2006 5.7 lifter "tick"
#3083521
10/05/22 11:29 AM
10/05/22 11:29 AM
Posts: 2,914 Calgary, Alberta Canada
a12rag
So, just finished a 1800mile (3,000km) trip in my 2006 Magnum RT AWD . . . had changed oil/filter prior to the trip . . . now I notice I can hear "faint lifter tick" . . . never did this before. I have 237k km (147,265miles) on it, original, never been apart, always change oil/filter at 3k miles (5k km) . . . so am I correct in thinking I might have bad lifter that is taking out the cam ??? Oil pressure still good as always been (50psi at anything over 1300-1500 rpm) . . . just wondering if I need to be concerned ?? Time to change cam/lifters, etc . . .??
Thanks,
Mark
Re: 2006 5.7 lifter "tick"
[Re: a12rag]
#3083530
10/05/22 11:55 AM
10/05/22 11:55 AM
Posts: 3,508 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I don't know if this will help you but I have a 183,000 mile 2007 Magnum R/T I have driven since it was new.
It has had a lifter tick off and on for many years.
[Re: a12rag]
#3083651
10/05/22 08:06 PM
10/05/22 08:06 PM
Posts: 15,806 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thanks,
Mark Do you feel certain it's not exhaust? Also, there's some that swear by using different oil brand such as Red Line or Amsoil to stop a faint one. If it doesn't bother you I bet you can drive thousands more miles without issue though.
Facts are stubborn things.
[Re: 5thAve]
#3084279
10/08/22 11:47 AM
10/08/22 11:47 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The bad lifters was a problem with hemis newer then that. I think the biggest thing with that year range was more exhaust manifold leak related and things like dropped valve seats and broken valve springs which would cause problems more noticable then a tick, '09 and up with Eagle Heads. I'd keep driving and doing your maintenance.
[Re: AndyF]
#3084642
10/09/22 08:06 PM
10/09/22 08:06 PM
Posts: 20,463 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I drove a new Challenger rental car with a 5.7 a few years ago and it had an engine tick if you listened for it. Minor, but it was there.
[Re: a12rag]
#3085521
10/12/22 04:46 PM
10/12/22 04:46 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I have had people insist their hemis have lifter tick and it's fuel injectors and coil packs firing. NOT saying that's the case with everyone's here.
[Re: a12rag]
#3095064
11/17/22 07:04 PM
11/17/22 07:04 PM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
Yeah . . . I am more inclined to say it is injector noise . . . as said before, doesn't do it all the time . . . and as such, just going to not worry about it . . . everything else on car has checked out perfect, so drive on ! My 2012 Challenger R/T had the "Hemi tick" all the time I owned it - from 2011-2016. I sold the car with 7,xxx miles on it & never had it looked at - seemed futile after all the things I read back then. Our 2017 Ram Hemi will tick on a cold start in cold weather, but then goes away after about 10-15 minutes of driving. What is it - I don't know, but it sounds like lifters. Now my 2016 300 with the 3.6L does this ALWAYS on cold starts, & it's much noisier in cold weather like now. I've had 2 different dealers look at it & they claim the lifters & motor are fine - "normal." And the 3.6's are notorious for having bad lifters/rocker arms??? I think sometimes opening an OE motor leads to more problems than you had going in. My 300 I bought was certified used - so 7 years & 100,000 miles. That's better than the new car powertrain warranty!
