Re:Direct Connection 6 Pack Mech Carbs
[Re: ragtop]
#3089608
10/27/22 10:01 AM
10/27/22 10:01 AM
Posts: 196 Cent, OH
Mopar.70
Cent, OH
Hate to turn these loose, but needing funds for the next project! Open to reasonable offers.
Set of Direct Connection Mech. Carbs that are in their original boxes. Also comes with progressive linkage, brackets, return spring & mount, coil mount and full rebuild kit for all 3 carbs. These were for a 340 per the box but I think the only difference is the jets, same list numbers as what I run on my 440. Any questions on them reach out, $1,500 plus shipping. PM me here on the board or email to eastern_mule@yahoo.com SOLD
[Re: Mopar.70]
#3090494
10/30/22 02:18 PM
10/30/22 02:18 PM
Posts: 666 Ripley
BryanRad
Ripley
L2266 0.040 pistons and LY rods resized with ARP bolts. Less than 20 miles on these. Car was parked and just not brought out.
Located in Ripley, WV.
SOLD
1971 340
[Re: moparts]
#3090575
10/30/22 10:14 PM
10/30/22 10:14 PM
Posts: 1,575 MA
ragtop
MA
NOT SHIPPING. Cash Pick up only. Located in Billerica MA. Have many other 1970 Challenger parts. 1971 340 Long Block: 030 over, very low mileage. Ran great when I removed this engine. very little to no cylinder top ridge. 10 to 1 forged pistons, new cam bearings, new dist. drive shaft bushing. Also comes with high volume oil pump, oil pick up, oil slinger, fuel pump eccentric, front cam plate, date coded timing chain cover, water pump, engine cradle, & date coded heads which are re-built. Heads come with valves, rockers and shaft, retainers, locks & valve seals. (no valve springs). Heads and Oil Pan removed for inspection. 3000. will separate into short block and heads can sell separatly Extra 340 forged Crankshaft: $75 1968 373 Block $100. See some of my other parts in the E-body section and Transmission section .
Re: 16 used SB Crane aluminum roller tip rocker arm setup
[Re: moparts]
#3094197
11/14/22 05:36 PM
11/14/22 05:36 PM
Posts: 1,669 Edison, New Jersey
PHYSIXX
Edison, New Jersey
SOLD! I have for sale a set of 16 used SB Crane aluminum roller tip rocker arms, adjusters, MP chrome hardened shafts and the MP hold down hardware blocks. We had this on a mild bracket engine for a while then decided to put the car back on the street using the OEM design rocker setup. When we got these rockers, they weren’t a complete set so we got other good used ones to make the complete set. The original ones have a smaller radius where the adjuster locking nut goes while the other ones have a larger radius. I guess Crane realized that it was a real PITA tightening the lock nut with the smaller radius. What we did was use taller nuts on all of them and that made it much easier to tighten. All the rocker arms are the same 1.5 ratio but several were made later. Some scratches and wear marks but no issues at all with any of these parts. I would like to get $300.00 for the complete rocker setup plus the shipping. For an additional $50.00, if purchased together, I have a set of ball/cup pushrods that were used for the hydraulic lifter application. They measure approximately 7.25” and have a 5/16” diameter.
Edison, NJ rider1454 at aol.com
Re: 16 used SB pushrods for use with hyd lifter/adj rockers
[Re: PHYSIXX]
#3094198
11/14/22 05:39 PM
11/14/22 05:39 PM
PHYSIXX
Edison, New Jersey
SOLD
I have for sale a set of 16 very little used SB pushrods that came from a 340 that had hydraulic lifters and adjustable rockers so these have the cup tip on top and ball on the bottom. They measure approximately 7.25” in length and 5/16” in diameter. I couldn’t find any manufacturers mark on any of them so that’s an unknown. They are all straight and have no issues that I can see. I would like to get $60.00 for the set plus the shipping.
Re: For Sale - Small Block Engine - 4th Quarter
[Re: moparts]
#3096349
11/22/22 02:52 PM
11/22/22 02:52 PM
Posts: 2 NC
phil g
NC
SOLD THANKS MOPARTS Comp cams custom grind solid cam and lifter set. spec sheet attached. brand new never out of the bag. $250 plus shipping prgallim@yahoo.com
IMM built 416
[Re: moparts]
#3099249
12/03/22 03:33 PM
12/03/22 03:33 PM
Posts: 163 San Diego
JP8
San Diego
Fresh build. Never installed. 1973 340 block with a 4" crank (416"). Pistons are forged Icons. Zero deck. Piston to cyl. head clearance is .050". Compression is 10:1. Brian pored the Edelbrock heads. The heads have 2.5" intake and 1.60" exhaust valves. He spec'ed out the camshaft and it's a custom hyd. roller from Comp Cams at 233/239 @ .050" on a 108 LSA. Lift is .626/ .635 The hyd. rollers are from Gaterman and the lifter bores have been bushed. Rocker arms are 1.6 Harland Sharps from Mancini. Manton pushrods. Brian also ported the Melling high volume oil pump. The oil pan is the Milodon road race unit. IMM invoice was $12,500. Many other parts purchased outside of the IMM invoice like Edelbrock heads and Pro Flo 4 purchased separately = $4500+. Oil pan = $550+. 340 block. ..... Not shipping. Located in San Diego. For sale for the month of December only as I will be putting it into long term storage and won't be digging it out for at least a year. $12,000 firm. jpcarter80@gmail.com https://youtu.be/luZKC2v0pUU
Instagram : @5_points_racing
340 blocks
[Re: moparts]
#3099688
12/05/22 01:15 AM
12/05/22 01:15 AM
xx29
For sale: 340 blocks 1. casting date 6-18-68, rough bored to 4.075, will clean @ 0.40, VIN: BH29P9B105109, $800 2. casting date 3-10-69, Standard bore, VIN: 9E366510, $1200 3. casting date 1-8-70, bore 0.30, VIN: 0B353631, $1000 4. casting date 1-15-71, bore 0.30, VIN: 2B483446, $1000
Located in Los Angeles area, e-mail: ebodycab@msn.com, phone: 818-426-8685
[Re: moparts]
#3101100
12/10/22 03:19 PM
12/10/22 03:19 PM
Posts: 186 Arizona
sixpakjoe
Arizona
LD-340 Intake Manifold -- Like brand new, absolutely no disappointments. No cracks whatsoever, all threaded holes are excellent too. It has been recently carefully bead-blasted. Included in the sale are Fel-pro installation gaskets, Quality aluminum header collector gasket & bolt set (3 inch) also, Mr. Gasket header to Cylinder head set, ARP intake bolt set, and new Bypass hose & clamp kit. All these parts are brand new, in their packaging. $400.00 for all. Prefer pick up, shipping too expensive. sixpakjoe@cox.net......Peoria, Az.
NOS Electric Choke - 1973-82?
[Re: moparply]
#3107248
01/01/23 02:17 PM
01/01/23 02:17 PM
Posts: 4,039 MD
floyd
MD
Part of an auto store clean out. I have four of these electronic choke assemblies. All are unused with no box. I believe these correlate to Mopar part numbers 3698355 and 3751484 and will work on most 1973-82 V-8 applications. Brand unknown. Asking $15 each plus shipping. Additional pics on request. Thanks for the ad!
1 SOLD, 3 remaining
PM or email: musclesigns AT comcast DOT net
