RB Street Dominator
[Re: moparts]
#3089530
10/26/22 09:56 PM
10/26/22 09:56 PM
Posts: 1,225 Out of the State of Confusion
blue_stocker
New in the box Holley Street Dominator for RB engines with standard ports. Bought this a couple of years back for a project that was sold, $300 USD plus shipping from Savannah, Tenn 38372. If interested PM me here, thanks for viewing and thanks Tom for the ad space, much appreciate...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Re: Set of Direct Connection Mech 6 pack carbs
[Re: blue_stocker]
#3089605
10/27/22 09:59 AM
10/27/22 09:59 AM
Posts: 196 Cent, OH
Mopar.70
Cent, OH
Hate to turn these loose, but needing funds for the next project! Open to reasonable offers.
Set of Direct Connection Mech. Carbs that are in their original boxes. Also comes with progressive linkage, brackets, return spring & mount, coil mount and full rebuild kit for all 3 carbs. These were for a 340 per the box but I think the only difference is the jets, same list numbers as what I run on my 440. Any questions on them reach out, $1,500 plus shipping. PM me here on the board or email to eastern_mule@yahoo.com SOLD
Re: For Sale - Big Block Engine - 4th Quarter
[Re: moparts]
#3090471
10/30/22 12:34 PM
10/30/22 12:34 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
I am selling a NOS mopar Performance cam and lifters this is a hard to find item perfect shape Original box.
Part # P4529318 Duration is 320 lift is 533 Centerline is 106 @ .050 is 272 I am asking 425.00 plus shipping
SOLD .... !
Old car are me......
Re: Edelbrock Torker II 440 Intake
[Re: littleredcoffin]
#3090652
10/31/22 09:51 AM
10/31/22 09:51 AM
Posts: 11,741 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
1962-1971 361-383-413-440 SINGLE POINT IGNITION COMPONENTS ,ALL USA MADE NORS/NOS
2 DISTRIBUTOR LEAD WIRES, BLUE CONNECTOR,$40 EACH 1 DISTRIBUTOR LEAD WIRE,WHITE CONNECTOR $30 NOS VACUUM ADVANCE 2098209 $30 TAN DISTRIBUTOR CAP,MADE IN USA INSIDE,HD,$30 2 ROTORS, 2 POINTS, 1 CONDENSER$25 BLUESTREAK HP DISTRIBUTOR CAP,COPPER INSERT,BAKELITE,$30 CAN COMBINE ORDERS ,PRIORITY MAIL SHIPPING cowgerwilliam035@gmail.com
Hemi Headers
[Re: moparts]
#3091186
11/02/22 02:24 PM
11/02/22 02:24 PM
Posts: 574 Wisconsin
71duster414
Wisconsin
New take offs never ran
TTI polished ceramic coated. I removed these from a 69 hemi roadrunner
$925
hoffmanhhr@gmail.com
M1 intake for RB
[Re: moparts]
#3091945
11/06/22 08:40 AM
11/06/22 08:40 AM
Posts: 2,650 Md.
carnut68
Md.
I have an M1 intake for an RB. No stripped threads it’s been slightly gasket matched. 250plus shipping Sold.
[Re: A39Coronet]
#3092202
11/07/22 12:18 AM
11/07/22 12:18 AM
Posts: 4,317 Puyallup, WA
StealthWedge67
Puyallup, WA
***** SOLD *****
[b][/b]Engle solid flat tappet cam Lifters and springs set
Cam is Engle KV3 lobe; specs shown on the cam card picture (252* / .573 - square on 109 cl) Lifters have been on this cam it’s entire life, look good, and are marked for lobe. Springs are brand new TrickFlow PAC doubles - 420 lb/inch rate.
This set (sans springs) was in my 451 which was built in 2010. Ran its entire life with Lucas HotRod 10-30 and zinc additive. Oil was changed approx every 50 runs. Wear pattern looks great.
$300 / offer - for the full set
***** SOLD *****
Edelbrock Victor BBM standard-port heads
[Re: StealthWedge67]
#3092694
11/08/22 08:13 PM
11/08/22 08:13 PM
Posts: 810 Loudoun County, VA
Brad_Haak
Loudoun County, VA
SOLD
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Hughes BB rocker arm shafts
[Re: Brad_Haak]
#3092695
11/08/22 08:18 PM
11/08/22 08:18 PM
Brad_Haak
Loudoun County, VA
New older set of Hughes' "banana groove" rocker arm shafts with push-in end plugs, not the screw-in type that stretches the ends of the shafts out. $120 shipped in lower 48 USA
I accept cash, USPS money orders, and PayPal. If using PayPal, there is an additional 3% transaction fee.
PM me here, or text 7 zero 3 - three 17 - seven 9 eight 7
*** SOLD ***
[Re: moparts]
#3094166
11/14/22 02:07 PM
11/14/22 02:07 PM
Posts: 839 West Virginia
B1Frank
West Virginia
SOLD **** MADE IN THE USA *** Isky big block adjustable rockers 1.5 very good condition , very little miles, had these rockers about #30 years, FREE SHIPPING thanks JEFF !
[Re: B1Frank]
#3095974
11/21/22 10:27 AM
11/21/22 10:27 AM
Joesixpack
APACHE JUNCTION AZ
1962-1969 361-383-413-426w-440 metal 90 degree pcv valve with pal nut nors usa made old stock.standyne patent# $25 ea 1970-1971 383--440 440+6 metal base,yellow plastic top, 3 ribbed pcv valve, usa made nors old stock ,NOVO, MANIFOLD UP on base$35 ea cowgerwilliam035@gmail.com
[Re: Hutch]
#3096491
11/23/22 09:10 AM
11/23/22 09:10 AM
MarkMcDonald
1972 400 HP engine and matching numbers 727 from a 72 Charger. It’s an early casting 400 3614230 block casting date 12/3/71. Looks like it was freshened up at some point and it’s very clean inside. New rocker arms and shafts double roller timing chain Hemi fuel pump. The person I bought it from said it was in a running car about 10 years ago. Spins freely and makes compression. Vin # 2A183848 assembly date 4/25. The trans is very clean also. I’m asking $1,000 for the engine and trans. Located one hour west of Detroit MI. Thanks Moparts SOLD SOLD SOLD!
