Updates...W/Better Pics
#3082572
10/02/22 08:48 PM
10/02/22 08:48 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
Well, as many know, I have a couple of projects in the works....And I do not watch any TV, and that include football, until it gets too cold anyway.
So as you know, I did get my 70 Cuda running....Took it to the track, made two passes, broke it. Somthing in the valve train, not sure yet. It had the wrong cam in it anyways and I don't think it liked street use, so now, we will be replacing that. Been talking with Tim at FHO, but he moved to Florida, and I suspect he has a lot of work on his hands at the moment. ....So after I get the issue fixed, I have to decide, do I keep it and try and get the power out of it I think it should have, or sell it and go a different route? I did get a data log of the run, learned a few things...
The lawn ornament has been getting worked on, and today, it got a well used boosted engine I picked up...Never owned a set of Trick flow heads, and now I have a set of 270's on a 440 based blower engine. It was run on E85 with an 871, and made lots of HP.....just need an intake, a blower, and an oil pump. I got the complete engine minus blower and oiling system.....I even got the E85 carbs...So I will be researching blowers....
I also pulled the rear end out of the lawn ornament, and the Dana has a 4.10 posi...A cast yoke, and a stock stamped steel rear cover...Its getting a spool with 4.10's and a nice support cover aluminum unit, and a billet yoke. The 1/2 studs are also an issue but might have to stay for now.
I also thru some flat black paint on it to keep it from rusting for now...Made a big difference..hopefully dry tomorrow.
And lastly the Duster, never sold it....Still have it, collected all my parts and built a new 400 based engine pictured. Just needs rocker arms, push rods, oil pump and cover....And a good carb or maybe two if someone has a TR they want to part with....I got the new Indy 325's on it..... pump gas....new Bullet cam.
Re: Updates...W/Pics
[Re: Dragula]
#3082640
10/03/22 08:57 AM
10/03/22 08:57 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Looks good in black! What broke in the hemi? Must be a real aggressive grind? Did you sell the other motor from the Duster? Didn't you have a low deck stroker in it before?
[Re: an8sec70cuda]
#3082657
10/03/22 09:40 AM
10/03/22 09:40 AM
Dragula
Looks good in black! What broke in the hemi? Must be a real aggressive grind? Did you sell the other motor from the Duster? Didn't you have a low deck stroker in it before? Not sure on the Hemi...Thinking broken spring again...not sure until I get it apart. I think it hates that cam... The last motor in the Duster was a 440/543 high compression engine, and it ran....Fastest engine I have ever had. Sold it to an offer I could not turn down. Had the car sold twice at least....Then it all went quiet....Built a new pump gas 400/512 out of parts I had. Should run very low 6's in the 1/8th still. Predicting 6.10 or better. More cam, better heads... And the lawn ornament looks a lot better in black....Stuff was starting to rust, had to do somthing, and all my painter buddy's are out of the business' now.
[Re: HardcoreB]
#3083267
10/04/22 03:19 PM
10/04/22 03:19 PM
Dragula
Lot's of irons on the fire for sure, keep on them and good luck! I'd see if Indy has a retrofit roots adapter for the modman. So I can't find any good pics of one. I like that idea as I can fire up the engine on just one carb and check for issues, and then add the blower, but the bolts that hold the supercharger plate on, how big are they? They big enough to hold a full weight roots blower on there? That is a lot of weight, and its being spun by the crank and seeing all that vibration and torque....I am not sure about that option.
[Re: fast68plymouth]
#3083345
10/04/22 06:50 PM
10/04/22 06:50 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
All the projects remind me of my place..We have everything in pieces waiting on parts. Waiting on engine parts led to getting carried away with the truck redo 100%
[Re: n20mstr]
#3085767
10/13/22 02:23 PM
10/13/22 02:23 PM
Dragula
The T&D rockers I ordered for my 400/512 showed up....OMG what works of art they are....So all I need are now are push rods, and a 1050 carb, and she is done and ready to put in the car...Cross one big project almost off the upgrade list....Just need to re-wire the Duster and add a Holley dash to it and that car is ready for racing next year with brand new engine, slicks, and wiring, ....Maybe re-skin the doors in fiberglass if I get time. I have the skins, but never done it before. Still shooting for 5's...
Pulling the Hemi this week, and already ordered a new cam for it...Gawd knows what broke in the valve train on that thing. But if its another intake spring, I might have to really look at T&D Barton rockers for it as well....That would put a hurting on the budget for the lawn ornament 66 Barracuda...
[Re: Dragula]
#3085775
10/13/22 02:51 PM
10/13/22 02:51 PM
Posts: 10,039 MN
JERICOGTX
MN
T&D makes rockers for Comp Cams? Curious, why not 1.6 rockers?
69 GTX
68 Road Runner
[Re: Dragula]
#3086421
10/16/22 04:58 AM
10/16/22 04:58 AM
Posts: 3,023 NY
B1duster
NY
