Yes, after further thought , ALL of the valves not just the intake
Re: Damaged cylinder head repair [Re: CSK] #3082863
10/03/22 02:33 PM
10/03/22 02:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted by csk
Originally Posted by fast68plymouth
Well, I see what’s 99% likely the cause of the failure.
Yep, & replace ALL the intake valves, new springs & double check PV clearance
My guess is, it’s the #1 reason for broken intake valves.
On the plus side........ I’m liking the complete lack of carbon build up in that intake bowl.
Re: Damaged cylinder head repair [Re: fast68plymouth] #3082895
10/03/22 02:59 PM
10/03/22 02:59 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Remember some broken pieces could have gone into other cylinders Even on the other side. My son had a 1/4 inch chunk of an Edelbrock intake valve in number three cylinder end up stuck in number 4 or 6 and pinch a ring.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Damaged cylinder head repair [Re: fast68plymouth] #3083030
10/03/22 08:49 PM
10/03/22 08:49 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Ok. Give me the good or bad news. The spring looks like new in that it was not moving around same for the keepers and retainer. No metal scuffing at all. I'm thinking the valve gave up. Or # 5 rod bearing went but it still had 60# oil pressure.
America First!
Re: Damaged cylinder head repair [Re: carnut68] #3083053
10/03/22 10:08 PM
10/03/22 10:08 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Don't know what the top of the piston w/ the broken valve looks like, but I'd be looking very closely at all of the piston tops for any indications of other valves possibly coming into contact, too. scope
2021 Challenger 6.4L Scat Pack 1320 (2022)
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008)
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Damaged cylinder head repair [Re: Brad_Haak] #3083060
10/03/22 10:28 PM
10/03/22 10:28 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
It's bashed up and has a hole were the valve stem went thru it. The cylinder wall looks fine. #7 did,but when? Probably after #5 broke.
America First!
Re: Damaged cylinder head repair [Re: carnut68] #3083171
10/04/22 10:08 AM
10/04/22 10:08 AM
So. Burlington, Vt.
So. Burlington, Vt.
This pic tells the tale:
Re: Damaged cylinder head repair [Re: fast68plymouth] #3083172
10/04/22 10:12 AM
10/04/22 10:12 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
aha! i was wondering if you were referring the shiny and kinda marred edges of the other intake valve.
Re: Damaged cylinder head repair [Re: krautrock] #3083177
10/04/22 10:24 AM
10/04/22 10:24 AM
So. Burlington, Vt.
So. Burlington, Vt.
I have some BBC heads here now that have a few valves showing the same thing.
There’s really only one way to get that shiny ring.
Re: Damaged cylinder head repair [Re: fast68plymouth] #3083179
10/04/22 10:35 AM
10/04/22 10:35 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
A very intimate relationship resulting in a shiny ring. Then everything crumbles after too much hitting and abuse.
Sounds like a lifetime movie
Re: Damaged cylinder head repair [Re: INTMD8] #3083183
10/04/22 10:46 AM
10/04/22 10:46 AM
So. Burlington, Vt.
So. Burlington, Vt.
The thing is, the fact that it’s showing contact for the full diameter means the valve is rotating, since nothing would touch all the way around otherwise.
So, the rotation means there is some degree of the stem flexing in different directions as the valve rotates around.
Like bending a coat hanger back and forth......... it can only flex so many times before the material is fatigued and breaks.
In my mind, the question as to why the valve broke has been answered.
Also, the contact is not the result of valvetrain control problems.
That’s not to say there couldn’t be some of that as well, but that won’t result in contact with an intake valve.
When you float an intake valve, even if it’s lagging way behind the cam....... at IVC, the piston is nowhere near TDC.
So, the only way to get the shiny ring on an intake valve is....... inadequate clearance during the IVO period.
It’s not all that uncommon for me to see this condition when I’m reconditioning heads.
Re: Damaged cylinder head repair [Re: carnut68] #3083686
10/05/22 10:27 PM
10/05/22 10:27 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Any suggestions who to send the head to get it fixed?
America First!
Re: Damaged cylinder head repair [Re: carnut68] #3083741
10/06/22 09:09 AM
10/06/22 09:09 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Hopefully it’s a quality casting. I sent my leaky W5 head to a guy in Iowa that had brought sprint car heads back from the dead. My head basically crumbled as he tried to weld it.
Re: Damaged cylinder head repair [Re: carnut68] #3083757
10/06/22 10:00 AM
10/06/22 10:00 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Indy would be my first call, considering they did lots of cylinder head repair work in the past. Whether the new owners do any of that, you'll only know by asking.
Re: Damaged cylinder head repair [Re: Brad_Haak] #3083772
10/06/22 10:56 AM
10/06/22 10:56 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Indy still does repair work and it is second to none. I had a block fixed and if you didn't look real close you could not tell it was ever hurt. They also fixed my B1 heads last year and they look perfect.
Re: Damaged cylinder head repair [Re: carnut68] #3083901
10/06/22 07:49 PM
10/06/22 07:49 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
It's an Indy head. So that's good to hear. Thanks.
America First!
Re: Damaged cylinder head repair [Re: pittsburghracer] #3083926
10/06/22 09:25 PM
10/06/22 09:25 PM
PA.
"Little"John
"Little"John
PA.
Originally Posted by pittsburghracer
You won’t know till it’s taken apart and stripped but I’m betting it’s fixable. Jump on it and get it to a shop before everyone else. Winters coming. Indy may even fix it.
Wow I suggested Indy 10-1-22. Lol 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Damaged cylinder head repair [Re: pittsburghracer] #3083950
10/06/22 11:13 PM
10/06/22 11:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
We don’t listen to old guys! laugh2 …..all kidding aside it’s a great time we live in when you can actually recommend Indy for something.
Re: Damaged cylinder head repair [Re: carnut68] #3084164
10/07/22 10:33 PM
10/07/22 10:33 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
What about Brett Miller? He's within reasonable driving distance.
America First!
Page 2 of 3 1 2 3
